Question about CTX Computers & Internet
Need bracket for ctx pv 720 monitor - CTX Computers & Internet
  • CTX Master
  • 3,051 Answers
I got my bracket for mine at office depot and circuit city also caries them
Posted on Aug 22, 2008
In our company we have monitors ctx PV500BT, the computer has installed windows xp and SP3, before we installed service pack 3 everything was fine, but after that problem started accuring, the...
This seems to be a problem with the screensaver or power /standby settings, please follow the below steps to remove this problem :-
  1. Go in control panel from the start menu
  2. In control panel , go in power options
  3. In power schemes you would find different preset schemes , you can choose one as per your convenience or directly edit it to never option in all the four options that you see, please find the below picture for further help.
Hope this helps :)
May 12, 2011 | CTX PV 500 (Beige) 15" LCD Monitor
Faulty monitor ctx pv720a. The screen has the
Try another cable, or check the plug for bent pins. If they are all good, check that the monitor is set for VGA input (if it supports VGA and DVI) as it may be looking for a different input. Then replace the monitor. It's not common, but video processing circuitry can sometimes fail, and yours may have. New 17-inch LCD monitors are quite inexpensive now, so it would probably be more economical to replace this one than to try repairing it.
Jan 01, 2011 | CTX PV 720 17" LCD Monitor
Ctx pv720a monitor goes blank
This is what inverter board looks like:
http://www.shopjimmy.com/catalogsearch/result/?q=CTX%20PV720
Look for bad caps also, more likely to need new inverter board, warning, you can have bad lamp assembly also.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Capacitors kit: http://lcdalternatives.auctivacommerce.com/
Jul 27, 2010 | CTX PV 720 17" LCD Monitor
Ctx ezbook 700e larger HD
Why move it at all. XP needs SP3 to read hi capacity drives. I use USB external drives without any problems to increase capacity without the hassles of moving files. There are software packages that will transfer data from one hard drive to another if you must.
May 12, 2017 | CTX PV 700B 17" LCD Monitor
Brightness of monitor changes itself to quite dim
YOu can go to the monitor settings to make sure nothing's been changed. It could be an energy saver issue where the display dims after a certain period of time, and you can reset it to longer period of time so it would stay bright for you
Dec 12, 2008 | CTX PV 700B 17" LCD Monitor
Ctx pv 720 lcd monitor backlight drops post plus 30 seconds!
Hi...there,
The problems on the backlight inverter power supply. Open it up and check all the capacitors, it look like a tiny battery cap on the side had writing on it. (Example 1000uf 16v ) if you are lucky you can spot it right away...with a bulged on top of each caps. If not, just replaced all of the caps... Good luck!
Dec 06, 2008 | CTX PV 720 17" LCD Monitor
Ctx model PV720A
Hi...there,
You can saved even more repaired yourself. The problems on the backlight inverter power supply. Open it up and check all the capacitors, it look like a tiny battery cap on the side had writing on it. (Example 1000uf 16v ) if you are lucky you can spot it right away...with a bulged on top of each caps. If not, just replaced all of the caps... Good luck!
Sep 01, 2008 | CTX PV 720 17" LCD Monitor
Need parts
Hi...there,
Oct 23, 2007 | CTX PV 720 17" LCD Monitor
Computers & Internet Logo
41 people viewed this question
Top CTX Computers & Internet Experts
Rommel Balcita
Jerry Greenberg
Jerry Greenberg
Are you a CTX Computer and Internet Expert? Answer questions, earn points and help others
