Question about Epson Stylus Photo R260 InkJet Printer
Epson R-260 offset
My Epson R-260 printed a couple of discs and it is printing on paper okay, but now it offsets the printing way to the back and left of the disc. Moving on the print positioning menu seems to make very little difference.
  • William Hyman Aug 22, 2008
    Yep, I removed and re-installed Print CD on my Mac and it fixed the problem.
    Thanks
    Novelist:
  • 110 Answers
Make sure you are using the correct version of the Print CD. If you had a older Epson printer with this program remove it, and install the one that is on the disk.
If you are operating on a Mac and it has automatically updated to the latest OS, remove and reinstall the program.
Posted on Aug 22, 2008
Some pages offset printing
You need the paper feed tires replaced.
Feb 17, 2014 | Xerox 5500/DT Laser Printer
Vertical lines are not smooth, they are jagged. The lines are straight for about an inch, then they are offset to the left. Some words are broken in half horiziontally with the lower half offset to the...
You can align the print cartridges at any time from the control panel or by using the HP Image Zone software on your computer. Aligning the print cartridges ensures high-quality output.
Note: If you remove and reinstall the same print cartridge, the HP all-in-one will not prompt you to align the print cartridges. The HP all-in-one remembers the alignment values for that print cartridge, so you do not need to realign the print cartridges.
To align the cartridges from the control panel:
  1. Load letter or A4 unused plain white paper into the input tray.
  2. Press Setup.
  3. Press 6, then press 2.
  4. This displays the Tools menu and then selects Align Print Cartridge.
  5. The HP all-in-one prints a print cartridge alignment sheet and aligns the print cartridges.
Feb 16, 2011 | HP OfficeJet 7410 All-In-One InkJet...
The printer breaks the silver hologram ribbon everytime i print.it only break the silver ribbon when i do holograms
If your ribbon is breaking while printing a card, there area few things to look at.
  • Check that the printer driver has the appropriate ribbon selected. If a different ribbon is selected on the driver other than what you are using in the printer. Go into the driver and change the setting to the correct ribbon.
  • Another reason your ribbon may be breaking is because the "X" offset is set too low or too high, in other words the printing is beginning too close to the left side of the card, or ending too much to the right side so when the print head goes down to print on the card, the ribbon gets sliced because the print head and the edge of the card knife the ribbon. In order to eliminate this problem, increase or decrease the "X" offset value. I recommend a minimum of three digits up/down depending on the circumstance. For example: X-offset = 06...increase X-offset to 09. If the "X" offset is to high...EX: X-offset = 20...decrease X-offset to 17. Do not increase or decrease the value by more than 5.
  • If ribbon appears melted onto card, the print head may be damaged. Do not try adjusting. Immediately contact your re-seller or Zebra technical support.
  • If ribbon is breaking and nothing is being printed onthe card, contact your re-seller or Zebra technical support.
Dec 04, 2010 | Zebra P330i Thermal Card Printer
Double sided copying
http://www.brother-usa.com/ModelDocuments/Consumer/Software%20Users%20Manual/SUM_DCP_7030_7040_MFC_7340_7345N_7440N_7840W_EN_1650.PDF
here is the manual p4 and p16 discuss the topic:
Duplex printing 1
The supplied printer driver supports duplex printing.
Guidelines for printing on both sides of the paper 1
�� If the paper is thin, it may wrinkle.
�� If paper is curled, turn over the stack, straighten it and then put it back in the paper tray or the Manual Feed
Slot.
�� If the paper is not feeding properly, it may be curled. Remove the paper, straighten it and turn over the
stack.
�� When you use the manual duplex function, it is possible that there may be paper jams or poor print quality.
If there is a paper jam, see Paper jams in the User’s Guide. If you have a print quality problem, see
Improving the print quality in the User’s Guide.
Manual duplex printing 1
The machine prints all the even-numbered pages on one side of the paper first. Then, the Windows® driver
instructs you (with a pop-up message) to reinsert the paper. Before reinserting the paper, straighten it well,
or you may get a paper jam. Very thin or thick paper is not recommended.
Simultaneous scanning, printing and faxing 1
Your machine can print from your computer while sending or receiving a fax in memory, or while scanning a
document into the computer. Fax sending will not be stopped during PC printing. However, when the machine
is copying or receiving a fax on paper, it pauses the PC printing operation, and then continues printing when
copying or fax receiving has finished.
�� Manual Duplex
Check Manual Duplex. In this mode, the machine prints all the even numbered pages first. Then the
printer driver stops and shows the instructions required to re-install the paper. When you click OK the odd
numbered pages are printed. There are six types of manual duplex binding directions available for each
orientation.
�� Booklet Printing
When you want to print a booklet, use this function. To make the booklet, fold the printed pages down the
middle.
�� Binding Offset
If you check the Binding Offset option, you can also specify the offset for binding in inches or millimeters
May 14, 2009 | Brother MFC-7440N Laser Printer
After paper jam text is offset 1 mm every 0.5"
you still have a piece of paper stuck some where in the paper path have a closer look
May 12, 2009 | Canon Pixma iP2600 Photo InkJet Printer
Canon LBP 1120 Offset paper feed and subsequent jamming.
G'day, I pulled the whole printer down and gave it a clean and put it back together and set it to work. All good.
May 11, 2009 | Canon LBP 1120 Laser Printer
Epson 1290 prints a ghost image in cyan or magenta
I like this one! No don't have a solution but....interesting Try it's test not by computer, just printer, may need head alignment, should be a command for this on printer
Apr 23, 2009 | Epson Stylus Photo 1290 InkJet Printer
Printing from InDesign CS3
even if you have the same document size and paper size the printer will not print exactly to edge to edge... so please select scale to fit and check the percentage of scaling if it is more than 95 then your document should look as big as it is desired
Mar 13, 2009 | Epson Stylus Pro 4800 InkJet Printer
Epson AcuLaser C1900 starts printing too low
I have a C1900 with an error "Service Req E021". I appreciate any help as to what this refers to please.
Jan 05, 2008 | Epson AcuLaser C1900 Printer
Printing Alignment
Is the paper cassette set to the correct paper size and/or the printer driver printing to the correct paper size? Sometimes this can cause the image to be offset.
Sep 12, 2007 | Canon IMAGERUNNER 3530 Copier
Epson Stylus Photo R260 InkJet Printer Logo
102 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
