Question about Casio Exilim Zoom EX-Z80 Digital Camera
SCREEN READS CARD LOCKED, CARD WAS REMOVED UNLOCKED BUT SCREEN STILL READS THE SAME THING
  • 4 more comments
  • drummerfreek Sep 16, 2008
    i dropped my camera and whe n i turned it on it said the screen was locked... i took out the memory card and everything worked fine. i put the card in and it said screen locked. should i buy a new card or take it to be repaired? please help!!
  • Anonymous Sep 24, 2008
    MY SCREEN ON MY CAMERA SAYS LOCKED AND WEN I TAKE THA CARD OUT IT WORKS FINE BUT USED SOMEONE ELSES MEMORY CARD AND THA SAME THING HAPPENED WAT DOI DO I ALSO CHECKED THA LITTLE SWITCH NUTING??
  • Anonymous Jan 03, 2009
    Dropped it and now screen says card is locked, even though it isn't.  Also tried someone else's SD card and the same thing happens
  • sassgirl05 Jan 29, 2009
    I have the same problem and I have tried everything. The card itself is unlocked and I have tried multiple times to unlock it and it doesn't work. What else can I do?
  • Anonymous Apr 23, 2009
    my memory card saids it lock where is the button to unlock it?
  • Heintje Apr 27, 2009
    Card locked, but card works fine in other camera's / laptop/
    They want $79 to repair this $179 camera under warranty?
    Ope it up and jiggle the read-only sensor?
    Never again. :-(.
  • 374 Answers
Make sure you are using Toshiba, Panasonic, Sandisc. Those are the only 3 brands Casio recommends using. Make sure that lock on card is moved all the way into the unlock position.
Posted on Sep 12, 2008
I have had this camera for two years and never had a problem. Now when I switch it on the screen shows the message, " Memory card is write protected" and the camera will not function.
On the memory card is a slide lock that locks the card from being accidentally written to or erased. embossed with a lock that is unlocked/locked.
Somehow this slide lock has been moved to the write protection mode/locked. Could have happened if you removed the memory card lately.
Remove the memory card and slide the lock to unlock reinstall the card and that should cure your problem.
Feb 05, 2016 | Nikon Coolpix S3300
I took the memory card out and unlocked the card but the main screen still has write protect on the screen
From your description it sounds like you have locked the card! While the card was being used it would be unlocked so when removed you should just read the card! What type of card is it and are you reading it on a PC?
Jan 17, 2015 | Moultrie M-990i Mini Cam
Memory card locked
And you looked if the card was locked?
The 64GB card is unlocked the 32 GB card is locked. So make sure the switch is up when you see your card like these two.
When you are sure your card is unlocked, just check if all contacts of the card and in the camera are still clean, shiny, and straight. (no bent in any contact)
Jan 18, 2014 | Canon PowerShot A490 Digital Camera
THe main screen reads "card
try to look at the side of the card it might be locked then unlock it
Jun 28, 2011 | Samsung S860 Digital Camera
Telling us that the memory card is locked. Older camera so we no longer can find the instruction manual. Has been working fine. Have removed the card and all that still says Card Locked in red across...
1. Make sure the slide switch on the side of the card is "unlocked". 2. Go into the camera menu and find "reset" to get back to factory default settings. 3. If you can't find "reset" do this....remove the card and battery...press every button...leave the camera alone for 20 minutes...insert the card and then the battery....turn it on.
Jun 13, 2011 | Samsung Digimax 430 Digital Camera
Ic502 sim card swap problems
The phone is attached to another account and the previous owner will have to contact Sprint to have the device removed from the line.
Aug 27, 2009 | Nextel BOOST i835g i835 LTD. ED UNLOCKED...
Memory card reads locked, unable to use camera
there is a little slide tab on the card. switch to unlocked
Jun 01, 2009 | Canon PowerShot A560 Digital Camera
I have a casio Exilim camera.when I turn on the screen reads 'The card is locked' There is no instructions in the manual to cover this event. Can you advise anything? Many thanks.
Take the card out of the camera, and along the side of it, there is a small slide switch. Move it to the unlocked position, and try again. This is a common thing, card come from the manufacturer with the lock applied, and they assume everyone knows about them.
Jul 14, 2008 | Cameras
Card Locked
There is probably a little slide on the side of the card that locks it. Take the card out and slide it back to the unlocked position.
Jul 14, 2008 | Samsung Digimax S600 Digital Camera
Card locked
Not sure what kind of card it is but let me talk about SD. If you look at the left side of the disk when the label is facing you and upright, you should see a little slider. In one position it is locked. Slide it to the opposite side and it is UNLOCKED.
Nov 30, 2007 | Casio EXILIM Card EX-S770 Digital Camera
Casio Exilim Zoom EX-Z80 Digital Camera Logo
156 people viewed this question
Top Casio Cameras Experts
mohamed salim shaikh
pontelemon
pontelemon
Are you a Casio Camera Expert? Answer questions, earn points and help others
