(old) InFocus LP335 Projector - powers on for 1.5 minutes, then dies
I recently had my boss walk into my office and set an InFocus LP335 projector on my desk and tell me "it doesn't work" no explanation, no in depth complaint. I set it up and face it against the wall and power it up. It turns on, finds a a signal and is fine. for 86 seconds. the problem has repeated itself many times, and i went ahead and pulled the fans and vents and dusted them thoroughly. I've never really worked on a projector and know the basics, but not much. Any help would be great,
Thanks!
  • New IT Guy Aug 22, 2008
    REVISION: Im sorry, maybe I wasn't clear by accident. it powers on for 86 seconds and then it dies, and will not start even if I let it sit for a half hour. Any Help?
  • Nyavan Feb 19, 2009
    I have exactly the same problem. I'm thinking about an overheating problem, but all the fans to work well.
    If you were able to fix it, can you tell me how ?
    Thanks !
  • 2,237 Answers
Replace the lamp.
Posted on Nov 10, 2009
I recently replaced my bulb on my Cinego Projector, all the fans work - the light on the top works, but no light on the projector screen.
Can someone tell me what can be wrong?
Posted on Sep 01, 2010
After having the projector on for 15-20 minutes the lamp will go out for 1-2 minutes then turn back on with no intervention This will repeat at no set intervals. The projector is not quite 5 years old...
The ambient temperature in the room is to high.
Try lowering the room temperature. If that doesn't work
get a small fan and place it near the projector to provide
extra cooling. The projector is running border line on
high temperature and just needs a little extra cooling.
Jun 28, 2010 | InFocus ScreenPlay 7205 Multimedia...
InFocus LP70
Have you tried another lamp? Sometimes thats your problem, but I've seen a several occasions that the a defective power supply causes this symptom. Do you see an image flicker before the projector shutsdown? I do have some spare parts for this projector.
I'm on Ebay - gtitubro if you want to contact me through there.
Sep 17, 2009 | InFocus LP70+ Multimedia Projector
InFocus LP130 Projector has intermittent power off
go into the menu to find out the lamp hours. it could be the lamp, but if the projector shuts down and not just the lamp, there is either an overheating issue, or a power supply issue.
Mar 07, 2009 | InFocus LP130 Replacement Projector Lamp -...
Infocus IN72 Projector. NO POWER OR NOT POWERING UP
This model projector is very sensitive to internal heat. I f by some reason the projector was abruptly powered down without the use of its normal procedure, in other words, unpluging cord from wall while on or power outage in premises, then the heat remains trapped and the sensors overheat and subsequently shuts down the unit. Now, although, once the sensors cool down it should reinstate operation some sensors become permanently damaged due to the extreme heat. In this case without having more facts, i believe it is the cause. I recommend a free check up to your nearest shop, most shops will offer free check ups.
Jun 07, 2008 | InFocus IN72 Multimedia Projector
Lp335 in focus projector lamp not turning on; spark switch gap is sparking
It could be the lamp. I have seen this many times on DLP'S. If the ballast is firing it which is usually around 600 volts or so, then i would say it is fine, and only needs a lamp. Let me know if that helped you. Later Jay
Jan 20, 2008 | Office Equipment & Supplies
Black lines are appearing on the top and bottom of projection,.
try factory reset in the menu. if that doesn't help, it could be the light tunnel, but infocus doesn't have parts for the lp3xx series anymore.
May 16, 2007 | InFocus LP330 and LP335 Replacement...
813 people viewed this question
jasbo
jasbo
