Question about Lexmark X6170 All-In-One InkJet Printer
Printer won't print-says color cartridge is missing and it is there
My printer is telling me the color cartridge is missing and it won't allow me to print. I have tried taking it in and out and it does not help. Keeps saying color cartridge is missing. I need my printer---help. Thank you Julie
  • Anonymous Oct 02, 2008
    We are having the same problem. HP Officejet keeps saying "cartridge is missing" but it is not. We have restarted the printer, computer, etc... Cleaned the cartridge contacts, etc... Nothing is working.
  • Anonymous Dec 24, 2008
    I've cleand the cartridge, turned the printer and computer on and off again, and I still get the same message "color cartridge missing" what is the deal?
    Sergeant:
  • 390 Answers
With your lexmark, the printhead is separate to the cartridge, so you can try cleaning the printhead on the printer with correct pc cleaning fluid and a cotton bud (Q tip is us) see if this helps. It will not hurt to use a wet wipe (baby wipe, not perfumed) and gently clean the gold contacts (points) on the cartridge where it goes into the printer. Post back if no good. For the hp, i believe hp's have the printhead atattched to the cartridge itself (i do not have as much info about hp's) and as you have tried cleaning already (assuming you cleaned as above) you coukd try uninstalling and reinstalling printer. Post back if you nees assistance in this.
Posted on Oct 28, 2008
2 Suggested Answers
SOURCE: printer won't print-says color cartridge is missing and it is there
Call Lexmark. I am having the same problem with my lexmark 2470 and I called their customer support. They are sending me a new cartridge as the cartridge that I have installed may be dried up.
Posted on Dec 18, 2009
Dell printer won't print
It may have a date code ill not allow you to print without updating/replacing the cartridge. I got rid of hy HP for the same reason.
Jun 03, 2017 | Dell AllinOne Multifunctional (v515w)...
My Pinnacle Pro 901 is set to print using black ink only but it keeps telling me I need to replace color cartridges and won't print.
You won't be able to print if one of the cartridges is out of ink. The printer needs all cartridges with sufficient ink levels to prevent damaging the printhead.
Every time a cartridge is replaced, all colors are primed simultaneously thus the need for all cartridges to have ink.
Oct 25, 2012 | Lexmark Pinnacle Pro 901 All-In-One Inkjet...
Hello. How do you clean the cartridge as it is a little dried up for printer HP PSC 1210 all in one printer?
Ink is a lubricant for the print heads. Some color ink is used even if you only print in black or vice-versa. If you printed with a color missing, you could destroy that print head from the friction of running without ink to lubricate it. That's why most printers won't allow you to print with a color missing even if you aren't using it.
If you allow a color to go empty, the residual ink in the head could clog and become permanently blocked. You would never be able to print that color again. So always replace ink cartridges as soon as they are empty.
The best solution for you is to buy some isopropyl alcohol from chemist, which is a great solvent for dried ink, and drop 8-10 drops into the ink nozzle, put it back in and try running a few prints then repeat the process. If it doesn't help, you will be better off buying new ink cartridges.
Jan 05, 2011 | HP PSC 1210 All-In-One InkJet Printer
I don't have black ink is there a way to print with just using yellow, cyan, and magenta
Ink is a lubricant for the print heads. Some color ink is used even if you only print in black or vice-versa. If you printed with a color missing, you could destroy that print head from the friction of running without ink to lubricate it. That's why your Brother printer won't allow you to print with a color missing even if you aren't using it.
Jan 05, 2011 | Brother MFC255CW All-in-One InkJet Printer
5200 ERROR SHOWS UP AND WON T LET ME PRINT. WHAT DO I DO?
1. With the printer turned on, unplug it
2. Open the top and bring the ink cartridge holder to the middle
3. Raise the grey bar and remove the print head assembly with the cartridges in it
4. Lower the grey bar with the head missing and close the top with the head out
5. Connect the power, wait till the printer wakes up
6. It will tell you to put in the cartridges
7. Restore the print head, close the top and the printer should start working
Sep 20, 2010 | Canon PIXMA MX330 Multifunction InkJet...
Hp psc 1210xi- the black ink cartridge appears to be out- i have a good color cartridge-how do I get the error off of my printer and print with my color cartridge?
  1. Take out the black cartridge once you've determined that you are completely out of black ink. You'll have to rely on the dark hues from the color cartridge to print in black.
  2. Adjust the printer software settings. Once you take out the black cartridge, your printer's software will typically warn you that you are missing a cartridge. Follow the instructions for your printer to allow the printer to print without the black cartridge. Then set the printer to print in black and white, not color. This overrides the black cartridge and allows the printer to access the dark hues of the color cartridge.
  3. Print a test page to ensure that your printer now prints black using the color cartridge.
  4. Print your documents. Bear in mind that your documents may not appear as black as normal. Still, they should be dark enough to pass for black, depending on how much color ink you have and the strength grade of the ink.
Sep 29, 2009 | HP Office Equipment & Supplies
My printer is not printing. it will run the paper
I see you don't have much knowledge about printers. It always helps to know something about your printer. It seem you have a color printer. Usually a color printer has two cartridges. Black cartridge and color cartridge. The color cartridge usually contains three colors; cyan, yellow and magenta. If the black cartridge is empty, you won't see black text in the printed paper. Print a small photo and see. If it has all the colors, but looks dull (without proper black color), that means only the black cartridge is empty. If it is greenish, the magenta ink is missing. Generally orange colored printouts suggest cyan is missing. Likewise, purple color means the yellow ink is missing. If you installed the printer properly using the CD from the printer manufacturer, you will be notified when the cartridge is empty or close to run out of ink. But if Windows automatically installed your printer, then the system won't give such information. From the information you have supplied, I believe your blck cartridge is empty or missing. Oh, I almost forgot to say, some manufactures sell some printers (for example some Canon Pixma models) with only the color cartridge. Switch on the printer and open the printer cover. The cartridges will move to the middle. You can check whether the black cartridge is missing. Do not hesitate to contact us for further help.
Aug 13, 2009 | HP Office Equipment & Supplies
Just a shot in the dark, was it a refilled ink cartridge. I know HP has a problem detecting the remanufactured cartridges from time to time. And too, if it is not refilled cartridge perhaps you just have a bad cartridge.
Oh, of course Julie remembered to pull the tape off of the bottom of the ink cartridge, correct?
Hope this did some good, please leave rating,
thank you kindly.
Apr 27, 2009 | Lexmark X2470 All-In-One InkJet Printer
Dell 962
Just found this partial fix: "Try removing the color cartridge and try printing with the color cartridge out. If it gives you a message that the cartridge is missing, it will still allow you to print by clicking "continue". And from there, it will allow you to print black. I think it really is a problem with your color cartridge." From searching the net, this seems to be a major problem with no solution from Dell!
Feb 14, 2007 | Dell 962 Photo All-In-One InkJet Printer
Lexmark X6170 All-In-One InkJet Printer Logo
382 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
