Question about Motorola Mobility RAZR V3
Display shows msg ... can't get past it.
Hi my razr is showing a msg saying "No voice names are stored in phone book. " I can't get it to do anything else. Any ideas?? I need the numbers out of it too!!!
  • 2 more comments
  • tomsbri Aug 22, 2008
    I cant get to a master reset. the phone will not allow me to view anything but the msg.
  • Anonymous Sep 12, 2008
    Cant delete ringtones. And also my phone keeps cutting off.
  • ken828 Sep 29, 2008
    It lock by No Voice Names are stored in Phonebook
  • indirapriyan Dec 01, 2008
    same problem..the message just blocks me.
    Problem Solver:
  • 8 Answers
Have to tried pressing the button at the back that resets it, and if that doesn't work then you will ahve to go to the at&t place or where ever you got it from and they will help you from there.
Hope this helps
Posted on Aug 24, 2008
    Brigadier General:
  • 7,752 Answers
Try master resetting or clearing the phone and try again
Posted on Aug 22, 2008
  • funky_weasel Sep 26, 2010
    Try removing the SIM card and battery, cleaning out the inside of the phone of any cruft. I found a can of compressed air did the trick. Replace SIM and battery, reboot phone, chide it for misbehaving.
My motorola razr does not display the names when i receive text messages
check the phone book entries...possible the names are appearing twice in the phonebook...or the format in which nos are saved could be diff from the format of numbers u get message ...eg : u might have stores only no and when u recieve msg it might come with a 0 or country code too
Feb 11, 2012 | Motorola Mobility RAZR V3
Voice mail display & retreving messages
Do you know how to get into phone system programming? The extension names are changed in there.
Mar 10, 2010 | NorStar M7310 Corded Phone
Can't Set up Voice Dialing
Are you saying "name dial" first? Name dial works only with the contacts in the PHONE contact list/ address book, otherwise you have to say "digit dial" and repeat the number.Also make sure you have gone to settings>personalize>voice dial set up, first.
Aug 29, 2009 | Motorola Mobility RAZR V3x Cellular Phone
Voice dial?
Voice Command
To activate voice commands:
1. In your menu, go to MY STUFF MENU
2. select TOOLS
3. select Voice Command
4. Enable the on/off option
How to use it:
Call <Name or Number>: This function is activated only when if user says command “Call” and name stored in address book or specified phone number. Handset, voice engine inside recognize users utterance handset, displays name lists from your phone’s address book or phone number, however noise might caused to display candidates. Additionally user can superimpose number type at the end optionally, such as “mobile”, “home” or “office”.
Hope this helps & happy holidays!
-TJ
Dec 15, 2008 | LG Vu CU920 Cellular Phone
Having troublw with voice commands
you must copy a phone number to the phone from the sim card once you have a number stored in the phone memory select your phone book scroll to the number select options scroll down to add to voice dial select it you should get a screen that says say a name when your done just select save
Nov 18, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
I got a error on my olympus VN-3100PC
yes the above solution ie by pressing "STOP" button and "DISP/MENU" button at a time is solved my problem showing "ERR" in VN 2100PC olympus voice recorder
Jun 19, 2008 | Olympus VN-3100PC Digital Voice Recorder
Motorola razr v3x
hai,
first take the contact list and select the name u want to set it to voice dial. select the name detials and scroll down to the voice dial. Then select/ change and from options select record and say the name loudly and save the sound. And u r done. Now exit all and try the voice dial.
good luck
Rabby
Jun 16, 2008 | Motorola Mobility RAZR V3x Cellular Phone
Outside display screen will not show anything but the motorolla logo
Does anything show on the external display if you go to take a picture, but before you acually take it, close the phone and look on the external display as if you were taking a self-portrait?
To make fully sure, while the phone is closed, press a volume button - does anything show on the display? If so, the external display functions and it would be a setting that may have been overlooked.
Go to Menu > Settings > Initial Setup > Display Timeout
or:
Menu > Settings > Personalise > Home Screen
Nov 01, 2007 | Motorola Mobility RAZR V3
Voice tags for bluetooth
See page 54 of manual http://www.fixya.com/support/p401500-motorola_razr_v3_cellular_phones/manual-3642 Recording a Voice Name When creating a phonebook entry, scroll to Voice Name and press RECORD (+). Press and release the voice key and say the entry?s name (within 2 seconds). When prompted, press and release the voice key and repeat the name. Note: This option is not available for entries stored on the SIM card
Feb 14, 2007 | Motorola Mobility RAZR V3
My phone when someone calls wont show the name just "unknown call"
check your phonebook ,, it may have double entry...is it all who calls you display unknown calls?
Dec 16, 2006 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
157 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
