Question about Sylvania 6427GFG 27" TV
Audio output how do i hook up external powered speakers to this tv?
  • 790 Answers
Hi
you need amplifier to do that!
Thanks!
Posted on Aug 22, 2008
How do i get the external audio output to work?
First make sure that your TV has an audio OUT. Most do not. If you do then you can plug into that but you will have to go into the menu on the TV under audio and turn on the external speaker feature. If you do not have an audio OUT then you will have to hook you speaker to the audio OUT of your home stereo system and hook the source output to the input of your stereo. Source being (dvd, cable box). In that case you need to turn off the internal speakers on the TV and just run it through your home stereo system.
Mar 07, 2016 | Sony KDL-52XBR5 52 in. LCD HDTV
Is there a way to hook up external speekers to my dp32642 tv Ive tried the digital output with powered speakers etc. no luck getting any sound
I guess you tried it in a coacial out female tulip output your spreakers can not decode digital audio you use active speakers this means they got an Amp inside
to get digital out you need a reciever that supports digital in
Dec 12, 2014 | Sanyo DP32642 32" LCD TV 1366x768, 60 Hz,...
Rca tv ..how to hook up to home speakers
Unless the set has actual audio outputs it should not be done.
The set will have a very low audio output not intended for external systems--if you hook to wrong impedance speakers volume either will not work, be very low or even damage the audio circuit in the set
Mar 28, 2012 | RCA 27V530T 27" TV
How can I hook up external speakers? I have
Go to your tv menu, and make sure that your fixed audio output is selected not variable. Variable will make not work, with the television volume is turn down. When you hook the speakers, make certain that it is on a fixed audio out, not variable, as well.
Oct 27, 2009 | Zenith C34W23 34" TV
How do i hook external speakers to sony bravia television
The proper way to do this would be to use the audio output from the TV, either analogue left and right or the optical port, and send it into an dedicated amplifier or AV receiver. You can then use the amplifier or receiver to power the external speakers. If you are using a dedicated amplifier with no volume control you will want to change the audio output setting on the TV to "variable out" as oppose to its current "fixed out"settings. You can find this in the TV menu, usually under the audio settings. This will allow you to use the current TV remote to adjust the audio volume coming out of the external speakers.
Aug 21, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
No Audio when disconnect from external amp and hook to speakers
In a radio like your Pioneer and all similar units there are always a pre-amp circuit that feeds a power amp circuit,In some players there are more than one pre-amp circiuts. It is possible and highly probable that the power amp circuit in your Pioneer is shorted, so you still get some audio output , but very little. I believe this is your problem and I suggest that you bring it to a repair shop for an estimate or replace the unit. Good luck and please rate this answer, Thanks.
Apr 12, 2009 | Pioneer Car Audio & Video
Want to add an external speaker to TV
If you have audio out RCA jacks then you can hook up some computer speakers that have RCA jack inputs. If you don't have audio outputs and your TV has a HOT chassis then you won't be able to do it. If your tv has a switching power supply then you can install a jack to TV speakers, so they disconect when you hook up your other speakers, if you try and hook up speaker to the TV speakers then the impedence will change, and your audio output IC will get hot and short out.
Oct 26, 2008 | Televison & Video
Audio output not working
I had what may have been a similar problem and even talked to Westinghouse to see what I was doing wrong. Woman suggested there was a problem with the audio output port and suggested I exchange tv for another one. When the new one had the same problem, I discovered that to get audio out requires the volume to be turned way up on the tv (set speaker preference to external only if you don't want sound from tv speakers as well). If you have a digital optical connection on both the tv and the home theater, the sound output is independent from the tv setting and is easier to work with.
Oct 04, 2007 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
19 inch LCD TV
Hi, Chances the Audio L/R are line level (can not drive speakers) other than they can either be output or inputs. If they are inputs, they are connected to a source such as a DVD player or if they are outputs, connects to an external amplifier where external speakers maybe connected. hope this be of some help/idea. Post should you need additional information. Good luck and kind regards.
Aug 25, 2007 | Westinghouse LTV-19W3 19 in. LCD...
Sylvania 6427GFG 27" TV Logo
Top Sylvania Televison & Video Experts
matt martin
matt martin
Dave Naylor
Dave Naylor
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
