Question about Dishwashers
Asko 1805 model dishwasher. There is standing water in the bottom of the dishwasher, and although the power is on the machine will not turn on and begin a cycle.
  • scorreia02 Aug 22, 2008
    it appeared to be a drain problem, however i was not able to fix it myself
  • Dishwashers Master
  • 1,879 Answers
First check the drain pump and/or drain hose. It may be clogged with something. Need to have the water removed first.
Posted on Aug 22, 2008
  • monk3ybidzness
    monk3ybidzness Aug 22, 2008
    Check the drain pump and/or drain hose. It may be clogged woth something.
SOURCE:
The lower spray arm on my ASKO 1805 dishwasher has stopped turning, the dishes are still getting washed, so fluid still goes through the sytem, and drains at the end, the heater works. When turning, t
If the arm spins easily by hand, but won't spin when operating, that points to poor water delivery...
1) check the strainer. Not just the holey one you can see, but there might well be a very fine mesh filter under it ~ if so, remove it to clean it (it can appear clean, but still be clogged with transparent cellulose fibres). Try running the machine empty without the strainer/filter fitted. You should hear a difference if the filter was causing the problem.
2) you might have a weak impeller. After a while the plastic impeller on some machines just wears away, leaving insufficient fins to move the water, this can be accelerated by e.g. broken glass stuck in the pump. Impellers can also slip on the motor shaft; the motor's spinning but the impeller doesn't. This means removing the machine, turning it over and removing the pump for inspection...
Feb 13, 2015 | Asko 24 in. 1805 Built-in Dishwasher
All the lights are flashing on Asko 1805 dishwasher
Hi, You need to absorb the water in the overflow basen of the Asko dishwasher's and then push and hold a button to reset the error code...flashing LED's or turn the power off momentarily. You need to remove the lower kick plate and get to the basin with a wet-dry vacuum or sponge etc. Good luck. Let me know if I can assist you further. Thanks for visiting fixya and if you found this solution helpful please rate it accordingly. Macmarkus :)
Apr 08, 2010 | Asko 24 in. 1805 Built-in Dishwasher
Asko 1805 - inside light is on, none of the operation (front panel) lights turn on
Quite simple after all. If the main power button on the top left hand side of the door is pressed in (on). Whenever the door is openned their is a light in the DW which comes on like the fridge or oven.
Keeping the power button off turns the light off. For us this is good as we usually only close the door fully (catch catches) when we run the machine.This way we are not wasting electricity.
Nov 14, 2009 | Asko 24 in. 1805 Built-in Dishwasher
Water Connections
In the US dishwashers are usually connected to the hot water supply. Although the ASKO 1850 I believe has an in line heater. Using hot water supply will reduce electrical useage.
Interestingly we use to have ASKO washer and it suggested only using cold water hook up as it heated its own water. I guess this was a feature if one's laundry area does not have hot supply, but it made no sense in CA to heat water with electricity.
Nov 11, 2009 | Asko 24 in. 1805 Built-in Dishwasher
Asko 1805 dishwasher detergent door does not despense the detergent during the wash cycle. At the conclusion of the dishwasher cycle the door is still closed. How do you repair?
First make sure that nothing is blocking it.. when you load the dishwasher...next make sure your dishwasher cycle is NOT on rince and hold ( water spraying on a plate symbol) as this cycle will not open the despence door..
last you can remove the screws in the door check the vax motor and or check if you are getting power to the despencer ( no power replace control)
power to vax motor replace despencer motor
Hope it helps if Not let me know more about you problem..I can help
Sep 05, 2009 | Asko 24 in. 1805 Built-in Dishwasher
Detergent door will not close on Asko model 1805 dishwasher
Here you must change complete detergent box. Or the electronic gives consantly power to trigger. Most likely one of these two.
Jul 18, 2009 | Asko 24 in. 1805 Built-in Dishwasher
Asko 1805 ALL lights flashing and no water coming out
High water level is often in the pan under the dishwasher.
  1. Unplug or turn off breaker.
  2. Remove kick panel.
  3. Remove water from pan.
  4. plugin/turn on breaker.
  5. watch for leaks.
May 30, 2008 | Asko 24 in. 1885 Built-in Dishwasher
Asko 1805 - all idnicator lamps blinking
Searched some more on this site and found the following from a guest (thanks). It solved my problem, the base where all the electrics and plumbing is located had a pool of water. I had to pull the unit out as I could not access this area from the front.
This is a common problem with the Asko1805. The machine is equipped with overfill protection. Water has leaked through to the bottom pan and has triggered the overflow shutoff float. You must get the water out of the bottom of the dishwasher. Unscrew the kickplate and the metal cover to access the bottom of the machine where the pumps and motors reside. Use a sponge to slop up the water in the pan. Blow dry the bottom. The machine will reset itself as soon as the water is gone.
Apr 19, 2008 | Asko 24 in. 1805 Built-in Dishwasher
Asko 1805 Frozen
Sounds like the controlunit is bad.
Jan 01, 2008 | Asko 24 in. 1805 Built-in Dishwasher
Dishwashers Logo
118 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
