Question about Motorola Mobility RAZR V3m Cellular Phone
Keypad backlight erratic
The keypad backlight comes on sometimes, sometimes it does not. It seems to come on in darkness, but not in room or daylight and I can find no mention of this in the manual. Thank you!
There is a small opaque circle just above right soft-key. Put a small piece of black plastic electrical tape over it and keypad lights all the time. This circle apparently is a so-called "battery saver" which senses light in the area so unless you're in a dark area keypad will not light. There is absolutely no mention if this in the manual that I can find.
Posted on Aug 22, 2008
How do i turn off the keypad beeping sound, but leave the ringer on?
hi.
you should turn off "keyboard tones".
so first go to settings and go to sounds settings.
then go to tones. then go to keyboard tones.
turn it off
Jan 30, 2011 | Microsoft KIN Two Cell Phone
No backlight or key pad light nokia e71
There is a light sensor in your Nokia E71
This light sensor senses the outside light and activates the keypad light accordingly.
When you have enough backround light the keypad light wont light up.If the background light is less then the keypad light wil light up.
You dont get the keypad light ON because the light sensor might have activated.
If in dark also you wont get the keypad light on then the fault lies with the keypad light unit.please give your mobile to the nearest authorised service centre for service.
Thanx
Jul 26, 2010 | Nokia E71 Smartphone
Keypad light thing
i have only had the Q9C but i think with the all the Qs the keypad has a automatic light sensor in dark rooms the lights should bright and in light the lcd and keypad should go off and get dim
i dont know were exactly u may need to dissable the smartback light and press the lcd off light
or u may need to take it in and see if the a cell repair place can fix it i have the same problem with my Q9C i am looking now and its either my windows mobile or candlelight app but u may need to take it in
Jun 29, 2008 | Motorola Mobility Moto Q
Nokia e65 keypad lights
My Nokia E65 keypad lights have not worked from the time i purchased the phone
Jun 11, 2008 | Nokia e65 Cellular Phone
Keypad backlight does not come on
Change the keypad flex connector. If still don't come the light you need to change some parts near flex connector.
May 19, 2008 | Motorola Mobility RAZR V3
Backlight display not working
Hey Dannes1956,
The Motorola V3m has a light sensor, which is visible just above the right soft key -- the key above the CLR button. This light sensor turns the backlight on when you press a key in the dark and disables the keypad backlight when you are in a well-lit area.
Your phone sounds like it's operating normally. I believe they disabled the option to activate or deactivate that feature.
Hope this helps,
cHiPz.
Mar 17, 2008 | Motorola Mobility RAZR V3
Backlight problem
exchange the phone for a new one.........see if that corrects the issue
Mar 14, 2008 | Motorola Mobility RAZR V3
Keypad Problem
Have you tried it in the dark? There is a photo sensor that is located just above the right soft-key. It looks like a pin hole. Put your thumb over the hole and press a key on the keypad, you should see the keys light up. The purpose of this sensor is to prolong the battery life by not having to light up the keypad in the daylight.
There is a way to disable the photo sensor so that the keypad is on whether it is day or night. Look for a setting that allows you to turn the "battery saver" feature off.
- Jim
Feb 02, 2008 | Motorola Mobility RAZR V3
Erratic keypad
It must be dissassembed Clean both surfaces (pad bottom surface and board up surface so they would have good contact) with alcohol solution liquid sweep and let them be dry. Next assemble it again and test it. if START KEY persit not working even if it is clean, a small leaf of aluminium must be stuck at the pad bottom of START KEY. Be sure you can carry out this procedure well done otherwise you 'll need to buy another keypad. Good Luck!
Jan 05, 2008 | Kenmore 63672 Convection/Microwave Oven
Motorola Mobility RAZR V3m Cellular Phone Logo
90 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
