My gateway m-6847 does not turn on at all. no lights turn on. the ac adapter light turns green when plugged in the outlet, so that is not the issue. even if i try to charge it, nothing happens. It's just dead!!! any suggestions will be appreciated.
Hi
silly question sorry
but have you charged the battery or plugged the power cord into plug and switched on to try to charge the battery for a couple of hrs without using the laptop
Insert the installation CD that came with your wireless keyboard set into your computer's CD-ROM drive.
Use the CD to install the drivers for the wireless peripherals.
Insert batteries into the keyboard .
Use a screwdriver to remove any screws that hold the battery bay covers closed.
Connect the wireless signal receiver to your computer.
Receivers for wireless keyboard and mouse sets usually use a USB connector.
Your computer will automatically detect the receiver.
Turn on your keyboard if the devices have power buttons.
Press the "Sync," "Connect" or "Pair" buttons on the keyboard , depending on your model.
If present, press the "Connect" button on the wireless signal receiver as well.
Your wireless keyboard set is now connected.
hope this helps
You can also use the Xbox 360 Play & Charge Kit or the Xbox 360 Quick Charge Kit to power the controller. Learn more about Xbox controllers and chargers.
To connect additional controllers, follow these same steps again. You can connect up to four controllers to the console. Each connected controller is assigned a position that corresponds with the lighted sections that appear around the console's power button and around the Guide button located in the middle of each controller.
