HI I have an AWA DVD player model DP208 on the old tv with yellow video cable it has a picture on our LCD HD TV with s video cabel TV Svideo on no picture my friend dvd player with svideo cable on my LCD TV IT workes thanks Ian my email address is
  • iangascoigne Aug 22, 2008
    HI thate sounds good i will wate till tomorw
  • Anonymous Mar 24, 2014
    Please locate a free download for Userguide for AWA Alarm Clock Radio 34QLD. My Email is: Thankyou
  • 1,586 Answers
Can you rephrase please?
Posted on Aug 22, 2008
  • Jeremy Dellow
    Jeremy Dellow Aug 22, 2008
    The way I read this, you can't get a picture on the newer TV but you can with the older one. Are you sure that your DVD player is capable of S-video transmission? There may be a setting you have to adjust to take a feed from the DVD player using the S-video input. Take another look through the manual for the DVD player if you have one - you may find that the way to make it work is different on your DVD player when using S-video than when you use regular patch cables. There seems to be nothing wrong with the S-video input on your TV, and the DVD player works fine (since you can use it on the older TV) so there has to be a setting (maybe menu-driven) to adjust in order to allow S-video to work. I'll buzz a friend of mine tomorrow morning and see if I can get a scoop from him on how to make it work.
AWA HD LED LCD TV with builtin DVD Manual
Hi Beverly House
You can use this manual for your LCD TV
I hope my solution may help you.
Thanks for using Fixya...;-)
May 06, 2014 | Televison & Video
How do i connect a DVD player?
Use three RCA cables, yellow, white and red to connect DVD player to TV as shown in the diagram below. Connect yellow to yellow and white to white. Connect red to red. Select on the TV, the A/V input where the DVD is connected using the TV remote control. Power on TV and DVD, place a disc in tray of DVD player and press PLAY.
Mar 28, 2011 | Toshiba 22AV600U 22 in. LCD TV
How do I hook up a dvd player?
Hello Andy, Hi!, you can hook up your DVD in 3 ways. 1. using standard RCA cables, 2, using Svideo cables, and 3. using HDMI cables. Depending on your player. I suggest you buy the RCA cable. they are color coded so the yellow goes to the player Video out to the TV video in, red and white cables goes to the Left and Right channel of the player audio out to the TV audio in. thats it.
Dec 21, 2010 | RCA F27242GY 27" TV
your TV has composit video in but your DVD/VCR only has Component video and Svideo outputs ..those are not compatable with your tv .. if you look more closely you might find an SVideo input on your tv .. its flat and not as easy to see as the normal jacks .. if your tv does have SVideo then all you need is an SVideo cable (plus the two sound cables) ... i could check on what you have if you give the TV model number .. othwise you have to have something to convert your SVideo to composit video .. there is a cable that does that .. you can check with radio shack .. if they do have such a cable then one end would plug into the svideo of the dvd/vcr . the other end would plug into the yellow jack on your tv .. hook up sound and it should work ok ..
here is such a cable on the internet ..
or google "svideo to composite" to see lots of options
Nov 22, 2009 | Sylvania DV220SL8 DVD Player/VCR
How do i hook my dvd player to my tv? i have no manual to show me where to plug the wires into the back of my tv.i have a proscan 32LB30Q LCD
Hello pebbles12137,
This depends on what you want to do SD or HD
First if you just want to connect for SD only
Here are Three ways:
1) connect the coaxial cable to the DVD player F-connector (sliver screw connector) and the to the TV's Antenna in F-connector.
2) connect the yellow, red and white RCA connector end wires to the yellow, red, and white RCA Jacks of the TV Yellow (video in), Red (Right Audio in), White (Left Audio in) do the same for the other end into the DVD player (Best SD Method)
3) connect the svideo cable into the s-video socket of the TV and the other end to the s-video socket of the DVD player
For HD, Here are the connection methods:
1) Connect the HDMI cable to the HDMI in of the TV (HDMI1)and the other end of the HDMI cable into the DVD player. (best HD method)
2) connect the Component video cable (RGB) into the RGB sockets of the TV (should be marked as Component 1) and connect the other end to the DVD player (using this method you will have to connect the Red and White audio cables to the audio input jacks of the TV from the audio out of the DVD player)
These are the SD and HD methods.
I would suggest using the HDMI cables only, its the best choice and the simplest.
I hope this helps,
Thank you,
Jun 21, 2009 | Proscan 32LB30QD 32 in. LCD TV
Dvd won't send picture/audio to tv
for video, 3ways and any of this should work.
Step1, video out of dvd to video in on top at video1 section on tv. or
Step2, svideo out of dvd to svideo in at video1 section on tv. or
Step3. using component video DVD unit component video out to TV unit component video in at video2 Y to Y input of TV Pb to Pb input of TV Pr to Pr input of TV
for audio, connect left/right audio of dvd to left/right input of tv. Input section of TV is in the middle. on tv back panel from left to right is antenna input, IN section - this is it, use this for all your connections. let us know if you have any issues. thanks.
May 02, 2009 | Panasonic DVD-S27 DVD Player
How do you connect AWA plasma TV to AWA surround sound
Hi Map33_bm
It appears that your TV set is 2 channel stereo, so as there is no surround signal coded into the TV audio channels, thesurround sound does not process it.
I've posted a PDF in 'manuals' which you can check out.
Did this info help at all?
Regards, Clive.
Oct 28, 2017 | Televison & Video
AWA DVD Player DP208
Press "V-Mode" on remote control. Answer courtesy of AWA Warranty Support.
My thanks to FixYa and hopefully of benefit to other readers.
Jun 17, 2008 | Televison & Video
Cabling -- Panasonic LCD TV into LG DVD player (model no. DV6812P)
Take the basic Red, White, Yellow component cable -- plug it into the backside of the DVD player and plug the other side into the back of the t.v. Make sure to plug the right colors into the right sockets. If there are no available AV inputs on the back of the t.v, plug the other end into your cable box (if you have one).
Mar 03, 2008 | Televison & Video
No color or sound on DVD Player when hooked up with the ShowStopper
Svideo requires the audio cables too, Red and White. Svideo is only carries video.
Dec 30, 2007 | Panasonic PV-HS2000 Showstopper 30-Hours...
Televison & Video Logo
125 people viewed this question
Top Televison & Video Experts
