Question about Hitachi 43F300 43" Rear Projection Television
43F300 convergence The green line on my TV is severely bowed at the top and bowed at the bottom. I've heard this is a convergence IC problem. I need to know the part #'s for each and also how to get to my service mode for allignment. Thank Chris.
  • 1 more comment
  • kathmance1 Aug 22, 2008
    Hitachi 43F300 picture problem.
  • kathmance1 Aug 27, 2008
    Not even the right part for my TV, I just need to adjust my convergence and need to get into service mode to do that. Can someone please help.
  • Anonymous Mar 18, 2014
    I ned to know if i can allign convergence mamuelly without the remote control
    Sergeant:
    Champion:
  • 375 Answers
Convergence kit # x480306 , dont go into the service mode unless you know what your doing in there and what your adjusting./st.
Posted on Aug 23, 2008
There is a constant blue shadow and yellow bowing from the top of screen. Needs convergence circuit repair = replace convergence IC's, How is this done!!!
Please do us a favor and rate this by cliking the thumps up icon located here >>>>>>
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 22, 2011 | Hitachi 43F300 43" Rear Projection...
Hitachi UltraScan HD Projection Screen 43FDX01B
The convergence board is on the fritz! See TVRepairKits.com and see if they have a kit just right for you!
Jan 12, 2010 | Hitachi 43FDX01B TV
Red, green, and blue lines at bottom of screen, mirror looking effect, also looks like 3D. Got at a garage sale so no manual.
  • Screen looks 3D
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
Jan 03, 2010 | Hitachi 43F300 43" Rear Projection...
Ws 55511 convergence lines bowed down at bottom of screen
Check resistors might have cold solder joints are changed resistance values around replaced STK393-110
Pay attention to faded colored or fried resistors.
You can download service manual for WS-55511 from HERE to get schematics and technical info. (download all 3 parts of file and use WinRAR to extract file)
Good luck.
Dec 13, 2008 | Mitsubishi WS-55511 55" Rear Projection...
43F300 convergence
Convergence kit # X480306 for your Model #.....
Replace parts & activate auto-focus......T.
Sep 01, 2008 | Hitachi 43F300 43" Rear Projection...
Green Bows on top and bottom
This is most likely either bad connections on the convergence IC or a defective IC. Try resoldering the pins first. If that fails to resolve the problem, replace the IC.
Dan
Mar 18, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Red bow on top and bottom of 61dx01b
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
Feb 20, 2008 | Hitachi 61SDX01B 61" Rear Projection...
Screen is bowed (top and bottom) Color has a green and purple tint?
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Here is an example video
utube.png You-Tube video "9oI1Nzq7CR8" placeholder (do not delete) utube.png
Jan 15, 2008 | JVC AV-56WP74 56" Rear Projection...
Convergance Green bowed top & Bottom
Nov 21, 2007 | Hitachi 43F300 43" Rear Projection...
Bowing image top and bottom of screem
No im sorry there is nothing to do but replaceing the convergence IC
Oct 30, 2006 | Toshiba 55H70 55" Rear Projection...
Hitachi 43F300 43" Rear Projection Television Logo
91 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
