Question about Kirby Vacuums
Belt for kirby 2000 g limited edtion - Kirby Vacuums
I have troble resetting the belt on my Kirby 2000 vacuum cleaner
Posted on Oct 04, 2008
SOURCE:
Why would the belt burn on a kirby
The belt could be old and worn out. Or if you have a high pile carpeting or fibers wrapping around the brushroll, these cause friction and when it gets hot enough it will melt either brushroll ends or belt. You can limit this by removing the brushroll and removing the fibers and hairs that wrap around the brush. You can also find a new belt here.
GoodVac.com Technician
www.goodvac.com
1-800-775-6586
May 21, 2014 | Kirby Generation 3 Bagged Upright Vacuum
I have torn my file cabinet apart, and cannot locate my manual for my Kirby 2001 Limited Edition. I am trying to replace the belt, and need the manual in order to do so.
Kirby models are all very similar. The only manual I've been able to locate is for the G6. You can download or print it from the below link.
http://ubermanuals.com/search/contentsearch/kirby
Or check the belt change video at the following site. I recommend making this site a favorite for easy access to these videos.
http://www.kirby.com/Portals/0/videos.html
Mar 13, 2011 | Kirby G4 Bagged Upright Vacuum
How do I change a balt on a kirby G 2000 Limited Edition vacuum cleaner
Here is a link to a video showing how to change the belt on a Kirby http://www.totalvac.com/videos/kirby-vacuum-cleaners-videos.htm
Sep 08, 2010 | Kirby Ultimate G Bagged Upright Vacuum
I need to know how to put my belt back on my kirby 2000 G6 vacuum belt
Greetings from GoVacuum,
Here's a very informative video that we've recorded explaining in detail how to correctly install the belt on your Kirby Generation vacuum cleaner. I hope this will help you.
Kirby Belt Change Video;
If this video was helpful, please be sure to rate this Solution by clicking on the 4 Thumbs Up icons in the top right hand corner of the page. If you have any questions, please feel free to email me, I'm more then happy to answer any questions you may have.
Chris Jones
GoVacuum.com
Mar 02, 2010 | Kirby G6 Bagged Upright Vacuum
Dont know how to put the shampoo system together on my kirby g6..
http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
Copy and paste the above link to the address window of your browser for the Kirby Shampooer instructions.
Hope this helps :)
And thank you for using Fixya!!!
May 02, 2009 | Kirby G6 Bagged Upright Vacuum
REPLACING BELT KIRBY CLASSIC III
http://geeksquad.fixya.com/ThreadView.aspx?prdid=11562&thid=806061
Posted by JETALBOT on July 19, 2008
I CAN'T REPLACE THE BELT ON THE CLASSIC III (KIRBY). CAN YOU HELP ME? ELAINE
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The belt install on a Kirby is to raise the height adjustment to the highest level and then dial the belt off counter clockwise so it is loose and not on the fan pulley, release the top lever on the bell housing, then remove the bottom plate and unhook the brushroll on one side, slide the old belt off and then slide the new one on, replace the brushroll with the screws facing the carpet and re-hook the bottom plate on the Kirby. Then take the bell housing and hook that back on to the Kirby and lock it down. Then dial the belt on clockwise all the way and the belt should be on the fan pulley. The belt should be ready to go, plug in your Kirby and then do the step down on the vacuum height adjustment until the tone changes, then try to see id it picks up, if not go one more height adjustment and that should be the correct setting.
http://kirby.com/
Customer Service – U. S. & Canada
1-800-494-8586
Hours 8:00 am to 5:00 pm (EST)
Mail To: Consumer Relations
The Kirby Company
1920 West 114 Street
Cleveland, OH 44102
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 19, 2008 | Kirby Heritage II Vacuum
I need to replace the belt on my kirby g6 2000 how do i do it
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=688060
Generic problem for all Vacuums
Posted by shawn81 on Jun 20, 2008
I need to replace the belt on my Kirby g6 2000 how do I do it
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The Kirby has a belt hook on the inside of the bell housing and 1st you need to release the old belt by turning the dial in front of the bell housing counter clock wise to get the old belt off. Some Kirby vacuums the entire bell housing comes off and makes it fairly simple but the process and the format to change the belt is the same. The brushroll has screws on each end and the screw heads need to be facing down on each side, so remove of drop down one side of the brush and slide the belt onto the middle of the brushroll then re-insert the brushroll, screws head facing down, then use the Kirby dial to hook the belt and then dial the belt onto the Kirby fan pulley and then you should be done. If you have further questions please feel free to contact your local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://kirby.com/ Customer Service – United States & Canada 1-800-494-8586
Hours 8:00 am to 5:00 pm (EST) U.S. & Canada Fax # 1 (216) 529-6146
Mail To:
Consumer Relations
The Kirby Company
Cleveland, OH 44102
Go Ahead. Use Us.
Jun 20, 2008 | Vacuums
Belt
I don't know where near you, but most local repair shops should have the belts for kirby.
Jun 18, 2008 | Kirby Generation 3 Bagged Upright Vacuum
Replacing brush roller on my KIrby g6 limited edition
You need a new belt. When the green light goes out, that means your brushroll has stopped spinning. Here's how to change it....
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
Even if you just replaced the belt, this guide will help you make sure that you got the brushroll back in the right way.
Hope it helps....
Marci
Dec 08, 2007 | Kirby G6 Bagged Upright Vacuum
Vacuums Logo
182 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Gerry Harvey
Gerry Harvey
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
