Question about Minka -Aire Brushed Nickel Remote Control Fan MIA F518-BN
Minka Aire remote controlled ceiling fan
I have two Minka Aire remote controlled ceiling fans in the house.  The remotes are programmed identically so when my son operates his fan or light, it affects the one in my room.  I can find the pins in the remote to change the configuration, as instructed in the manual but I can't find the receiver in the fan to make the same changes. The owners manual doesn't tell you where it is.   Where is the receiver on the fan?  Thanks
  • Anonymous Dec 23, 2008
    Same problem.
  • Anonymous Mar 23, 2014
    the remote works the ceiling fan but it won't turn the lights on
I have a newer Minka w/ wall controller. The books says to make sure both the wall control and the receiver(up in the fan) are both programmed the same. My receiver has no little switches but has a sticker stating that you need to hold the 'fan off' button down for 3 seconds after turning on the power so the receiver can memorize the program in the wall switch. You have 60 sec to do this after power is turned on. Good luck !
Posted on Feb 25, 2009
I have the same problem, except I live in a multi unit condo where many of the occupants own the same fan! You can imagine how  frustrating this is when your fan or light comes on or you can't  agree on a fan speed. Anyway, I spoke to a MinkaAire customer service guy and he tells me that the switches in the receiver are located under the mounting ring. You need to unscrew the ring and it should be located in there. I haven't tried this myself as my fan has a mind of its own as I type and everytime I turn it off to unscrew the mounting ring, the damn thing turns on again.
Posted on Sep 04, 2008
  • Imelda Fagin
    Imelda Fagin Jun 03, 2017
    Haha, yes Minka does like to play mind games with its customers. Its a great fan....till something goes wrong.
    Habit-Forming:
    New Friend:
  • 3 Answers
A friend of mine with the identical fan only had to have the remote configured. Have you tried that? And isn't it a bit ridiculous to expect the owner to have to take the whole fan apart?
Posted on Jun 03, 2017
    New Friend:
You have to disconnect the power lead of one of the units. Then use the stop button to program the one fan/light. Disconnect the fan's power lead that you just programmed and set different dip switch of the next fan. Connect it's power lead and program it. Reconnect the first fan and they will both work with their respective controllers
Posted on Jul 29, 2013
How do I program a MinkaAire R211 remote?
How do I program a MinkaAire R211 remote? - Fixya
www.fixya.com/support/t26033435-program_minkaaire_r211_remote
2 hours ago - I have set the wall mount, hand held R211 remote and the fan receiver to the same frequency. 1 & 2 ON and 3 & 4 OFF. But the remote still wont ...
[PDF]Universal Hand Held Remote System - Minka Group
minkagroup.com/sites/default/files/product.../RC212-English.pdf
NOTE: The RC212 Universal Hand Held Remote Control System is equipped with a learning frequency function which has 256 code combinations to prevent ...Missing: r211
Minka Aire Remote Control RCS212 and Wall ... - YouTube
? 0:56
https://www.youtube.com/watch?v=359xzOXynxI
Jun 14, 2013 - Uploaded by Del Mar Fans & Lighting
Del Mar Fans & Lighting's Minka Aire specialist provides tips for using these innovative ceiling fan controls ...
Jan 01, 2016 | Dryers
Hardwired ceiling fan turned off by itself and stopped responding to remote control, but the light turns on/off.
I've had problems with Minka Aire also. You might need a new receiver. Call Minka @ 1-800-307-3267 and talk to someone in tech dept.. Should be a one year warranty on the receiver.
Aug 17, 2015 | Minka Lavery Minka Aire F888-BNW...
I have a Minka Aire Concept 1 which has been programmed to operate from a different frequency than nearby fans with remotes. The light goes on and off by itself at will and goes off each and every tim
Does your neighbor have a remote fan? Check wattage of bulbs to make sure they're the correct wattage. Still not working correctly, call 1-800-307-3267 (Minka Aire)
Sep 20, 2014 | Minka Aire Ceiling Fan
Minka Aire model f603 reverse switch?
Not sure what model of fan or manufacture you have. Says Hunter 52" & Minka aire F603. If it's the Minka , Then push the button on the lower part of the remote (6 o'clock). If that doesn't work then you might need a new receiver.
Jul 23, 2014 | Hunter 52" Ceiling Fan With Light And...
Minka Aire Ceiling Fan light wont come on
Probably needs a new remote receiver.Contact Minka Aire @ 1-800-307-3267
Apr 30, 2013 | Minka Aire Ceiling Fan
Minka Aire remote control ceiling fan problem with dimmer.
Did you ever find a solution to your issue? I have the EXACT same problem and have been looking for an answer for about a year.
Sep 20, 2009 | Minka Aire Ceiling Fan
Minka aire concept II flushmount
try buying a wall mount remote. it must be made to be able to be programed
Jun 13, 2008 | Minka Concept II Flush 44 Ceiling Fan by...
Minka Aire Remote control R211
You need to change the tiny DIP switch settings so each fan is set up differently. (Note that each pair of remote transmitters--the one in the fan body, held in a bracket above the light kit when you drop that down; plus the one on the wall switch or in a hand-held remote, must be set with the same combination.)
Our Minka Aire Churchill model has 4 DIP switches; I have seen Casablancas with 5.
Jun 01, 2008 | Minka RC120 Remote Control
Minka -Aire Brushed Nickel Remote Control Fan MIA F518-BN Logo
7,836 people viewed this question
Top Minka Dryers Experts
Joseph Coppeto
Joseph Coppeto
Are you a Minka Dryer Expert? Answer questions, earn points and help others
