Question about RCA Televison & Video
Rca convergence- HELP!!!!
My tv sometimes get this ghost like paicture- I use to be able to go to either auto convergence or red/green and line the corss- now as I hold the arrow down - it stops at a certain point and won't go any further thus not allowing me to over-lap the lines- Can someone please help
  • 125 Answers
Replace the converg pcb inside the tv and realign the picture
Posted on Aug 22, 2008
Have green and red ghost lines that are permanent on my old sony grand wega TV 50e 200a rear protection tv Help would be appreciated will repair on my own just no idea what to change
First try convergence setting in menu. If convergence adjustment will not move the lines then you probably need convergence output IC's and probably two fuses.
Apr 14, 2014 | Televison & Video
Rca big screen 5-8 years old, power shut off this morning while watching then when I powered it back up now blurry and has a red and green outline around everything onscreen
If you have the original remote to that tv, click on menu, then select set up from the on screen menu, then select convergence. you might see auto convergence as well as manual for blue and red convergence.
If you see Auto, select it, this will line up your tubes.
If no auto convergence, you will have to select each one, and follow the instructions to aline your tubes.
Oct 09, 2010 | RCA R52WM24 52" HDTV Projection Television
RCA D52W23 52in HDTV red and green ghost and bowing lines
Ur convergence it dead,need convergence kit,use what in that kit,U know to solder? Tries websites Tv Repair World.com,Ebay.com
Oct 06, 2009 | RCA D52W23 52" HDTV CRT TV
Color is distorted. Green, red, and blue ghosts
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Jul 15, 2009 | RCA P52950 52" Rear Projection Television
Red green and blue lines rca 52' rear proj.
your convergence powert supply is not working-
replace the supply or repair it
Dec 25, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
**** tv
this is an indication of convergence failure. on this set first question i need to ask is IN you setup menu do you have the convergence option. if not this is an indication of a special fuse that has failed. if not it can be more.
Jul 26, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Ghosting in red ,blue & green
Sounds like an allinment problem with the color projection you can allin yourself via small screws on color tubes in rear. but be careful as tv needs to be on to do it.
Jul 17, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Convergence Problem RCA HD52W59
you need to test all cables then make shure it is not your tv.
Jun 20, 2008 | RCA HD52W59 HDTV Projection Television
Color Issues with red ghosts on screen
The suggestions listed would be relevant for 'Ghosting' by itself, however you mentioned you tried to use the crosshairs to line up the images4.gif, which implies convergence - red/green/blue image separation and/or distortion. NONE of the solutions mentioned were anywhere close to the fix for this problem - this us usually cut and dry; convergence circuit failure. Generally, STK ICs are used. (Common parts are STK392-010/020/040, STK392-110/120/150/180, etc.) Most times replacing BOTH of these chips will be enough, sometimes there will be a blown fusible resistor and/or burnt resistors near the chips themselves. If you don't implicitly know exactly what I'm talking about, don't attempt it - take it in to a repair shop. For in-shop repair, this would NOT exceed $250 (EVER) at our location, unless there was more damage done, which is a one in a hundred situation. Good luck!
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 10, 2008 | Hitachi 43F300 43" Rear Projection...
Televison & Video Logo
60 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
