Question about HP LaserJet 1010 Printer
PRINTER WONT WORK
PAPER GOT TORN IN IT
    Master:
  • 479 Answers
Servicing required and the tefllon inside the printer needs to be replaced .it will cost u near to $25
if the tefflon is replaced.only servicing not more then $10.
Posted on Oct 01, 2008
I'm having problem with paper getting stuck.
Check the paper path and make sure there is no torn piece of paper stuck anywhere.
May 02, 2016 | Office Equipment & Supplies
Tip
Does not feed paper
Follow the instructions below in an attempt to resolve the issue you are experiencing.
1) Turn off the printer and remove all paper from the paper tray & disconnect it from the computer.
2) With the printer off, check for any obstructions such as torn paper or foreign objects.
3) Place 20-30 sheets of paper in the printer, ensuring none of the paper is torn or creased.
4) Make sure that the paper is flush with the far right edge of paper tray, move the left edge paper guide over so that it touches the left side of the paper.
5) Turn on the printer (still disconnected from the computer) and try to feed paper manually (using the paper feed button).
Still does not work ? Go for Warranty or Service.
on Aug 29, 2008 | Epson Stylus C88 InkJet Photo Printer
I can see the torn paper in my ESP3250 KODAK printer. Please help ,how to remove the torn paper.
Go to the back of your unit remove the cover and gently remove the paper and put the cover back. Your are good to go.
Oct 14, 2014 | Kodak ESP3250 All in One Printer
MY PRINTER SAYS IT HAS A PAPERJAM BUT I KNOW THERE IS NO PAPERINSIDE JAMMED .. HOW CAN I CLEAR THIS MESSAGE . IT WONT LET ME PRINTER ..
Check all the paper path. Ther might be a stuck up sensor not in home position or a small torn paper stuck up or left behind the sensors ..
Sep 09, 2014 | Toshiba estudio 305 Copier
Our printer keeps gettin caught papaer wont glide through help!!!
your paper guide rollers might be off or dirty. Shine a torch and check if any of the rollers is out of place. It happens when there is a paper jam and the paper was yanked the wrong way also there might be a torn piece of the paper obstructing the path. If the rollers are dirty take a earbud dipped in rubbing alcohol and try to clean the rollers.
Nov 01, 2012 | Office Equipment & Supplies
I've cleared to paper jam. Paper was not torn so
you have take the ink cantainer out and disconect the printer for one min then reconnect
May 27, 2010 | Dell 1700n Laser Printer
Paper is jammed inside printer - part of paper torn off trying r
In the back of the machine, there is a door/hatch that you can remove. That might help you.
May 24, 2010 | HP DeskJet F4280 All In One Printer InkJet
The printer wont pull paper thru
theres a piece of torn paper stuck in the feed path. i used to be a photocopier tech and that was a very common problem. get out a flashlight and a pair of tweezers...
Jun 18, 2009 | Canon PIXMA MP160 All-In-One Printer
Paper wont feed
Make sure that the printer track is free of any torn paper. Make sure that the tractor feeds themselves are free from debris. Turn it off during this check.
Apr 24, 2009 | Office Equipment & Supplies
3210 paper wil not feed in the printer it not jam it just will not feed
  • Turn off the printer and remove all paper from the paper tray & disconnect it from the computer.
  • With the printer off, check for any obstructions such as torn paper or foreign objects.
If there is no torn paper or any obstruction then follow this
  • Place 20 sheets of paper in the printer ensuring none of the paper is torn .
  • Make sure that the paper is flush with the far right edge of paper tray, move the left edge paper guide over so that it touches the left side of the paper.
  • Try to feed paper manually .
If your problem is not solved yet then follow this
  • Uninstall the printer driver and restart the computer.
  • Re-install the printer driver
SAM ANDERSON
Sep 16, 2008 | Computers & Internet
HP LaserJet 1010 Printer Logo
22 people viewed this question
Seeker5211
Seeker5211
