Question about Coleman Lantern Fan Radio (841.321) AM/FM
Coleman lantern fan am/fm radio
I bought this radio at a yard sale...i can't figure out how to put batteries in it...could you help me with downloading the user manual
  • mkalkofen Sep 16, 2008
    I did the same thing, and didn't get the charger.
    Does anybody know the specs on the charger so I can buy one on Ebay?
This fan/lantern/radio was sold under numerous name brands, and is supposed to come with not only a wall wart, (plug in power supply) but it should have also included a 12VDC cigar lighter cord so it can be charged in your car/truck/SUV, etc. The included car adapter is not a standard variety. It has a special resistor inside the plug that limits the amount of charging current. This is very important. Too much current, and the battery could overheat and be rendered useless, or worse, it could literally explode inside the lantern housing. Your best bet is to locate a universal supply, and set it for 7.5 or 8 VDC maximum, and the plug polarity should be what is called "tip positive" Don't assume that an aftermarket wall wart is "tip positive" check it with a volt meter if you have one available to you. If not, ask your friends, neighbors, or call a local Amateur Radio club and ask if there is someone who would be willing to check for the proper voltage and polarity before you try it. It is a very simple check and I'm sure that they will be happy to assist you. As an aside, there is a little compartment in the bottom of the lantern. Mine came with a small emergency kit with a band-aid or two, monofilament line, a hook, and two matchbook type matches. Very odd, but it was a nice touch. God luck, and have fun with your fan.
Posted on Oct 06, 2008
    Problem Solver:
  • 3 Answers
This lantern/fan/radio combination does not use/accept batteries. It is recharged using the black A/C adapter provided with the lantern. I hope you received the adapter with the lantern when you bought it @ the garage sale? You plug the adapter into the little circular opening just above the round spotlight on the lantern. Hope this helps!
Posted on Aug 26, 2008
I just repaired one of these I purchased from a Thrift shop. It would work with a dc adapter plugged into it, but would not recharge the internal battery ( which is a small gel cell type 6 volt ). It turns out the assemblers wired the dc connection wrong to the battery, reversing the polarity, The wires coming from the board to the battery and the ac plug should have been red for positive, black for negative, but they were reversed ! This unite would never work on its battery. So much for quality control from the great workers paradise of communist China !
Posted on Jan 30, 2009
KB2ZGN. You are correct about the tip positive. Trying to fix one of these for a friend. I checked his wall wart and it was dead. Found another one in my pile of stuff and checked it. Was showing just about 8 volts. Plugged it into the radio and the only thing that worked was the fan. Also it had no charging light on. Checked the polarity of the wall wart and found the center tip to be negative. I reversed the two wires and all is fine know
Thank you
Stan
Posted on Jul 10, 2010
6ya staff
SOURCE:
Unlocking channels on uniden bearcat 10 channel, can it be set back to factory settings?
You can download the user manual from here:
Uniden BC60XLT 1 User Manual
It should help to reprogram your unit. Please provide your model number in any further inquiries.
Jul 20, 2018 | Radio
Bought a wrt100 at yard sale with no cd. how do I set it up
Hi Bess,
I've attached the user manual for this router for you to look through. The setup instructions are on the first couple pages.
Hope this helps!
http://downloads.linksys.com/downloads/userguide/1224638332121/WRT100_ug.pdf
Apr 04, 2015 | Linksys RangePlus WRT100 Wireless Router
Need manual for audiovox #FR531
You may download a copy of the manual here.
Mar 16, 2013 | Radio Communications
White Westinghouse Bread Maker WTR-7000
Here is one http://tinyurl.com/32attq
Oct 02, 2007 | Kitchen Appliances - Others
Virgin Pulse VP-14 manual
http://safemanuals.com/ if i helped you at all would you please let me know by rateing my help. thank you kathy
Aug 21, 2007 | Virgin Pulse VP14 (14 Channels) 2-Way...
2 way radio
I found a manual hope this helps. www.marineradios.us/pdf/GMR1038-2CKom.pdf
Aug 05, 2007 | Uniden GMR1038-2 (7 Channels) 2-Way Radio
Coleman Lantern Fan Radio (841.321) AM/FM Logo
3,840 people viewed this question
Top Coleman Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Coleman Audio Player and Recorder Expert? Answer questions, earn points and help others
