Question about Kenmore 25842 Top Load Washer
Drum won't spin
Everything else works fine how do I repair the spin cycle?
Thanks for your help
Aaron
  • Anonymous Feb 08, 2009
    everything else works except the spin cycle
Check the lid switch plastic tongue mounted some times front--,,lid right hand side,this is a safety measure switch,when lid is open it disables the spin cycle-------tom
Posted on Aug 22, 2008
I have a Maytag Atlantis that seems to cycle through the steps properly, it agitates but the only thing it will not do is spin. The motor does run while the spin cycle is active, but the tub is still the...
I would suspect your correct, but first check the belt and make sure the belt tightens for spin. Its possible the the belt is too glazed to grip the pulley to spin. The other thing is noise, this is common for this model, its a dry brake system like a car, brake dust collects in the drum and causes this, if you change this is comes back, same for if you clean it. Aaron, remove the front panel, check the large center pulley, turn one way to release the brake and the other to wash. Check this first before changing anything. Good Luck
Aug 09, 2014 | Washing Machines
Hotpoint aquarius wml760 noisey when spinning with stuff in but ok empty
more than likely the rear bearing has gone bad and when a load is applied the difference in weight distribution causes the knocking.
Jun 15, 2012 | Hotpoint Washing Machines
Why is my Miele Novotronic w1512 saying Drain fault?
I have the same problem, i have cleaned the filter area and there was a plastic sweet wrapper in there also. However, I have put the machine back on an express cycle ans still have the error message coming up?? Drain Fault! I then tried to spin and the spin cycle wasn't working eithet. Whilst the machine was still on i patially undone the filter cap and removed a full tray of water, it then began to spin. What could yhe problem be?
May 21, 2012 | Miele Washing Machines
My washer won't spin on spin cycle
Hi rapwizz,
I believe your drain pump filter is just clogged. The drain pump is trying to pump the water out before the Spin cycle, but can't. Usually this is caused by a foreign object that is obstructing the impeller. See my tip on how to access, drain & clean the Drain Pump Filter:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER
After this, the Spin cycle will run, after the drainage procedure. If it does not, then you may need to replace the Drain Motor. Which is a easy task.
Kind Regards :-)
* If this solution helped you, please rate it
Jul 18, 2011 | Whirlpool Washing Machines
My washer, A612S, does everything correctly but SPIN in the spin cycles. Both belts underneath are fine. The motor pulley spin fine when in the spin cycle, but the belt doesn't. When I turn it off...
the brake it the drum directly above the transmission pulley it is not intergrated into the trans.
in my almost 30 years of repairs in that old and very reliable machine i would find where a article of clothing and floated over the inner tub and has wedged itsefl between the inner and outer tub, their is enough clerance between the tub and tub cover where you could get finger into it and run it around the tub and feel if a piece of clothing is caught. if that isnt the problem then the tub bearing is ceased up and would require repalcing it and the tub seal
Jul 18, 2011 | Maytag Washing Machines
I've got a 4 yr old Roper electric dryer that won't start up. The belt is fine and the drum spins freely. When you push the button to start it will hum but won't turn the drum. I've got...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 03, 2011 | Roper RGX4634KQ Gas Dryer
Have a front loader the drum will not stay turning for each cycle
sounds like the motor bushes have badly worn just check or replace them,sometimes they just need taking out and give them a flick with your finger to get rid of the carbon dust build up,put them back on if they are long enough as they really should be showing a good quarter of an inch for it to function rite.
Jul 07, 2009 | Maytag EPIC MFW9700S Front Load Washer
Whirlpool Ultimate Care Model LSR8233EQO - Loud noise during final rinse/spin
Sounds like the clutch, mi9ne works fine but is noisey when spinning, repair guy said it was the clutch.
Feb 05, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Everything is working except the spin cycle
Sounds like the spin coil/brake solenoid is burnt out or broken. This is a coil situated on the motor plate under the machine with a lever attatched to it. When the machine goes into spin cycle, this solenoid pulls the brake away from the outer drum to allow the drum and agitator to spin together. The shaft that goes into this coil should move in and out freely. If tight, replace spin coil/brake solenoid.
Oct 31, 2007 | GE WSKS2060WWH Top Load Washer
Kenmore 25842 Top Load Washer Logo
85 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
