Question about HP Office Equipment & Supplies
I cannot install my new hp officejet pro L7500 series printer. My computer used to be able to communicate with this printer, but I restored my computer back to the original settings and lost the server connection between my computer and the printer! HELP!!
    Scholar:
  • 152 Answers
Have you checked in Device Manager to see if there are any conflicts? If not, check your Printers folder and see what is listed. If the HP is there, delete it, reboot your machine and see if you can reinstall the driver. Let me know how it goes.
Posted on Aug 22, 2008
Trying to install software for HP officejet L7680 on widows 7 system 64 bit. When installed printer and fax works well. When attempting to scan error message appears. "hp Imaging device not...
when installing the drivers turn off the antivirus software. download the latest drivers from HP, also down load the HP software on the main software page. this is the latest HP firmware and diagnostic firmware.
Jun 21, 2017 | HP Officejet Pro L7680 All-In-One Printer
Printer claims ink cartridge is expired and won't let me print
Hello, if you change the date on your computer to 3 months previous (say), then reboot, you can probably overcome this temporarily. Obviously, for normal operation it's best to restore the date to current, and only set the date back when you want to print something.Regards,nicam49
Jan 10, 2012 | HP Officejet Pro 8500 Wireless All-In-One...
How do i install on windows 7? HP OFFICE JET PRO L7500/L7600/L7700
there are no drivers available for hp printer on windows 7..
so better use windows vista or everyone's favorite windows xp to connect your printer...
Dec 19, 2009 | Computers & Internet
How can I remove the sending fax number on my transmissions on HP
Check the HP Officejet Pro L7300/L7500/ L7600/L7700 All-in-One series
User Guide
(page 83):
"Configure the fax header:
The fax header prints your name and fax number on the top of every fax you send. HP
recommends that you set up the fax header by using the software that you installed with the device. You can also set up the fax header from the control panel, as described here.
NOTE: In some countries/regions, the fax header information is a legal
requirement.
To set or change the fax header
1. Press Setup.
2. Press Basic Fax Setup, and then press Fax Header.
3. Enter your personal or company name using the numeric keypad, and then press OK.
4. Enter your fax number by using the numeric keypad, and then press OK.
To set or change the fax header via the embedded Web server
▲ Select the Settings tab, select Fax from the left pane, select the Basic sub-tab,
and then enter the Fax Header Name and Fax Number. Click the Apply button."
Sep 18, 2009 | HP OfficeJet K80 All-In-One InkJet Printer
HP OfficeJet Pro l7500 won't print. Printer queue shows 5 jobs with error on first 2. I tried twice after rebooting the computer.How to print , or how to download proper driver? SB
Officejet Pro L7500 is giving me error message that it can see the black and yellow print head I have replaced it and it is still giving me the same error.
Is there a way to clean it with out having to have it taken in to be repaired?
Jun 10, 2009 | HP Office Equipment & Supplies
Software Installation Problem
I understand your concern that you are unable to remove previous HP drivers installed on your computer. To resolve this download the HP software removal utility and run the utility.
Click here to download HP software removal utility.
NOTE: Select your OS and select HP software utility At bottom and click on download only. After dowloading run the utility for four times to remove the HP printer software completely from your computer.
After running the utility four times restart the computer and check whether HP Imaging folder is completely deleted or not which as located in C:/progra files/HP Imaging folder. If the folder is not there then the software is removed completely from your computer and continue to download the Full Feature software from the same link and install it.
Now try to scan from HP solution center. This should resolve the issue.
May 23, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Want to set Draft as Default Print Setting
Under Printers and Faxes in Control Panel (Classic View) right click on the printer and select properties then under Printing Preferences set Draft and click OK - this will now be the default setting.
Dec 11, 2008 | HP Officejet Pro L7680 All-In-One Printer
my hp office jet pro l7500 indicates the ink has expired in all cartages but the cartgages are new because they were just put in . Before the same error code came up and so bought new cartages. Also the door to the cartages will not stay closed without tape.
Nov 29, 2008 | HP Officejet Pro L7480 All-in-One...
Mirror images only
hopefully you have fixed this problem by now----if not, go to control panel bt clicking start then settings or could be start then control panel. WHAT YOU ARE LOOKING FOR IS THE PRINTERS AND FAXES FOLDER. once you have found that, right click on the HP Officejet Pro L7500 Series (or whatever your printer name is) and choose printing preferences. go to the advance tab. look for mirror image and click on it you will be given a small drop down to toggle it from on to off----choose off and the click on apply and then OK.
Aug 12, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
175 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
