Question about SanDisk Sansa e200 MP3 Player
Sansa Media Disc freeze/restart
Everytime i plug my mp3 into the computer it says Connected but then like 2 sec. later the screen freezes and it just goes blank then restarts my mp3.Does anyone know why its doin that?
  • mauzac2002 Aug 26, 2008
    when i connect the sansa e200 the screen works, but when i unplugged the device i cant turn on it.
  • 758 Answers
You can try to reset the device by pressing the power button for about 15 to 20 seconds..if that doesnt work I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
Posted on Sep 02, 2008
Everytime i connected to the pc it freeze and when i disconnected it doesnt want to work
What does your Sansa display on its screen, when it freezes after you connect it to your PC?
Jan 28, 2010 | SanDisk Sansa e250 MP3 Player
Tip
For Version 2 Sansa E200 Series and Version 2 Sansa C200 Series
As you have notice, these version of player will not have the USB Mode / Mode ( FOr Rhapsody Players ) and / USB for sansa C200 series. If you want to have your player detected by the computer as a removable disc drive or as a MSC drive you can perform this easy steps.
For Sansa E200 Players and C200 version 2 Players.
1. Enable the Hold Switched for it to show a red color.
2. Press and Hold the Rewind button the " << " then connect to the computer.
3. Connect the player to the computer and dont let go of the Rewind Button " << " , you will notice that the player would be detected as a removable drsc drive in the My Computer Window.
*For Load Main Image Failed Problems and player Freezing on the Refresh Database Screen will be post later*
on Dec 08, 2007 | SanDisk Sansa e250 MP3 Player
My Sansa E280 mp3 player Keeps freezing everytime I go under my "unknown" section. It says Bad Track for most of the songs in that section and it freezes. Also in my unknown section most of the songs won't...
What I would recommend you to do is to format the device...Keep in mind that formatting the device will delete everything you have in that device....if that doesnt work...go to the sandisk website and download a firmware upgrade for your device...I am sure that will take care of the problem you are having...
Thank you
Computerrep
Feb 24, 2009 | SanDisk Sansa E280 MP3 Player
Songs Freeze up
go to my computer> properties>hardware > device manager >universal bus driver>right click on it> update driver>
then1
1.yes this time only> next 2.choose advanced option>next 3don't search i"ll update from........>next4.click on show campatible> next> next 5. now it updated then restart you computer
Then try to format your drvice sir
your problem will now soved
Feb 05, 2009 | SanDisk Sansa Fuze MP3 Player
Unable to put in music
You probably have your Windows Media Player set up to auto-sync - since this player is smaller than your total music collection, it is too much for both WMP and the Sansa. Disable auto-sync and you should be fine. Windows Media Player 10 is fine. Windows Media Player 11 works also.
-Tha Mp3 Doctor
Dec 23, 2008 | SanDisk Sansa Clip MP3 Player
Freezes after 8 secs (No sound or anything)
I registered my Sansa View in sandisk site, and the support sent to me these two solutions. I have a similar problem like you and I'm still haveing problems but meaby these steps working in your sansa view.
regards
Diego
Nr 1:
Let us update your player's firmware:
Step 1 – Connect the player in Recovery Mode.
1. Turn off the player.
2. Slide down the Hold switch along the left side of the player down so the orange is showing.
3. Press and hold the HOME button and connect the device to the computer.
4. A message will appear on the device display screen confirming the connection and a 16MB partition will be viewable in My Computer (XP) or Computer (Vista).
5. Release the HOME button.
Download and update the firmware.
1. Download the firmware file:
Click Here for the Sansa View Firmware update file
2. Extract the zip file.
3. Copy the extracted firmware files (*.dat, *.rom, *.mi4, and *.fnt) to the 16MB-FORMAT drive.
4. Disconnect the player. This will now start the firmware update.
5. Slide the Hold switch to the unlock position.
6. Turn on the player.
Nr 2:
It appears that this is caused by file corruption in your player's memory. Usually, formatting your mp3 player resolves this FM issue in your player.
Formatting your Sansa View Mp3 player in Disk Management:
WARNING - FORMATTING YOUR MP3 PLAYER WILL ERASE ALL MEDIA FILES IN YOUR PLAYER, PLEASE BACK UP IF POSSIBLE.
1. Make sure the Sansa View is turned on.
2. Engage the hold switch, located on the left-hand side of the player.
3. Press and hold the LEFT BUTTON ( << )
4. Connect to the computer while pressing and holding the LEFT BUTTON ( << ). Do not let go of the left button until the player is detected as Removable Disk.
5. The Sansa View should now be connected in MSC mode and should appear as a "Removable Disk" or "Sansa View".
6. From the desktop, right click My Computer, then select Manage. If you don't see My Computer on the desktop, click on Start and right click My Computer from there, then select manage.
7. On the Computer Management window, click Disk Management from the left pane.
8. On the right side, locate your sansa device on the list (it might be recognized as removable disc), right click on the sansa device, then select Format.
9. On the Format Window, select FAT32 under File System and make sure that the Quick Format option is not checked.
(You might get a warning window about your files being deleted when you format the device, if that is not an issue for you, click ok.)
10. Click OK to start formatting the device. This should start the format process.
11. Once the formatting is done, unplug the device from the computer. Let the device refresh.
12. We can verify that formatting is successful if it shows no files on the player.
Oct 25, 2008 | SanDisk Sansa View 8GB MP3 Player - Black
Frozen
You guys should download the firmware updates and the drivers for it. Here are the links. Firmware Drivers
And if it freezes hold down the power button for about 20 sec. Then it will restart.
Oct 17, 2007 | SanDisk Sansa e250 MP3 Player
No brand-mp3 mp4 player
well this has never happened to me but mine did freeze o all you have t do (this might work) when it is on try holding down the power button for about 20-30 sec and it restarts it. thTS WHAT HAPPENED FOR MINE WHEN IT FROZE FOR THIS PROBLEM IM NOT SURE IF IT WILL WORK but give it a try
May 23, 2007 | SanDisk Sansa e250 MP3 Player
Video trouble
Download latest Quicktime
Oct 01, 2006 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e200 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
