Question about Refrigerators
Dometic RM 2804, freezer is ice cold, fridge is 60 degrees to warm for food
  • 51 Answers
Adjust your temp control on the fins inside the fridge move it down it just slides on the fin. You may need a fan on the back of the coil to increase the air flow depending on the heat outside
Posted on Sep 08, 2008
SOURCE:
Freezer stays cold. Why is fridge part warm?
if freezer gets iced up the fan designed to pass cold air from the freezer to the fridge stops working. The freezer is meant to go into a defrost mode when its trtansducer senses too much ice. If the transducer goes fault the ice builds up. Some fridges use a timer to work this out so it could be a timer fault. Talk to a service man about how much ice the freezer should have for them to sucessfully diagnose the fault. Too much ice may prevent the service man from working out if temperature sensor is working and no ice can prevent him from testing sensor. To get rid of ice you have to trun off the power to the fridge and let it melt.
BEWARE remove food to another freezer and fridge to prevent food going off or getting food poisioning
Sep 17, 2015 | Estate TT14DKXKQ Top Freezer Refrigerator
Kenmore classic bottom freezer refrigeration warm but freezer is cold
I would guess you have just caused a build up of ice to block the air way, which normally takes cold air into the fridge. manually defrost (unplug and wait until the ice goes away) then restart and it should be fine
Nov 11, 2013 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Food not getting cold in the fridge
There are many reasons for that to happen.
Check your refrigerator for a thick build up of ice in the freezer, you need to defrost the fridge.
A poor circulation of cold air will happen if thick build up of ice is not defrost.
Do not block cold circulation with so much food inside, you need to organize it.
Check temp control to lower degrees or high number.
A door gasket leak will cause cold air to flow outside the fridge.
A system tubing clogged dirt inside the copper tubing will also cause it, but this one need to be check by a service technician.
I hope I give you idea for your refrigerator problem.
Jun 26, 2011 | Dometic NDR 1292 Refrigerator
I have a dometic rm 4605 aes fridge in my motorhome priblem is wont work on gas can not hear auto ignition spark when turned to gas works ok on 12v & 240v
G'day I have a Dometic RM4605,184LT FRIDGE, AES what setting on gas would you have the fridge set. Settings are between 1 to 5 for max cold in the fridge I did run the fridge for two hours on number 4 setting but it was still 10 degrees in the fridge and -0 in the freezer.
Thanks
Jan 23, 2011 | Dometic Refrigerators
Have a dometic ndr1292 side,freezer works fridge at 60 degrees
Try to defrost it. unplug fridge and place a box fan in front blowing at it. keep the frigd controls in the midle range as well as the freezer control
Sep 05, 2009 | Refrigerators
My dometic fridge doesn't cool some times but the freezer works
I don't know what type of fridge you have side by side or top mount or bottom mount but what every it is sounds like the air ducts are blocked with ice or the air damper is not working.
Apr 02, 2009 | Dometic NDR 1292 Refrigerator
DOMETIC RM 1350 FRIDGE GET HOT AND COLD
Ok, I realize I'm a little late on chiming in here, is this unit located in a slideout, and/or the top outside vent is in the wall not a roof located vent?
If so then the issue is that there are fans that are necessary to circulate air thru the hot coils. And there is probably a malfuntioning thermostat to turn these fans on/off. I had this issue with same fridge in a Gulfstream motorhome, and the temporary fix was to pull the faston connectors off the thermostat and tied them together with a 12V fuse, and taped it up with electrical tape to keep it from shorting on fridge chassis and parts. Replace the thermostat at your conveniance, as these fans are now running whenever fridge is on, and will run your batteries down if not plugged into shore power.
Mar 31, 2009 | Refrigerators
The refrigerators accumulate ice
the fridge distrubutes cold by air movement. A overstuffed fridge can have trouble. There is a fan that blows a controlled amount of freezer air over to the food side, altho when this goes you usually have frozen freezer and food too warm. Make sure the air is allowed to move.
Nov 29, 2007 | Liebherr Premium CTP 3153 Top Freezer...
Refrigerators Logo
489 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
