Question about Toshiba 43H71 43" Rear Projection Television
Replacing IC's Thank you Terry, I will try to find out what the local repair shop charges for this task - thanks to you I will not sound as ignorant as I would have prior and hopefully therefore will not get taken to the cleaners for it. What would you say would be a reasonable charge by a repair shop for doing this? Again, Thanks for your help!
    Genius:
  • 1,694 Answers
If you carry-in to shop, repairs can run $300.00 + $60.00 parts..
considerably more including pick-up and delivery....
Perform a google search for TV repair in your zip code and ask lots of questions...go with experienced shop owner-operated with
good reviews on www.Kudzu.com ...HTH..........Terryfic.
Posted on Aug 22, 2008
No output on any sound I have done a reset and still nothing
Hi! self also facing similar problem with AVR120. No sound coming from any channel. Video is coming from DVD but no sound. Display / Remote is working. Did a RESET but same situation. please advice next step. local repair shop suggesting that some 'IC for sound is gone and charging a bomb for replacement. Please advice.
Sep 28, 2013 | Harman Kardon AVR 120 Receiver
Check engine light on.
Go to Auto Zone or your local repair shop and have them check it with a code reader. Auto zone wont charge you, your local shop shouldnt either. They can tell you the problem, and what it will taske to fix it. You can go from there.
Sep 16, 2013 | 2001 Volkswagen Cabrio
My nokia 6303 classic display is not working but i can recieve the call and all i asked in shop they said ic is gone ,,so can it be fixed n what will be the cost of original ic
Hi.There is no Particular display IC (filter).The tracks of the Display is directly connected to Rap IC.If the Rap IC is damage there is way to fix this.It can be only repaired by making jumper or replacing of LCD socket.The cost will be charge between 300 to 500 INR.You can see it from this 6303 display ways .Thanks for visiting fixya
Feb 24, 2012 | Nokia Cell Phones
How do I replace the shocks on my 1999 jeep
I suggest that you call a few auto repair shops and also a suspension pro shop and compare the labour charge in replacing your shocks. If it`s only the shocks you want to replace, keep in mind that a hoist-lift, impact-gun, and a heating/cutting torch will be required to preform this task. To replace shocks is not to expensive, it`s fairly priced and will save you the fustration of doing this yourself. Shop and compare, you will thank me later..
Mar 12, 2011 | 1999 Jeep Grand Cherokee
My 1100 mobile phone showa not charging
There are several reasons, like bad battery, bad charging connector, bad charger, charging pin problem, charging ic, etc..
You need to try with another charger and with another battery. If changing the charger and battery don't help, follow the instructions below;
First, remove the battery, clean the contact points on the battery and also clean the battery interfaces on the mobile. You also need to check the charging connector and clean whatever is possible. Use soft brush or cotton with Ipa solution or alcohol/spirit/acetone to clean all the metal contacts. Try charging again.
If the above method don't help, you need to change the charging pin;
Still the problem persists, then check the charging ic. Perhaps jumpering will be necessary.
If you are not sure what you gonna do with ic, I don't recommend to play around with it, rather take it to a mobile repairing shop or nokia service center and get it fixed. You may damage another components.
I wish you good luck.
Thanks for using FixYa.
Jul 24, 2010 | Nokia 1100
Nokia 6300 Cellular Phone
try to replace a new and tested one..if still fast drain your nokia 6300 is shorted and need to remove the shorted parts..thanks
Jun 10, 2010 | Nokia 6300 Cellular Phone
Rangar not working, plese tellme the ic trakes
it will not be an ic it means the speaker needs replacing, take it to your local phone repair shop
Apr 01, 2010 | Sony Ericsson K550i Cellular Phone
Our TV (Mitsubishi WS65711) is 6 years old, and has recently started showing a blue ghost image on everything. It stopped for a while for a week or two, but started back up, and has continued ever since. I...
You have convergence problem in your tv as your local repair shop told you. You need to replace convergence IC . YOu can get from the link below .
Convergence IC can be obtained from the link
You need to replace both convergence ICs .It will cost you around $30
If you can replace it by yourself . If you take to repair shop they will charge you around $200 for this job. .
The IC number is STK393-110 .
You can get some idea on how to replace convergence IC from the link below
http://www.fixya.com/support/r704766-convergence_solutions
Hope this helps .
Feb 19, 2009 | Mitsubishi WS-65511 65" Rear Projection...
Hitachi 43FDX15B Convergence Failed
You will need to order part no. CZ01341. This is the output ic. There are 2 of them, replaced them both. The numbers that are printed on the old part will not match the new part, do NOT take this to hart. It is a modification that you are putting in. You should be able to do this your self. I would charge 350.00. The set is not worth much, not working. Maybe 100.00
Jun 05, 2008 | Hitachi 51F510 51" Rear Projection...
TV Picture Reduced to Line across the Middle
This is called field-collapse. Either
1. The problem lies in the vertical deflection voltage-doubler circuit. The usual fault is a single capacitor of 100uF/35V that has failed. It is normally connected to a rectifier diode right at the vertical IC. Replacing the capacitor usually gets it working perfectly again.
or
2. The vertical drive IC has failed.
If you are finicky around technical work, then a reputable local repair shop in your locality should do it quickly for you and charge only labour.
Jan 13, 2008 | Symphonic ST419E TV
Toshiba 43H71 43" Rear Projection Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
