Question about Saeco Easy Espresso Machine
Machine didn't want to ventilate. The ventilating prompt finally went away and now it says to prime the machine. How do I prime the machine
  • 515 Answers
Open the steam knob and make a cup of water(tea).
Posted on Aug 23, 2008
Error message "Ventilate"
Hi
That means the pump needs to be primed by running water through the wand. Push the water button for water(the drop symbol) You will hear the pump change tone when it primes and the light or message will disappear. If you have a restriction in the intake line the message will not go away. There is a flow meter inside the machine that measures water flow. If the flow meter does not spin when the pump is running, the computer thinks that the pump is not primed. Ventilate
Mar 15, 2010 | Saeco Magic Comfort Plus Espresso Machine
What do you do about the ventilate message
Ventilate is the same as priming the machine open the hot water valve to purge the hydrallic system.
Jan 24, 2010 | Saeco Magic Comfort Plus Espresso Machine
The coffee machines say ventilate
Hi
You need to run water through the wand to prime the machine. Push the button that has or says water or a drop. The display will say "hot water". When the "ventilate" disappears it will say "warming up". You are primed.
Oct 15, 2009 | Saeco Royal Professional Espresso Machine
Ventilate shows.
try prime water on steam valve couple minuts if you have again message ventilate,that can be two reason,or your flow metar doesnt work or cpu board,but you try first prime water.
Aug 28, 2009 | Saeco Royal Professional Espresso Machine
Stuck on ventilate
Try this, open steam wand, if it calls for ventilate pusi in steam knob, if that works then the tap rod on the steam valve needs to be replaced. To me it sounds like the machine is building up pressure and the discharge is not releasing through the water circuit.
Apr 26, 2009 | Saeco Vienna De Luxe Espresso Machine
Machine says ventilate
When it says to ventilate, it is asking you to prime the pump. Put a cup under the panarello wand ( the steamer/frother) to catch the discharged water and press the hot water button (upper left button on my machine). Wait until air stops coming out with the water, usually 3-5 ounces, and then press the hot water button again.
You machine is now ventilated (primed) and should be ready to go.
Jan 11, 2009 | Saeco Royal Digital Plus Coffee...
My coffee machine says "ventilate"
When it says to ventilate, it is asking you to prime the pump. Put acup under the panarello wand ( the steamer/frother) to catch thedischarged water and press the hot water button (upper left button onmy machine). Wait until air stops coming out with the water, usually3-5 ounces, and then press the hot water button again.
Jan 05, 2009 | Saeco Royal Digital Plus Coffee...
Ventilate sign on my coffee machine
Dec 15, 2008 | Saeco Royal Digital Plus Coffee...
My coffee machine says decalcify ventilate
For ventilate:
For decalcify:
Recommend downloading and following these directions.
http://www.partsguru.com/user/Safe%20Descaling%20method.pdf
Apr 27, 2008 | Saeco Royal Digital Plus Coffee...
Machine Is Stuck on "VENTILATE" Command
Sounds like you all have the same problem. Your flow meter has been obstructed with a small chip of coffee bean that got into your water tank receptacle when your tank was off. You need to remove the top or back depending on your machine and remove the flow meter. It twist apart. The intake is a small opening and that is creates the jet of water that spins the flow meter. If it gets obstructed the meter doesn't spin and you will get the ventilate message.
Dec 05, 2007 | Saeco Vienna De Luxe Espresso Machine
Saeco Easy Espresso Machine Logo
53 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
