Question about Xerox DocuColor 12 Color Copier
Error Code : 6-355
When i on the Machine DC 12 Error Code : 6-355 appears on the screen please help me
    Scholar:
  • 53 Answers
06 xxx on Xerox products {I take it it is a Xerox?} refers to Scan or illumination...does the scan carriage under the glass move up and back a short way? Does the lamp come on? That's your starting point
If the lamp fails to light you could get someone to check continuity of the lamp and the overheat thermostat on the carriage (these are usually a push to reset)
Be SURE to unplug from the power, you can still get a bite from the lamp heater even if switched off!
Posted on Aug 24, 2008
I Have Problem With Dc 2060 error code 10-359 what i do
Open Heat Roll Control Thermistor (the one closer to the middle of the roll).
Jul 01, 2014 | Xerox DocuColor 12 Printer
Error code 55.4k
This error 55.4k appeared in printer hp color laserjet 5550. The following trouble shooting did. Orignally my printer fault is display blank.Then i replace dc board with formatter board. blank is gone dueto new ram.Machine display showed the memory process. but immediatly the error 55.4k appeared on display.The reason for this error is, communication failure between formatter and dc board.The dc board which i was replaced by old type one.Then i found exact same dc board, replaced. Error was gone.Machine came to normal status , working fine.
Oct 01, 2013 | HP LaserJet 5550dtn Printer
Error code 9-342 at start up of Dc 12 xerox printer/copier
change the IOT back side clutch that appear behind the back side of machine which rotates the ITO (black roller in main path of paper) just try with cleaing clutch other wise change it
and remove that IOT back side gear which rotate IOT black roller without that gear u can print
i solve my problem with this methods
Mar 28, 2010 | Xerox DocuColor 12 Printer
Our Canon Image Runner 330S shows error message E014....
is there an error code appear on panel display?
if there a error appear try to reset you may press * key,press 2&8 simultaneously, the select copier then select fuction then clear then error then ok then turn off& on
Jan 04, 2010 | Canon imageRUNNER 400S Copier
Xerox dc 12 error code 9-357
9-357 Black Toner Dispenser Broken.
Dec 19, 2009 | Xerox DocuColor 12 Color Copier
HP Laserjet 5m, appear error code 50...please help.
Error 50 will be a faulty fuser unit or DC controller board. Try replacing the fuser unit.
May 20, 2009 | HP LaserJet 4m plus Printer
Dc 12 ERROR 14-372
14-372 is Machine Laser Code Your laser is ......
and second thing is reset the machine
amitgraphix@gmail.com
Feb 03, 2009 | Xerox DocuColor 12 Printer
Xerox dc 12 copier system faulit 9-354
Hi ,
Sir I am have dc12 mech
its giving error code 9-354.
send me the solution as soon as posible.
Aug 09, 2008 | Xerox DocuColor 12 Color Copier
Error 3-397 Xerox DC 12
Hello, I have a Xerox DC 12 and i receive the error 3-308
Someone can you help me or information about me ???
Thank you.
Feb 22, 2008 | Xerox DocuColor 12 Printer
Xerox DocuColor 12 Color Copier Logo
81 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
