Question about ASUS A8M Notebook
Installation cd damaged cd need new copy
  • ASUS Master
  • 3,051 Answers
What cd are u looking for the operating system or what kind please inform me so i can give you some more assistantce ok best regards mike
Posted on Aug 22, 2008
  • Michael Thomas
    Michael Thomas Aug 22, 2008
    xp me win 2000 please inform me ok best regardds mike
WHAT IS .NTLDR .WIN XP HOME
NTLDR is the file that loads the OS. (It expands to NT Loader - all versions of Windows from WIN NT (Win2K) through XP used this file.) The message could indicate the ntdetect.com is damaged.
First make sure that you do not have a non-boot disc in the floppy or CD drive. Similarly, if your computer can boot from a USB device, unplug flash drives or other USB drives. Make sure that your boot device order is accurate (your C: drive should be first) in the BIOS. (Accessing the BIOS depends on your computer, often you need to repeatedly press F1, Esc, Del, or F10 after turning on the computer. There should be a screen that shows you the correct key.) While you are in the BIOS, make sure that your hard drive is recognized by the machine. If your hard drive isn't recognized, try replacing the data cable with a new cable and switching power connection cable with another from the power supply.
If the hard drive is present, the first solution is to get a bootable CD and copy the files back to your C: drive. You can use a Windows XP install or upgrade disk. For this type of source. Boot to the CD (press any key) and then enter the Repair option (R). Choose your Windows installation and enter your administrator password. Then copy i386ntldr and i386ntdetect.com from the CD (D: or E: drive) to the C: drive. (for example: type "copy d:i386ntldr c:" without the quotes )
The boot information (MBR) could be damaged. In that case, the you'll need the Windows CD to run fixboot and fixmbr from the Recovery Console.
If the above doesn't work, you should try a new hard drive and copy the files to it. Make sure that you format the drive to create a bootable disc. (Use a bootable diskette, if needed.)
I hope this helps.
Oct 28, 2013 | Computers & Internet
Hello i have a bmw with a 6 cd auto changer fitted in the boot i think its a factory installed alpine , but it skips when the car goes over a small bump . ive been told the laser has been damaged by...
Copied cd's can't damage this part. The pick-up of this changer can't be repaired, it should be replaced as a whole part. Also please check a position anti-shock system (two mechanical parts on sides of the unit). It must be set in the same position as the changer is installed.
Jul 12, 2011 | Alpine CHM-S620 6-Disc CD Changer
Hi guys i am facing problem while trying to install or even boot from CD or USB, my problem it's when i press any key to boot from CD i just get blank screen and i thing the laptop is stuck. Please...
Ok so I'm guessing it's detecting it's a bootable CD since it is prompting you to "press any key to boot from CD" right? If it goes to a blank screen after that and doesn't go any further, I would think it's 1 of 3 things.
1, the CD you are using is bad or damaged. Try a different bootable CD or try to burn a copy of that one and try with the new copy.
2, Could be a memory issue. If you have multiple sticks of RAM in your computer, try removing 1, testing, then the other (while replacing the first one you removed).
3, Your Hard drive could be corrupt or damaged. I would first try wiping it clean with a program like Darik's boot and nuke (http://www.dban.org/). THIS WILL DESTROY ALL DATA ON THE HARD DRIVE. Then try to re-install again.
Jun 24, 2011 | Computers & Internet
I HAVE PROBLEM ON BOOTMGR MISSING TO INSTALL NEW WINDOW HOW CAN I HANDLE THAT
The boot manager missing? Well u either have a rogue copy of an OS or the one u have is damaged. Either way u need to get ahold of a new cd and go from there.
Aug 13, 2010 | Compaq CQ60-206US PC Notebook
I want to install new software from cd but my system show a "nsis launching installer" error how can i fix it?
If you are receiving this problem from an installer located on a disc or other media besides the Internet, then the problem may be due to a hardware failure or more likely the physical media being damaged.
Installer integrity check has failed. Common causes include incomplete download and damaged media.
Best is to get another copy of the CD and install the software you needed.
Regards
Jun 22, 2010 | Computers & Internet
ZT Group CISNET A7022 disk read error
how are you installing it ?? boot from cd ?? or from a image or ??/if its from the disc..and its blocking ..and do not continue to copy files..the problem is the disc...its damaged ...if you want a copy look for me on yahoo ...catalin_yo_vlad I will provide you a image copy ..with a serial no that will be rec as original ...ad up-datable to sp3
Aug 01, 2009 | ZT Group CISNET A7022 PC Desktop
Windows XP installing problem
Your harddisk has some bed sectors.
U have to go to delete all partrition then turn off the computer then again boot withwinxp disk
then create new partrtion then format ntfs quick
then it error not comes.
Jun 07, 2009 | Intel P4 System Configurator (P4SDRAM1) PC...
Cd rom damage i need a copy of the cd installation
Hey there mate,
Heres the whole CD From: Extreme Computer
site: www.extremecomputer.net/m50/M50CD.ISO
Download that. It's an .iso file, which is an image for burning to a cd. You can use a free program call ImgBurn to burn it to a disk.
You can get ImgBurn from:
http://fileforum.betanews.com/detail/ImgBurn/1128426215/1
When you have burned the disk, just put it back into the drive and it should work.
Have a nice xmas!
Chris (ziraffa)
Dec 19, 2008 | Sony Handycam DCR-HC28 Mini DV Digital...
If you can send me your address. I can make you a copy and mail it to you
Jun 11, 2008 | Panasonic Palmcorder VDR-M50 DVD Camcorder
Distorted noise in cd's loaded into I-tunes
Are your cds dirty or damaged? If they are in good shape then I agree and you should replace it.
Mar 05, 2008 | NEC Versa LX Notebook
ASUS A8M Notebook Logo
27 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
