Dear all, I have a new seagate 1000Ga harddrive, but my existing desktop using hdd cable for my hard drive, please advise of how to install it into my computer. thank you
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 69 Answers
Is it sata 1000g hard disk if *********** board does not sata HDD then you have to purchase the sata card . then you can install in your COmputer
Posted on Aug 22, 2008
Unknown device
Samsung HDD division was only recently sold to Seagate.
"ST" is a Seagate number so your drive cannot be old - manufactured by ex-Samsung factory now part of Seagate.
Utility from Seagate (e.g. Seatools) should be able to display from S.M.A.R.T the number online hours.
Dec 27, 2013 | Samsung HD502HJ Samsung 500 GIGAByTE SATA...
I burned out my external hard drives PCB board and I am unable to find a new one
The Printed Circuit Board ON THE Harddrive inside the Seagate FreeAgent, or the small PCB inside the Seagate FreeAgent's external enclosure? (Case)
If you are referring to the small PCB that the Harddrive connects to, and has the USB cable coming from it, just buy an external enclosure, and install the Harddrive into it.
http://www.youtube.com/watch?v=0HZ-wTdscgc
If your Seagate is like the one in the link above, it has a laptop size Harddrive in it, and it is a SATA unit.
2.5 inches across in width. (2 and a half inches)
This is an example of a 2.5 SATA external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3195233&CatId=2783
IF you are referring to the PCB on the Harddrive itself, good luck.
One method would be to buy another harddrive like the one in the Seagate FreeAgent, and use it's PCB so that you can retrieve your information.
Then reinstall the PCB on the new harddrive.
For additional questions please post in a Comment.
Regards,
joecoolvette
Sep 17, 2011 | Seagate FreeAgent Go (ST910004FAA2E1RK) 1...
Whenever i try to transfer files from my desktop to my system i m find an error .. " the destination you specified doesnt exist , it may an offline device ....." what to do ... :( :(
Maybe your External HardDrive has failed, you maybe able to re-use the HardDrive inside if you can't retrieve files from your HardDrive to your P.C.
If you get no joy using the Troubleshooting Guide then try this...
You will need to check You Tube to find a Dismantle on your product and follow the step guide on here, the procedure should be similar.
Check 1st that your External HDD has an P.C. internal HDD inside, from You Tube, before dismatle of your External HDD.
Once your happy that it has continue reading and follow the step guide on the link below.
My neighbour has the Seagate FreeAgent Desk 500GB, and in under 2 weeks it started to beep and was not reconized by any Laptop or P.C. if this is the same for you with any FreeAgent Desk series ( not GO series, different procedure for GO products). You maybe in luck click this link, you may have to register in the forums to view thread.... http://www.yo-lid.co.uk/forum/viewtopic.php?f=32&t=84 Thread can be found in 'Technical' under 'General Technical Issues'
Aug 23, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Maxtor 3200
Seagate troubleshooting Error Code 10, states that drive has failed. (Seagate bought out Maxtor)
Before you resign yourself to everything is lost on this harddrive, how about trying one more thing?
How about putting the harddrive inside in a new external enclosure, and see if it works? I suggest that perhaps the external enclosure it's in, is bad.
The harddrive inside is a 3.5 inch harddrive. Same width as used by a desktop computer. It is a Sata harddrive.
Here's an example of a 3.5 inch Sata, external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3901268&CatId=2780
Just pop the external enclosure open that holds it now, take it out, and install it into an external enclosure like the example above. Plug in the USB cable.
Don't know if this applies to your particular Maxtor Personal Storage 3200, but when I went to search for the type of harddrive it uses just now, I ran into thsi, and thought I would pass it along. http://www.seagate.com/www/en-us/support/downloads/personal_storage/ps3200-sw)
May 10, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
New hard drive wont work..Help!!!
make sure that the jumpers are in the right place
Apr 13, 2009 | Computers & Internet
Trying to copy harddrive to another harddrive. want to move to larger drive. problem is optiplex gx260 convertible desktop only shows 1 harddrive in my computer. only a c drive shows up. the secondary...
To clone a disc , acronis true image home is a very good software . A free software based on it is available from seagate called as disc wizard but it will only work with seagate drives. about hard drive not being detected , try upgrading your bios . Some bios dont detect new higher capacity harddrives. Do tell what is your drive capacity.
Mar 21, 2009 | Dell OptiPlex GX260 PC Desktop
Emachine T5026 installing a new hard drive.
place the harddrive over or under the old drive.
a IDE cable most be connected to the harddrive and to the motherboard.
and a 4-pin power cable most be connected.
CS.
May 18, 2008 | E-Machines eMachines Desktop PC
I'm new to building pcs and this is my first build. I have two Seagate Barracuda 7200.10 ST3250310AS 250G hdd's installed in my newly built pc. I have yet to detect a driver when trying to install ...
There are many ways to format your hard drive but i will tell the two ways.
  1. while you installing the os like windows xp,2000 it ask you to format the hard disk to install the windows operating system. It comes before the copying the files into the hard disk while you install the windows.
  2. Another way is formatting the harddisk is by seagate software like DM (Disk Manger) is comes with the harddrive or you can download the software from the seagate website for free. DM is the software for formatting . so you can format your harddrive by these software.
May 03, 2008 | Computers & Internet
How to detect two IDE drives with same brand
You need to set one of the drives to be 'master' and the other to be 'slave'.
This is done by positioning jumpers on the back of the harddrives.
Pretty sure that on the drives is explained somewhere how to position the jumper, for several options.
Good luck,
Please post some feedback.
Apr 23, 2008 | Dell OptiPlex GX280 PC Desktop
How to install second internal hard drive
Yes, you can use, Please see label attached to the harddrive for a jumper setting to become primary harddrive.
in the DVD rom there's also a label on it. but the most common setting is slave is in the center.
C S M -
c-cable select
s-Slave
M- Master
the jumper is set to center to become a slave.
the hard drive is should be a master
connecting to the other end of the IDE cable.
HDD-should be a master
DVD rom-Should be a slave
Hope this help.
Feb 19, 2008 | Acer Aspire™ T180 PC Desktop
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
