Question about Magic Chef CTF2125 Top Freezer Refrigerator
Magic chef refrigerator
The top of the freexer works good but the bottom of the frigerators is hot can it be fixed or is it trash.
Dislocated hose
Posted on Aug 24, 2008
My magic chef mcbr445s will not cool down the compressor NSA30la cg stays hot what should i change out
check the condenser fan if working good or clean you condenser unit use water from faucet
Feb 24, 2011 | Magic Chef MCBR445S1 Stainless Steel...
Who manufactures Magic Chef refrigerators
google "magic chef" trademarks you may be supprised.(haier IS THE WORLDS LARGEST MANUFACTURER OF WHITE GOODS IN THE WORLD......MADE IN .......CHINA....)
tata make the worlds cheapest NEW car 1500 dollars
pre tax......made in india.
Jul 04, 2010 | Magic Chef CTB1821AR Top Freezer...
Magic Chef Ref top freezer Hot to touch outer cabinet and side of cabinet front four or five inches
Good day,
It should be warm, but not hot. It uses what is called a Yoder heater to prevent sweating, but ...........
If too hot, go to back bottom of refrigerator, and remove cardboard cover, and see is cooling fan motor for the box condenser is running. If not, replace.
Also, that box condenser can get very dirty.
It cannot be vacuumed out. You must blow it out.
If you have no access to a compressed air tank and hose, a good substitute is a good push/pull shop vac with a crevice tool.
Don't delay fixing this. It could destroy the compressor.
Thank you for using FixYa
Jan 22, 2010 | Refrigerators
Just bought magic chef ctf2124ar fridge. cannot
Not a bad refrigerator I work on them for a living they have put out decent products in the past. Magic chef was made by maytag in they past probably a wpl made product now. Its probably got a calrod defrost heater and an embraco compressor two good things to have. Stick with it.
Jan 22, 2010 | Magic Chef CTF2126AR Top Freezer...
Loud buzzing noise on a Magic Chef compact refrigerator help!
Disconnect power from unit. Remove the cover at the bottom, rear. Examine all refrigerant tubing for contact with other tubing or other surface. Carefully adjust the tubing to prevent contact vibration.
Sep 12, 2009 | Magic Chef CTB1821AR Top Freezer...
Magic Chef Mini-Fridge not Working, Model # MCBR360S
Unplug and look for the thermostat control. Try jumping the thermostat wires together. If it runs then replace the thermostat. Also feel the compressor to see if running, they run very silently. Thanks, Sea Breeze
Apr 27, 2009 | Magic Chef MCBR440 Compact Refrigerator
Freezer works great, but the bottom takes for ever to cool
Hello. Your question didn't post right. All it says is "Freezer works great, but the bottom takes for ever..." Can you clarify.
Dec 05, 2008 | Magic Chef CTF1826AR Top Freezer...
Magic chef fridge #ctb1722grq
Behind the panel in the freezer there is a drain hole that is underneath the evaporator.  It is frozen over.  Take the back panel off and get all of the ice out and run hot water down the drain until it is clear.  When the unit goes into defrost some of that ice melts and drips down thru the vent into the fridge section.
Oct 20, 2007 | Frigidaire FRT17G4B Top Freezer...
Magic Chef CTF2125 Top Freezer Refrigerator Logo
109 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
vince
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
