I closed my laptop, then i opened it, i tried to cut it on but when i tried to cut it on , it cuts on then shuts back off after 5 seconds and nothing shows on the screen. and it is an acer laptop
  • 3,051 Answers
Have you ensured that the power cord is inserted fully and that the power cord is in good condition
Posted on Aug 22, 2008
The dryer is doing nothing when I set the time and push the start button. I have omed out all the fueses and have made sure the door is shut. I have used my multi meter and I am getting the corect voltage....
Check your door switch. It should be a normally open switch. If it's good, you will need to check the thermal fuse and or thermal cut off. This is where you will find the problem. When you find the one bad, you will need to replace the cycling thermostat. It's a normally closed switch that closes on the rise. Once the temp gets to the degree on the cycling thermostat it opens, cutting power to element. When it goes out, it will not open. Then the dryer cycles off of the thermal cut off. This results in the dryer getting real hot and then the thermal cut off will be put out or the thermal fuse one. Your on the right track, keep looking and I feel sure you will find it. By the way, these parts I listed are located on the vent housing close to the blower housing. Good luck.
Oct 16, 2009 | Kenmore 700 6972 Dryer
Back fires everytime i shut it down after
When you finish cutting, bring the engine down to idle for about 30 seconds (some say 5 or 10 seconds but I have found a little longer doesn't hurt anything and sure doesn't scare the heck out of you) before you shut it off, If you shut it down wile it is still turning fast, it will continue to feed fuel into the cylinder and out into the hot muffler where the heat ignites the vapor causing the backfire.
Sep 23, 2009 | Garden
I have problems with my felco #4 pruners after I change the blade. Once I put it back together and tighten the lock nut, the pruners will stick in a closed position after a 5 cuts. I then have to pull it...
How old are they? If the spring in between the handles is old it won't spring back as well. Usually the only time I've ever had a problem with the blades sticking was when I had bent the arms to the blade. Felco's are indestructible, I know, but sometimes you can get a little to over zealous and use them for something they're not designed to do and you wind up bending them. Look down the arms and find out which one seems a little out of kilter and give it a gentle bend until it's back in shape. Do it too much and you'll wonder why they can't get a clean cut. DON'T FORGET TO RATE THE ANSWER.
Aug 28, 2009 | Garden
The DS Green Light Cuts On But Shuts off after a few seconds
I dont now about the sound but for the battery is that the ds charge battery is over! if you see backwards you will need to open it and buy a new battery thats all!!!!!! I try it it works
Jun 06, 2009 | Nintendo DS Lite Console
Acer Aspire 5315 Notebook will not power on
disconnect the battery from the laptop and only hook up the ac adaptor. Turn the laptop on and if it still cuts off after 5 seconds then reseat the memory back into its slots. Also make sure your air vents are not clogged with dirt or dust as lack or air flow can cause the laptop to shut off. If that doesn't do it then take out the hard drive and dvd drive and turn on the laptop. If the laptop still cuts off then it has to be a faulty motherboard at that point which means to much voltage is going thru and the components on the motherboard are not regulating it properly.
Jun 04, 2009 | Acer Aspire 5315 Notebook
Leaf blower problems
You may have a dirty fuel filter, or carb needs cleaned.
Mar 19, 2009 | Craftsman Garden
Rheem gas valve for furnance
It is intentional. It's a slow close valve. There is no adjustment. You can usually replace it with an instant open/close valve.
Jan 18, 2009 | Heating & Cooling
Computers & Internet Logo
David Payne
David Payne
