Question about LG VX6100 Cellular Phone
BLANK SCREENS - it's an epidemic
The same thing happened to my phone. The screens started cutting in and out one day, sometimes working fine and sometimes only lighting up but with no display, then in a few days they stopped displaying period. I was looking at the inside screen when it happened - my wallpaper picture zigzagged and flickered, turned different colors and disappeared and left me with a white screen. The people at the Verizon store (why don't they have phone mechanics to figure this stuff out?) surmised that a cable or something in there went bad. Can they fix it? No, they said. "We're not allowed to." Huh? They said I was SOL and managed to transfer my contacts and pictures (which they'd initially said they were unable to do) to a new phone, but I had a bunch of sound clips of my baby before she died and they said they couldn't transfer those. I neglected to email them to myself from my phone, so they're still in there. I'd like to be able to get my screen display back just long enough to be able to navigate in order to send myself those sounds. Can anyone suggest something?
    Problem Solver:
  • 10 Answers
I was able to get mine to work for about ten to thirty mins with a new battery and using a toothpick to spread the charger port parts. The flat one with two notchs away from the black with the gold contacts. GENTLY press toothpick (nonconductive) against the two notchs part and GENTLY wiggle it away from the other. It took 5 snatch sessions to get all my stuff off. I used the battery that came with my LGvx8100 as they are the same. DO NOT CHARGE THE BATTERY IN THE 6100.
Posted on Mar 08, 2009
SOURCE:
Lg xenon touchscreen doesnt work
I had the same thing happen to me. what I did when it started working again was take the back cover of the phone off while it's on and then try pressing the screen.. somehow it started working again for me. then if it works put the back cover back on.
Jul 07, 2009 | LG Xenon GR500 Cell Phone
XO Vision XOD1736
this happened to us also. If it's happening with the lights on, unhook the orange dimmer wire. our would workonly when the lights were off. the second we turned the light on the system would shut off. once we unhooked the orange wire it stopped doing it. we installed it in a 2003 mercury mountaineer.
Dec 24, 2008 | XO Vision XOD1735 Car DVD Player
Computer cuts off
Simply replace the power supply with a working one to confirm power supply problem. If the power supply is the problem than ask your grandson to open the casing of the power supply unit and see if there are bulgy signs on the top of the capacitors, and replace them with the specific ones. This problems may arise because of defective components, it might be best to leave it to the technicians to do the repair. Hope it helps.
Sep 18, 2008 | Computers & Internet
Tv cuts off and green light flashes
Yup, it seems a lamp problem can give a blinking green light over the 10 times (1 - 10 times for diagnostic codes), but in my case rather than replace the bulb if it works for a minute then resets with the green light blinking, do what I did.
Take the lamp out and inspect it, it has breather screens top and bottom, if it cant breath because there clogged with dust, clean them, and you can remove the screens, use q-tips and clean the inside. I saved the cost of a lamp and it's working fine!
Jun 27, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Freezes and displays white screen when starting
hardware fault ..90% chance at pcb level or short circut at the lcd flex cable? needs troubleshooting.
try a firmware update just to check if this is happening due to corrupted software. I dont thing so but there is a small chance..
Regards Theo
Feb 11, 2008 | Sony Ericsson W300 Cellular Phone
Blank Screen
mine does that too, any suggestions? is it the battery or the actual phone because i've tried taking the battery out and putting it back in, sometimes it fixes the problem for about 4 minutes and then the screens go crazy again. help!
Feb 10, 2008 | Kyocera Switchback KX21 Cellular Phone
Nokia 6133 mY screen!!!!!HELP
it not an battery problem check the connections is correct
Jan 09, 2008 | Nokia 6133 Cellular Phone
Sanyo phone cutting off
I've seen this happen with corrosion that damaged only the calling part apparently. If you're not inssured you can open it up and look for it, should be visible. If you want to clean it, don't use any solvents or non distilled water. an eraser works sometimes. Good luck
May 15, 2006 | Sanyo SCP-200
LG VX6100 Cellular Phone Logo
215 people viewed this question
Top LG Cell Phones Experts
William Norris
William Norris
George Etukudo
George Etukudo
Sheldon Dedek
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
