Question about GPS
I need a wiring diagram for a Garmin GPSmap 172
    Sergeant:
    Champion:
  • 298 Answers
Www.garmin.com/manuals/GPSMAP172C_OwnersManual.pdf
Copy and paste this link into your browser. This is the complete owners manual that should include all diagrams. Hope it helps :)
Posted on Aug 22, 2008
Compass will not caibrate
Garmin GPSMAP 62 - Initial Setup - Calibrate Compass ...
? 7:27
https://www.youtube.com/watch?v=OG7uVh2kQ24
Nov 9, 2010 - Uploaded by Jim Cyr
have owend 3 garmins. will be using handheld for biking. this looks like fast map ... Anyways, your review was decent, just don't know if I like garmin (possibly not). .... Compare Garmin GPSMap 62S vs Garmin GPSMap 60Csx ...
How to Reset the Garmin GPSMap 62 Series Handheld ...
? 1:23
https://www.youtube.com/watch?v=v-M7Ev6YTcA
Jul 20, 2012 - Uploaded by GPSCity
GPS City will show you how to RESET your Garmin 62 series GPS back to factory default settings. Back up all ... -My GPSMap 62s will not track satellites! -Forgot what ... -My barometric altimeter will not work or calibrate.
[PDF]GPSMAP® 62 series - Garmin
static.garmin.com/pumac/GPSMAP62_QSM_EN.pdf
Jan 04, 2016 | Garmin Gpsmap62s Hand Held Gps
Tip
How to Download your Garmin GPSMAP 545 / 545s Users Guide
Have you lost your User's Manual for your Garmin GPSMAP 545 or 545s?
Would you like a digital copy for easy searching of terms and quick reference?
The GPSMAP 545 owner's manual is available from Garmin here.
I hope that helps.
on Jan 31, 2010 | Garmin GPSMAP 545s GPS Receiver
Garmin GPSMAP 178C not boot
can we download india map?if tell me how to download and install the map in my device Gm4300?
Nov 20, 2013 | Garmin GPSMAP 178C Sounder GPS Receiver
How to degausse gpsmap 172 gps
Hi Donnie,
Degaussing is not something that ever needs to be done on this device.
Degaussing is a term that I learned many years ago - it was a process performed periodically on early CRT (cathode ray tube) displays (such as a TV). Over time, CRT displays would build up magnetic charges that would cause the image to become distorted. A degaussing wand would be connected to an AC outlet and then brought very close to the display and gradually withdrawn. This would neutralize the magnetic charges on the display - and the resulting distortion. Years later, manufacturers incorporated a degaussing coil inside the display's cabinet that did the same job as the degaussing wand - thereby making the wand obsolete.
The GPSMap 172 has an LCD display that requires an electrical charge to create an image on the display. Unlike a traditional CRT type displays, an LCD (or LED for that matter) display is unaffected by magnets / magentism. Hold a magnet near a non-CRT type display to see for yourself. A magnet held near a CRT display however will distort the image more as it gets closer to the display. Caution: Doing this may cause PERMANENT damage to the CRT display. This is why many home theater speaker systems touted that fact that they were "magnetically shielded" so that they would not distort the images on the CRT display.
I hope this helps!
Aug 28, 2013 | Garmin GPSMAP 172C GPS Receiver
My Garmin GPSMAP 178C screen backlight failed
Backlight problem: Remove the display, remove the light tube from behind the LCD. Buy a led panel from Ebay for around $5 and install it behind the LCD under the drfusing layers. Run the wires out to a 12 VDC source and there you have it.
Jul 13, 2010 | Garmin GPSMAP 178C Sounder GPS Receiver
How to perform a factory reset on a Garmin GPSMAP 172
The model number of your unit has been cut off so I can't find exact instructions. I found a page here where the guy said he held down Enter and Page keys while turning the unit on.
http://forums.groundspeak.com/GC/lofiversion/index.php?t128887.html
You should be able to find the user manual if you do a google search. It will have all the details.
Try "Garmin Gpsmap <your model> manual pdf" as the search string. (no quotes of course)
Hope this helps
Aug 16, 2009 | Garmin GPS
Missing fitting instructions
I just hardwired it into my vehicle, I use it for both road and water, I goggled garmin 276c wiring and I located the schematic. Unfortunately I cannot locate my printed hardcopy now. Give it a shot.
Apr 23, 2008 | Garmin GPSMAP 276C GPS Receiver
172 will not work after dropping
Have you solved the problem?
If not you shall check that the flexible cable to the screen is securely connected to the circuit board. Check also the other cables.
BR
SHALL@tdc.dk
Oct 21, 2007 | Garmin GPSMAP 172 GPS Receiver
GPS Logo
310 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
