I bought a standard audio/video (red, white, yellow) RCA cable. I also bought a wall-mounting bracket (like a light switch wall mount, if you know what I mean). I didn't realize that the backs of the 3 mounting bracket connecters would expect me to hard-wire them. The bracket has 4 numbered connecters 1 and 2 are blue and 3 and 4 are orange. I cut off the head of my red RCA plug (the Right audio) and I found two wires: a copper exterior wire, and a shielded inner wire. What do I hook to what to make my bracket work?
  • 1 more comment
  • doug_tice Aug 22, 2008
    So what numbers should I plug my wires into? Does it matter as long as I put one in + and one in -?
    I'm guessing I'd go shielded wire to 1 and copper wire to 2 leaving 3 and 4 open. Could I go shielded to 3 and copper to 4 just as well? What about combinations like shielded to 1 and copper to 4?
    Thanks!
    This was helpful, and was almost everything I needed, but I had to post a follow-up question. I hope that gets answered, at which point then, yes, this would have been very helpful!
    Thanks, that is exactly what I needed!
    I am setting up an audio/video "port" on my wall. Because I'm connecting my TV to my DVD by an HDMI cable, I don't even have a use for this port currently, but I'm doing some remodeling (which includes hanging a flatscreen TV on the wall), and now seemed like the appropriate time to get these wires run behind the wall in case I would need them later. I ran electricity to the wall where it is being hung, and I wanted to set a few different types of connectors on the wall also. I have a cable coaxial port on the wall, now I have the RCA (audio/video) as well, and finally I have one generic which I put on the wall to run a HDMI cable and the wiring for my Nintendo Wii. It is going to be sweet!
    President:
  • 624 Answers
I may be misunderstanding you somewhat, but what is this "bracket" to be used for and what is it's model number or identifying information? What type of equipment are you wanting to connect with the A/V RCA cable?
I can help you with this problem if it is explained better. I can not think of any normal installation of any type of audio or video equipment where you would need to cut off the ends of the RCA cables.
Posted on Aug 22, 2008
  • Anonymous Aug 22, 2008
    The information posted by "betz73" is wrong.
    The wires for the RCA cables are as follows: the outside shielding is the negative and the insulated inside copper wire is the positive. The red and white are for audio signals and the yellow is for a video signal.
    Sergeant:
    Champion:
  • 298 Answers
Okay on the bracket # 1 is positive, 2 is negative, 3 is positive and 4 is negative. Now the rca cable The copper wire is negative and the shielded wire is positive. Hope is this helps. please rate. thank you.
  • kristopher betzler
    kristopher betzler Aug 22, 2008
    okay to make this simple, tech48 is using the exact terminology
    the outside braided wire is the "shielding"
    but the inside wire w/insulation (red-white) is pos. the outside braided (shielding) wire is neg.
    now 1-2-3-4 it's best not to mix up the numbers i.e. (1-4)( 2-3)
    just stick with (1-2 )(3-4).
    what exactly is it you are doing. dust so i'm clear on this as well.
    thanks for the rate i appreciate it.
    okay cool so you're wiring the house for theater. fun stuff. if you have and more questions click the askme button under my name.
    and i'll walk you through any thing you may need help with.
    and for "tech48" pre-wiring a room for home theater does requier RCA splicing.
    thanks again.
SOURCE:
I understand about rca cables it's the green plug cable that I don't know where to put it. It doesn't fit anywhere.
RCA refer to the type of plug, the color code is for visual reference:
In standard video in/out:
Red: Left audio channel
White: Right audio channel
Yellow: Composite Videos
YPBPR Analog Composite video:
Yellow (Luma)
Blue (Blue Difference)
Red (Red Difference)
Orange is used for Digital S/PDIF audio.
For a detailed chart of RCA connectors color code:
en.wikipedia.org/wiki/RCA_connector#Color_coding_in_consumer_equipment
Mar 08, 2015 | RCA Televison & Video
How to get video from dvd to tv
Use HDMI wire if you have that option than simply tune TV to HDMI 1 or HDMI 2 etc depending which one you connect it to .
OR. analog ( R C A ) cables analog. Output from DVD player to imput tv """ red is right white. Is left sound. Yellow is video pay attention to where you are plugging on TV.video 1 or 2 or 3 Since you will have to go to ( video. Or imput ) on your TV to access the DVD player. Another words your cable box is a TV imput . You're doing is also a TV imput You have to tune it to be able to watch it
Feb 16, 2015 | Universal 40-42 Inch Flat Screen Panel...
My dynex tv only shows channel not available message?
Okay- the three cables (red, white, and yellow) are called RCA plug connectors. They are commonly used to carry audio and video signals.
Plug them into your Xbox according to the color codes- red cable connector to the red socket (jacks); then white to white, and yellow to yellow.
Now connect these leads to the RCA input jacks in the back of your t.v. - maintaining the same color code connections (red to red; white to white, and yellow to yellow)
The RCA input jacks on your t.v. should be labeled with an input number, to distinguish itself from the other inputs, like HDMI, S-Video, and such.
After plugging in your Xbox to the wall outlet or surge strip, turn it on.
Turn your t.v. set on.
With the remote control that came with your t.v. set, open the menu bar, scroll to... and open the "External Output" menu.
You should see a list of [however many] inputs your particular t.v has. Scroll to the input number that the 3 RCA cables are attached to, and press that number as the default video screen.
Exit the prompts and your Xbox video screen should be displayed.
Nov 27, 2013 | Dynex DX-LCD32-09 LCD TV
II HAVE A 13 INCH BRAND MODEL DWT 1304. I JUST WANT TO USE IT FOR A DVD PLAYER. I HAVE NO REMOTE ,HOW DO I CHANGE THE TV TO PLAY DVD OR VEDIO
Connect the composite video RCA (yellow) cable output of the DVD player to the TV's video input RCA (yellow jack). Connect the red and white RCA cable from the DVD players audio output to the TV's audio input (red and white jacks). Select the source input from the TV's control panel - if it has an input selector switch, set it to select the video source from the front panel input jacks if you connected the three cables - yellow, red and white on the front of the set. Or, change the channel to receive the video auxiliary input source instead of the broadcast station.
Dec 20, 2010 | Durabrand DWT1304 13" TV
Car audio wiring diagram for 94 nissan maxima. it doesnt have a harness so i have to rig it old school. so i need to know what the color of the wires are so i dont zap anything out
1994 MAXIMA
RADIO WIRING
BATTERY RED/BLACK
ACCESSORY BLUE
ILLUMINATION RED/YELLOW
LF SPEAKER(+) BLUE/WHITE
LF SPEAKER(-) BLUE/YELLOW
RF SPEAKER(+) BROWN
RF SPEAKER(-) BROWN/WHITE
LR SPEAKER(+) RED
LR SPEAKER(-) GREEN
RR SPEAKER(+) BLUE
RR SPEAKER(-) PINK
THE RADIO GROUNDS THROUGH THE CHASSIS MOUNTING BRACKETS
Oct 22, 2010 | Car Audio & Video
I bought a Nintendo Wii off of a guy and I didn't realize when I did that it came with Hi-Def RCAs. My TV only has a standard RCA hookup. I was told that I could still use the Hi-Def RCAs but what colors...
Those are not High Def RCAs.
The cables you received are called "component" when the picture is broken down to its component colors, red, green, and blue.
When compared to "composite" cables (RCA), the yellow is all the components in one, which is the video cable. The other red and white are audio.
Your component should be RGB, Red & White (audios)
What you need to do is buy a composite cable for the Wii, which shouldn't cost that much--usually under $10 bucks. Save the component cables for when you get a new TV since those are the more expensive of the two!
Feb 08, 2010 | Nintendo Wii Console
Hi, Just bought a 26" sony bravia tv. I don't use cable or satillite. I just need to find out what kind of cable I need to connect my panasonic DVD player to the TV and which port do I plug it into?
The best quality would be a HDMI cable, if your DVD player has a HDMI port on the back.
Any of the HDMI ports on the TV can be configured to take the audio over HDMI (digital audio) or over a separate rca stereo patch cable (menu option in the TV for analog audio).
So if your DVD has HDMI, just buy a HDMI cable and you're done. If you cannot figure out how to switch the audio input, there is no big harm in just installing a separate RCA patch cable between the two for the sound.
The next-best would be a component-video cable (Red/Yellow/Green) RCA cable, with a separate red/white RCA audio cable.
Alternately, if your DVD has a S-video port, that is comparable to component video. Then you would need a separate audio cable as well.
Last but not least, if your DVD player is ancient, it may only have a yellow video out connection, then red/white for audio. You then just need a standard yellow/red/white RCA component cable.
Oct 23, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Have video w/an S-cable, but can't get sound w/the optical cable
s video is only for video so run an extra set of red and whit rca cables for sound
Mar 15, 2009 | Audio Players & Recorders
I HAVE A RCA TELEVISION, MODEL F20632. I CANNOT FIND THE MANUAL TO HELP ME SET UP MY VCR. I HAVE A 4-PLUG VIDEO CABLE (YELLOW, BLACK, GREEN AND RED). CAN YOU TELL ME WHICH CONNECTIONS ON THE TV I NEED TO...
the yellow rca input jack( not the output one ) is for video in (by itself ) and the red and white rca jack inputs are for the right and left audio that is also required when using the yellow video jack
the red and white audio jacks are also required when using the component video inputs ( BLUE , GREEN & RED ) rca jacks
but only one type of connection is required ( yellow video jack , red and white audio jacks ) or ( the blue , green and red component video jacks and the red and white audio jacks )
you will need the yellow video input and the red and white audio inputs
Jan 05, 2009 | RCA F20632SE 20" TV
53 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
