Question about Kenwood VR-505 Receiver
My kenwood receiver has
Very low sound in the back im mad! i want it fixed
  • Anonymous Apr 14, 2009
    hello dave my problem on my Kenwood VR-505 5.1 Surround Sound system is i dont know where to connect my subwoofer behind, cause its all red and black wires like the clip insert thingy, how can i properly attached my sub to the reciever
    President:
  • 624 Answers
If you are referring to the rear speakers, it is normal. The rear speakers are not supposed to get a signal as loud as the fronts or center.
A surround sound system was originally developed for playing movies and the rear channels are for effects. In most surround modes the center channel will always be the loudest with the widest range of audio signals.
I have been repairing these type of systems since they have been on the market, so I know a lot about them.
This Kenwood you have is like most surround systems and does not have a feature that you would obviously like to have, 5 channel stereo. Only a few surround systems have this feature and they cost much more than the Kenwood systems. Denon and Marantz both make one with that feature. In 5 channel stereo you get a full signal to all the speakers. All the other surround modes you get a much lower signal to the rear speakers.
So in closing, you do not need it fixed, there is nothing wrong with it. You have a common complaint that many people have who buy a surround sound system but are not fully understanding of just what a surround systems is supposed to be capable of
. This is something that the salesman who sold it to you should have explained to you, that way you could have purchased a system that would have better suited your needs.
I would be happy to give you more help if you would like, just let me know. As I already stated, I have many years of experience with surround sounds systems, in fact I own the exact Kenwood model that you have and I like it very much. It is about the best you can get for that price.
Dave
Posted on Aug 22, 2008
Kenwood kna-g610 map upgrade problems
Which Garmin update did you use?
The correct update is Garmin Part Number: 010-10679-13.
You may also want to contact Garmin Support for assistance.
1-800-800-1020
Jan 08, 2012 | Kenwood Kna-g610 Car GPS Receiver
Im not getting sound from any input other than the radio what do i do?
We have no clue of what inputs you're talking about.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Kenwood-VR-357-Receivers-manual/id/480dj197/t/2/
Come back with specific questions you can't resolve.
Mar 13, 2011 | Kenwood VR-357
No sound on kdc - 138 and i know everything is hooked up right got power in everything i got a little sound but not for long
Im in the same boat... im searching for a reset... mine worked for 30 mins.. once i moved it from my van to 4runner... then I got back in teh car everything turned on but no sound.. i thought a speaker had shorted but nope.. im wondering if there is a reset
Jan 20, 2011 | Kenwood KDC-138 FM / AM Receiver
Connect a Sony SA-W3800 powered subwoofer to a kenwood receiver
Yes. It needs to know you have a subwoofer or it won't send low frequencies out to one. Then you have to calibrate its level to match the rest of your speakers. Hit the SETUP section in the manual (available at retrevo.com).
Jul 02, 2010 | Kenwood VR-309
Sound problem
Try cleaning the volume control with an electronics switch cleaner spray. If that does not resolve the problem and it seems to happen at low volumes more than load volumes, then the output relay needs to be replaced. Keep us posted. Dan
Jun 12, 2009 | Kenwood Audio Players & Recorders
Kenwood excelon kdc-x589 demo mode makes me mad
CLICK HERE for your owners manual in PDF format.
Cancelling the DEMO MODE is explained on page 29... as follows....
Select the Demonstration mode
Push the Control knob to [FM] or [AM].
Select the "DEMO" display.
Set the Demonstration mode
Press the Control knob for at least 2 seconds.
Each time the knob is pressed at least 2 seconds,
the Demonstration mode switches "on" or "off"
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 21, 2009 | Kenwood KDC-X589 CD Player
No sound at all
IF im correct if you only have high outputs which are RCA jacks, between the tunner and the amp, rather then the low inputs which is the factory hornest that your car manufactor installed, when you power down the amp you should have no sound at all. id assume 99.9%
Oct 30, 2008 | Kenwood KDC-MP5032 CD Player
Full Surround Sound
Dear Jennis,
Have you set properly your input source? What about program mode on your playback on your amp was it properly set. You have to let the amp knows that you are using an optical cable for input, this must be done from the controls.
Sidlahora
Dec 06, 2007 | Kenwood VR-7080 Receiver
Fixing a Kenwood KD 491F turntable
The reason why the audio is low, is that todays receivers do not have a phono input, and these types of inputs are differant then the ones of today. You will need whats called a phono preamp, and one should still be available from Radio shack. Or you can go here to find out more about them: http://www.phonopreamps.com/ To reseat the belt, take off the rubber mat on the turntabe disc. Install the belt around the inside ridge, there should be a couple of holes on the platter disc. Install the patter back onto the center spindle. Turn the platter around till you see the motor pully through one of the holes in the platter. Take the belt that is around the turntable platter, and pull it over to the motor pulley. Good Luck
Jun 15, 2007 | Kenwood KD-291RC Turntable
Kenwood VR-505 Receiver Logo
236 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
