The condenser fan motor is what blows the air around down there,pull out the machine remove the back bottom panel and you'll see the fan,check it to see if something is stuck in the fan blade keeping it from spinning,do this right away,if the fan isn't blowing you can cook your compressor,if something is wrong with the fan motor you can leave the bottom panel off and stick a regular fan back there to keep the compressor cool until you fix the fan motor.hope this helps
