Question about Whirlpool Duet GHW9150P Front Load Washer
Locked door/ machine won't run
How do I get the door to unlock and open or et the machine to run
  • mrich Aug 23, 2008
    Door locked Machine wont run
  • 639 Answers
Read the Manuel and see if they offer an over ride, first.
Try unplugging the machine and rebooting it!
If no go you will need service at this time!
A&E Factory Service is nation wide!
1800-905-9505
They are open 7 days 24 hours to make appointments
Neil
Posted on Aug 24, 2008
I had the same problem. Push the end of cycle button for 3 seconds and that will unlock your machine. Good Luck!
Door lock won`t engage
Hi - I understand that the door won't engaged, however does it show any other symptoms? Try to start a drain spin cycle and let the unit run for approximately 5-7 minutes and press cancel once. If the door opens immediately, unit made have a bad door lock. If you have to wait for the door to release to open, then possibly you have a control or wiring issue.
Sep 15, 2012 | Frigidaire GLTF2940ES Front Load Washer
Lg washing machine WM2277HW takes spells where door won't open at end of cycle.
try to replace the latch, go www.repairclinic.com and buy online.
God bless you
Jun 19, 2012 | Washing Machines
Maytag maxima door locked
Similar problem here - pump was set for a 58 minute normal cycle, I look in and see it is now showing 67. Hmm. Attempt to shut it off because it is just sitting there pumping and pumping. Power shuts off but pump keeps running and add garment light flashing red. Cannot open door (to add garment or not) Unplug the unit and the door will not open. Anybody got a clue what's up? I have a wash in, service is closed due to a storm today. Just bugs me that it is 6 months old and seems to act up a fair bit electronically.
Dec 09, 2011 | Maytag Washing Machines
I pushed the 'pause' button during the wash cycle of my LG WD-3274HD and now the door won't open.
Hi!
The machine knows it dint't finish the washing cycle, and, because it may be possible that water is still a lot inside, the door is locked.
If you are shure the door can be opened without the water coming out by the door, simply disconnect it from the electrical supply and wait a few minutes until the door unlocks. (you will hear the unlock click)
Aug 08, 2011 | LG WD-3274RHD Front Load Washer / Dryer
The door is locked and won't open; how do i unlock it manually?
unplug it,remove the bottom panel,stick your hand up where the door lock assy. is and on the bottom of the door lock assy. there is a plastic wire that releases the door manually,grab it and pull down and the door will release.
Jul 10, 2011 | Kenmore Elite 45986 Front Load Washer
My Neptune washer MAH6700AWW won't unlock door and won't work. It stopped mid cycle and the door is in locked position. I unplugged and replugged and try to run a cycle but all it does is make...
Hi
It seems that something is clogged in the drain pump assembly and you have to clean it to solve this issue. After cleaning if the issue returns then test the door lock assembly, if bad it should be replaced. Hope this helps...please post back for further assistance.
Daniel
Jul 07, 2011 | Washing Machines
Bosch Nexxt 300 has error code E-13 and the door is locked. turned on/off, unplugged, removed the drain hose to see if it is blocked, but ok. but still won't unlock. Is there someway to unlock the...
Turn the dial to off position wait few second, door should unlock. Unless you try to open it during cycle, it won't open. Otherwise, follow owner manual. call the manufacture.
May 18, 2011 | Bosch Washing Machines
Washed a small load, now the door won't open,
Power off by removing the plug off the set for some time. Now reset and see if the program resets. If not check if the program controller is activated to re-run a short drying mode. Let the mode end and see if the door opens. If not there is a fault in the lock , latching or unlocking from the program controller in end program.
May 12, 2011 | Electrolux Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
143 people viewed this question
Dan Webster
Dan Webster
Sal De
