Question about Video Game Consoles & Games
Some gamrs don't play
My dreamcast won't play a few of the games i have. i have heaps of games, and they all play perfectly, but there are a few that don't. they either don't load at all, or load up to the first level, but then reset back to the dreamcast screen, like there is no disc in the dreamcast. there are no scratches on the cds. is there a reason why this is happeneing?
just a note, my system is PAL, and the games i am having trouble with are also PAL. i have NTSC games as well and they all play fine.
  • 83 Answers
Hi friend how are you
You Need In This Probleme
The Bios Cd
For Play In Dream Cast :
(ps1,ps2,neogeo cd,.......)
And You Can !!!!!
Rate This sOluTioN ????
Posted on Aug 22, 2008
    Problem Solver:
  • 12 Answers
There are a few reasons for this problem.
1 - The laser may need adjustment.
2 - the game disk is damaged or dirty (Clean the game disk)
3 - the internal connections are dirty or oxidized.
# 3 is a common problem fairly easy to fix.
So do this first.
As Dreamcasts are used and they age, internal connections become "stressed".
If you have the ability you might try this.
All it requires is a phillips head screw driver to fit the screws (outside and inside), and a small piece of fine sandpaper 1 inch x 3 inches (Rolled around a soda straw or similar shaped object).
Flip the console upside down.
Remove the 56k modem from the side of the console.
You need to remove the 4 screws that hold the cover on, (and one of those screws is hidden by the modem).
After the screws are removed flip the console right-side up with the CONTROLLER PORTS FACING YOU.
Lift the cover straight up and off the case bottom.
Looking into the console, on the left side you will see a circuit board.
On the circuit board on the uppermost left there is a white plug.
Depress the little lock tab on it to release the plug so you can pull it up and off.
Near that plug is a brass colored screw.
Remove it.
There is an identical looking screw located toward the controller end.
Remove that also.
On the left side of the circuit board there is a white colored retaining tab that secures the board in place.
Slightly bend the tab away from the board while you lift the board up by lifting on the A/C power plug socket (where the A/C cord from the wall goes in).
Don't lift too far, just enough to get past the retaining tab (you don't want to break anything.)
Now, lift up the end nearest the controller board.
(There is a 6-pin connector with 6 vertical pins that you have to lift up and off the 6 pins).
Lift the circuit board straight up and off.
Set the circuit board aside.
Now, the 6 pins have been exposed.
There may be "wear marks" on the sides of the pins and you MAY be able to see where the connector was contacting them.
You need to use the FINE sandpaper to burnish the sides of the pins to resurface and clean away any oxidation where the plug made contact.
Don't overdo it, just enough to clean the contacting surfaces.
After the sandpaper, SLIGHTLY push the 6 pins backward toward the rear of the console.
DO NOT BEND the pins, just a bit of pressure is required.
Replace the circuit board STRAIGHT DOWN onto the pins until it is secured in place by the retaining tab on the left side.
Replace the screws.
Connect the plug.
Replace the top cover to the case bottom.
Re-attach the modem.
Plug it in.
Turn it on.
Your games should now all work.
I have done this on several consoles, and IT WORKED!
Good luck.
Post your success/ results here.
Posted on Sep 06, 2012
It will play music, but not the game. it keeps going back to a screen with four icons on it. It says game, music, memory and settings. Every time i back out of one, the disc starts spinning and a Sega...
Looks like your Dreamcast can't read the game properly either due to damaged disc or the dreamcast GD rom is not working properly. try recalibrating the GD rom using this guide:
Aug 28, 2010 | Sega Dreamcast Console
It will freeze in the middle of game play a some games not play
I believe your device is overheating, you need to make sure that the Dreamcast is well ventilated, don't set it on a carpet or enclosure. BLow any dust from the unit, pull the Dreamcast out of whatever nook it is sitting in, and set it on a flat surface like a hard cover book, etc. See if your issues resolve themselves.
Apr 08, 2010 | Sega Dreamcast Console
Dreamcast "please insert disc"
I noticed you said and I quote "a copy of an original game in chinese" you did say chinese right? Is it possible that the system you have may be a PAL system if so that means it's not a USA Region console meaning it won't play Region 1 USA games just PAL
Jul 01, 2017 | Sega Dreamcast Console
Dreamcast wont read games more detailed problem
you need to replace the hdd[hard drive]
Jun 20, 2009 | Sega Dreamcast Console
Freezing problem with Games
The Dreamcast is no longer supported because it was to easy to copy the games, but there are still a loyal few who keep the scene alive. I have no idea how much you want to put into fixing the problem, but the only way to fix your problem is flashing the Dreamcast BIOS.
Modification 101:
The Dreamcast is basically a computer; with the right programming you can do anything; and having a Dreamcast Keyboard is nice.
Other links you should check out...
DreamChip and 4 in 1 Connector
Another Dreamcast Mod Chip
The Ultimate Dreamcast Survival Guide
Sega Dreamcast VGA Mod
Modified Dreamcast BIOS
Nov 27, 2008 | Sega Dreamcast Console
Dreamcast just resets
hey man this is the best soloution
Oct 16, 2008 | Sega Dreamcast Console
Some Dreamcast games won't play
oh that problem.. leave it coz some of the PAL games are really a trouble .. better leave them coz they wont work eventhough you try it a million times.. n.n
Aug 18, 2008 | Sega Dreamcast Console
Dreamcast turned off when there's a disk in it
madarchod band kar de ......from ayush yadav lps lko
Apr 08, 2008 | Sega Dreamcast Console
Sega Dreamcast console problem
First off, NEVER store a game console on top of a subwoofer. It is like a giant magnet, and electronic devices do not handle magnetics. I don't think i've ever heard of a VGA box, Sega brand or not, killing a console. Millions use aftermarket AV cables and adaptors on all consoles without problem. I think it likely died from being on top of the sub. Relocate it and you should be fine. Running it for a few hours isnt likely either unless you had the vents entirely blocked.
To the guest who's drive isnt spinning, I would say your drive motor has burnt out. This doesn't indicate a defect in Dreamcasts, per se, it just means bad luck or excessive dust which killed it. Either buy a different Dreamcast or see if you can find a drive replacement.
Hope this helps.
Feb 28, 2008 | Sega Dreamcast Console
Dreamcast Loading problem
you can get disks relayered at game stores.
there was a long period where this happened to me.
some games worked for a while, some didnt.
its the dreamcast.
you might wanna get anew power cable or just clear out the dust because that is the main problem with the dreamcast.
try playing with the console upside down
it sounds crazy but it worked for me.
Dec 18, 2007 | Sega Dreamcast Console
Video Game Consoles & Games Logo
1,099 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
