Question about Canon Office Equipment & Supplies
I need canon 3020 manual
Pls any any help me.. i want canon 3020 copier manual or registration clutch part number?
Light printing
Posted on Nov 17, 2010
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 1,362 Answers
Posted on Aug 22, 2008
Xerox 7345 error 008-164 paper is folded with jams and 008/164
That error indicates that the paper was not sensed as passing the pob sensor which is right at the registration rollers. If the paper is folding there, the main cause is the registration clutch not being initialized or slipping. Replace registration clutch, part number: 121K22220
Mar 25, 2016 | Xerox Workcentre 7345 Printer, Copier,...
Canon2202ir E0000-000 This error code deals with the fuser unit. It is saying that the fuser is not warming up. It needs to be reset in service mode.
How can I enter service mode on canon ir 2202? - Fixya
Jan 19, 2015 - In standby mode, press the "Settings/Registration" key. 2. Press the "Reset" key. 3. Press the "Back" key. 4. Press the "Settings / Registration" ...
Error Code ir 2202n - > ... > Copier Technical Discussion > Canon
Nov 22, 2014 - 3 posts - ‎2 authors
... pls help me ....i know how to enter service mode but ......pls help. ... Copier Technical Discussion · Canon. [Error Code] ir 2202n ... ir 2202n. how to print jam history in ir 2202.......i dont know pls help ... mm its a new machine , i need to know how to enter the service mode if u please ... Press the "Reset" key. Error Code canon image ronner 2202N
Aug 21, 2014
Canon IR 2200 error E000001-002
Jun 18, 2009
More results from
Dec 21, 2015 | Office Equipment & Supplies
Canon IR8070 paper jam infront of Registration roller
If you can reach the paper in the jam you will have to pull it out to dislodge the jam. Be careful not to rip the paper in doing so!
Aug 28, 2014 | Canon Office Equipment & Supplies
May canon np 3020 ka machine liya hu. jab photocopy kiya jata hai to isme ek taraf kala aata hai. ye kis problam se aata hai
may canon np 3020 ka machine liya hu. jab photocopy kiya jata hai to isme ek taraf kala aata hai. ye kis problam se aata hai
Jul 24, 2010 | Canon Office Equipment & Supplies
In my 3530 single side copying is ok but when i am trying for back to back my A3 paper is getting jam with z fold pls guide
are you talking about ir 3530 b&w copier?
"Z FOLD" of jamed paper is usual when paper goes from cass. towards registration roller, and registration clutch doesnt operates.
Do you have problems with A4 double sided too?
Where does the jam occures? In wich section?
I had few cases, when the paper stucked above fixing unit in small inner door, wich guides paperout or back in duplex, for second side copying.
The problem was in spring and solenoid wich lifts the paper guide plastic with finger.
It also could be case that you need to replace paper pickup, feed and separation roller in cassete where is A3 paper, and clean other rollers.
Try to put paper in "good" cassete, from wich you do not have problems.Just swap papers, and set correct paper sizes, and if it works then the problem is 70% in rollers.
On the place where the paper stucks, clean the paper rollers, by rotating it and cleaning with alcohol or water and dry it verry well.
Hope that helped.
If you have more questions or want service manual, write on
Jul 09, 2010 | Canon Office Equipment & Supplies
Image registration adjustment on canon imageRUNNER C2620
Did you check the registration clutch? try to clean it. Be sure that the paper drawer sensor is "saying" the correct paper size.
May 25, 2010 | Canon imageRUNNER C2620 Color Copier
I have a canon xerox machine model 3020 copy is not comming,blank white paper is comming
Canon 3020 is a scanner, not a copier. It can scan a document & store. If you print the image, you will get a 'photocopy'.
S. Mohan
Sep 18, 2009 | Canon DR 3020 Path-Through Scanner
Canon DR-3020 Scanner with Windows XP Pro
Download Dr 3020 drivers for XP from
Try connecting the scanner to a diff computer and check if it is okay. Also pls ensure SCSI termination is okay.
S. Mohan
Jul 09, 2009 | Canon DR 3020 Path-Through Scanner
Regi problem in IR105
Recommend you to change the brake platform under registration roller or look the spring under her.Registraconnyy gross has a synchronizing the enabling the seizure of the paper, she often comes out of building, open the lids and fix timeliness of the drive of the registration gross of the roller of the seizure буаги. Analyse the **** or see the electromagnet. Good luck!
Apr 26, 2009 | Office Equipment & Supplies
Canon LaserCLASS 710 Fax Owner's Manual
Set Speed Dial / One-Touch Feature
  1. Open One-Touch Speed Dialing Panel and press “Data Registration.”
  2. Under “Additional Functions” scroll to find “4. ADD. Registration” and then press “Set.”
  3. Scroll to find “1. 1-One-Touch Speed Dial” and then press “Set.”
  4. Under “Tel # Registration” scroll until the desired “One-Touch” number is displayed. Press “Set.”
  5. Under “Tel # Registration” scroll to find “1. Tel Number Entry” and then press “Set.”
  6. Under “Tel Number Entry” enter fax number (with “9” and the area code – ex. 913104454200) and then press “Set.” Screen will display “Data Entry OK.”
  7. Under “Tel # Registration” scroll to find “2. Name” and then press “Set.”
  8. Under “Name” enter the company name and press “Set.” Screen will display “Data Entry OK.”
  9. Press the red “Stop” key on the main control panel.
  10. The “One-Touch” feature is now set.
Label corresponding “One-Touch” button with company name.
Jan 30, 2008 | Canon LaserCLASS Fax 710 Printer
585 people viewed this question
old marine
old marine
