SOURCE: Canon Fax L100 - toner required even though not empty
hi
first do use the original toner if no use the original toner if yes check the toner cartridge may could be brocken ore the toner jammed on it if its ok you have to check the toner sensor that located in side the fax m/c under the toner cartridge may its came out of position .
thanks
SOURCE: Canon L100 fax machine
Just flip the little key cover open on the right hand side of the machine then press "Data Registration" then press "Set" then press "Set" again this will put you on time & date setting if you press "Set" a third time you can now change the settings using the arrows to step around and the numbers to change the settings. Just press "Set" when finished to save your setting & press "Stop" to exit programming mode.
SOURCE: SCan Platform
Lift the cover covering the recieving paper!If u look in here u will c a black handle with a greenish sticker on!Pull that down gently and push it up again untill it clips into place!Good Luck!
SOURCE: Canon Fax L100 has Comm Error. Seems to re-appear
evry time press red button to clear it. It means that there are interferences in send or recive. Check your tel. lines.
SOURCE: error code e100 on canon laser fax L100
E100 means that you have laser trouble, probably laser pcb is bad. Replace it.
But also check the laser shutter.
