Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Stop error i have get a error during os xp installation error code is stop error 0x0000008e(0xc0000005, 0xfc779cad, 0xfc3477e4, 0x00000000) give me coorrect solution.
  • 44 Answers
Visit this post on microsoft to resolve your problem.Your RAM may be the cause of the error.
Posted on Aug 22, 2008
STOP 0X0000008E(0XC0000006,0XF740DFEA,0XF6F0AA14,0X00000000)
The stop is actually a OS error code abbreviated "Stop 0x8E "
"KERNEL_MODE_EXCEPTION_NOT_HANDLED"
In reality it is a BSOD (Blue Screen of Death).
The most likely cause is caused by memory hardware failures and more rarely by device driver issues, viruses, or hardware failures other than your RAM.
Type the same as the quotation "Stop 0x8E" into Google - it will take you to the error code and give you the meaning.
It's not a computer processor error, at all, but a memory or driver error. Most likely a device which is trying to be used by the OS you are loading but can't load because the device needs a driver or the memory is loose (besides bad memory). Remove the memory and re-seat. Make sure not to touch the contacts with your hands. Take a pencil eraser and clean the contacts.
For a better answer, the next time give the OS version you attempting to load, and the hard drive you are using whether ATA or SATA. The more data the better. Now to test your memory --- download MEMTEST (find it on Google) it's FREE. And run Memtest on a Floppy disk or from a CD. Run the complete ALL tests, It will take many hours, but you can write down the errors (if any) and exchange your memory for new memory under the lifetime warranty that memory maker give. Good luck.
May 10, 2014 | Computers & Internet
Error on windows xp desktop page_fault_in_nonpage_area
You receive "Stop error code 0x00000050 (PAGE_FAULT_IN_NONPAGED_AREA)" or "Stop error code 0x0000008E (KERNEL_MODE_EXCEPTION_NOT_HANDLED)" when you restart a Windows XP-based computer uparrow.gifBack to the top ' Give Feedback 20x20_grey_minus.png954211 MS08-061: Vulnerabilities in Windows kernel could allow elevation of privilege
  • 959252 Error message when you switch the operating system from a dual monitor setting to a single monitor setting on a Windows XP-based computer or on a Windows Server 2003-based computer that has the security update 954211 installed: "Stop 0x0000008E"
  • Note Update 959252 addresses a known issue that was introduced by update 954211.uparrow.gifBack to the top ' Give Feedback 20x20_grey_minus.pnguparrow.gifBack to the top ' Give Feedback 20x20_grey_minus.png824684 Description of the standard terminology that is used to describe Microsoft software updates
    Jan 06, 2014 | HP Computers & Internet
    0x0000008E (0xC0000005,0x805D946E,0xF78032FC,0x00000000)
    Remove all USB attached devices like drives. You may need to roll back system with System Restore. Under Safe Mode (press F8 during boot and choose Safe Mode). Win 7 - Start > Search type System Restore. XP - Is Start > All Programs > Accessories > System Restore. Now choose a date prior to problem. You may have to try a few dates. Uninstall last program(s) that was installed, again in safe mode. To eliminate possible bad RAM. Unplug PC, open case, and remove all RAM. Test one DIMM at time, one slot at a time. Re-install Windows. Clean install works best, but all data will be lost. Lastly you may have other hardware problems. If it does another blue screen after reloading windows, especially with a clean install.
    Dec 11, 2012 | Microsoft Windows XP Home Edition English...
    Pc blue screens with 0x0000008e (0xc0000005, 0x807019uf, 0xaa7ff48c, 0x00000000) after reboot goes into safe mode boot option. Selecting xp pc boots normally. repeated reboots pc works fine. But if left...
    STOP 0x0000008E errors are usually caused by memory hardware failures and more rarely by device driver issues, viruses, or hardware failures other than your RAM.
    Download and run from a floppy or CD MEMTEST86 at
    http://www.memtest86.com/
    Aug 05, 2010 | Evesham Evolution PC Desktop
    System is wont boot
    Getting 0x0000008e is surely a signal that your registry is corrupted. What you need to do is to fix 0x0000008e as well as other registry errors to prevent your registry from total corruption. If you continue to run this damaged system and don’t fix 0x0000008e, this potential risk will bring you more troubles, Even system crash.
    Cause of the problem would be.Mis-deleting registry entries, downloading dubious files, hard shutdown PC etc can also cause 0x0000008e.
    Heres how to fix the issue
    Download the software fix by clicking here.
    Launch it after finishing the installation.
    Click “Scan Now” button
    Click “Repair Problems” button and fix 0x0000008e.
    May 21, 2010 | HP Pavilion dv6000z Notebook
    Error code
    Apparently the XP Pro CD you are using is pre-SP2, thus causing the error. With XP RTM and SP1, you need to supply the proper SATA drivers for the chipset on the motherboard since there is no built-in support for SATA drives. You can download the drivers from http://www.ecs.com.tw/ECSWebSite/Downloads/DownloadFile.aspx?catid=1&driverid=2214&areaid=2&LanID=0
    During the XP setup you will need to press F6 to install these driver before attempting to copy the XP files to the drive. Or you could make a custom XP CD using the directions at http://maxeasyguide.blogspot.com/2008/04/preparations-for-winxp-installation-cd.html that has these SATA drivers already slipstreamed into the installation procedure.
    Or if you know someone who has the WinXP Pro SP2 CD, you could borrow that for the install.
    Apr 07, 2009 | Foxconn (945G7MA-8KS2) Motherboard
    XP Home Edition crashes while in standby - blue screen error
    Sounds like a bad file . I would consider reinstalling windows. When it starts up, for a new install, it will find your existing OS and ask it you want it repaired, say yes then it wil repair it and leave al you data as is.
    Dec 25, 2008 | Microsoft Windows XP Home Edition
    Hey
    this might help
    https://support.microsoft.com/en-gb/help/315335/-stop-error-code-0x0000008e-or-stop-error-code-0x00000050-page-fault-in-non-paged-area-error-message-during-windows-xp-setup
    May 06, 2017 | VMware Workstation 4.x (WS4-ENG-W-CE) for...
    Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
    300 people viewed this question
    Top Microsoft Computers & Internet Experts
    micky dee
    Piyal Perera
    Piyal Perera
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
