ASUS Eee PC 1000HA Notebook Logo
Posted on Jun 23, 2011
Bios settings/page keeps on appearing every time i boot up my asus eee....the date and time seems ti be fine...what is the problem here? i have already pressed f2 countless times to load default settings
2 Related Answers
Anonymous
  • Posted on Jan 27, 2011
SOURCE: asus eee pc 1005hab will turn on but will not boot
I have an Asus Eee pc 2g surf. I inadvertently installed a bios 2008 upgrade and cannot provide a password and cannot get beyond this page. Assus techs cannot provide it without an invoice and I have none as it was a gift. Any solution? I have taken out the battery, pressed f2, shift f10 ( which gets me to a screen "Atheos Boot Agent Configuration Agent" but not sure how this will help)
bronk50
Brian Sullivan
  • 27725 Answers
  • Posted on Apr 09, 2012
SOURCE: Asus Eee PC 1005HA wontl load OS
what key do you see during the boot up process
you should see a certain key it will be very quick you might have to restart a few times to get a good look
try pressing the delete key
hope it helps
Asus eee 900 disk hardware configuration
Have you checked BIOS settings to make sure the right harddisk is selected as Boot Drive ?
You could try installing it on another machine to make sure it's still readable.
Did you change any settings or get any error messages the last time you used it ?
tip
Retrieve Password on ASUS Eee Pad Tablet
Looking For a Password Recovery Program to Access Your Locked ASUS Netbook? Apple's iPad 2 maybe the hottest thing on the hip-happenin' trendy tablet block, but Asus isn't that behind with its own version, currently dubbed the Eee Pad. Till April 2011, this computer has occupied a considerable market share. In this article, we will learn how to <a href="http://www.windowspasswordsrecovery.com/retrieve-asus-password.htm">retrieve ASUS EPad Password</a>. <br /> <a href="http://www.windowspasswordsrecovery.com/images/knowledge/retrieve-asus-password/asus-eee-pad-tablet-password-big.jpg"><img src="asus-eee-pad-tablet-password.jpg" /></a> What is ASUS Eee PC? Asus Eee PC is a subnotebook/netbook computer line from ASUSTeK Computer Incorporated, and a part of the Asus Eee product family. At the time of its introduction in late 2007, it was noted for its combination of a light weight, Linux operating system, solid-state drive and relatively low cost. Newer models have added the option of Windows operating system and traditional hard disk drives.<br /> The first Eee PC was a milestone in the personal computer business, launching the netbook category of small, low cost laptops. According to Asus, the name Eee derives from "the three Es," an abbreviation of its advertising slogan for the device: "Easy to learn, Easy to work, Easy to play".<br /> Some of ASUS's hot products <b>Eee Pad</b>: Eee Slate EP121, Eee Pad Transformer TF101<br /> <b>Eee PC</b>: Eee PC T91, Eee PC 1000HD<br /> <b>EeeBox PC</b>: EeeBox PC B201, EeeBox PC EB1502<br /> How to Regain Password on ASUS Eee Pad Tablet? There are 2 passwords in an EPad, a bios password, an Operation System password. We will separately discuss the 2 cases.<br /> Bios Password Bios password is setting on the bios config, we can press Del button during loading the PC to enter bios config menu, then remove the bios password. Sometimes, you don't know the bios password, look this guide: "<a href="http://www.blog.windowspasswordsrecovery.com/top-3-methods-to-crack-bios-password/">Top 3 methods to crack bios password!</a>".<br /> <b>Tips</b>: As we know, EPad uses touch screen. We could connect it with a USB keyboard to press Del button. <br /> Operation System Password We can install many OS on an ASUS tablet, for example: Linux, Unix, MAC OS, Windows. Here we discuss only windows. <b>1.</b> Download <a href="http://www.windowspasswordsrecovery.com/downloads/Windows_Password_Recovery_Tool_Ent_Trial.exe"><b>Windows Password Recovery Tool</b></a> (free trial).<br /> <b>2.</b> Install and run it.<br /> <b>3.</b> Create a password reset disk. A CD/DVD disk, or a USB Flash Disk, depend on the locked ASUS PC's support.<br /> <b>4.</b> Boot the locked ASUS computer from the password reset disk. <br /> Note: You may need to config bios setting to set it boot from the password reset disk. The 2 articles can help you.<br /> a. <a href="http://www.windowspasswordsrecovery.com/getting_started/bios.htm">Boot from the CD/DVD-ROM</a><br /> b. <a href="http://www.windowspasswordsrecovery.com/getting_started/bios_usb.htm">Boot from the USB Flash Drive</a><br /> <b>5.</b> On the password recovery Windows, select the user account that you forget its logon password, click "reset" button.<br /> <b>6.</b> Confirm you action, then that user's password will be removed.<br /> <b>7.</b> Disconnect the password reset disk, and reboot your ASUS computer. You will access Windows OS without password ( blank password ).<br /> Finally Get away from the troubles of forgetting ASUS PC Password, no matter it is bios/cmos password or Windows password. <br /> Tips: <b>1.</b> The Windows Password Recovery Tool supports all versions of Windows OS, including Windows 7, Vista, XP, 2000, 2003, 2008. It is popular way of regain your password, even you don't have a password reset disk. <br /> <b>2.</b> Keep in mind that this tool can be only used on your own computer, never try to use it to crack PC password without permission. Otherwise, you will get into trouble by law.<br /> <b>3.</b> You can <b><a href="http://www.windowspasswordsrecovery.com/create-windows-7-password-reset-disk.htm">create a ASUS Eee Pad Password Reset disk</a></b> before you forget password. <br />
on May 23, 2011 • Computers & Internet
Asus stops in bios
When it stops booting, does it ask you to do something, like enter the bios and set the date? If so, do so. If it keeps doing it, you probably need a new CMOS battery.
If it hangs with no clues at all, either your operating system is corrupt or your hard drive has failed. You need to be able to boot from another source ie external disk drive or USB drive.
What is the problem If the time and date will not hold
This means that your BIOS battery is flat/worn out and this is why it changes the date and time each time you boot up.
Replace the BIOS battery with a new one then boot up and go into the BIOS and set the correct Date and Time.
3helpful
My asus 1005ha computer wne powering up goes from the grey asus page to a post? page. i have to either press f1, which takes me to the bios settings or f2 which says start with current settings. Have no...
Your CMOS battery may be dead or dying, or just has been reset. It is a small watch-like battery that keeps track of the time and BIOS settings. Your BIOS settings may have been reset because the battery cannot hold enough of a charge to store the settings and time. Also, it could have just been manually reset in the BIOS settings. If you go into the BIOS settings, adjust your date and time, and the POST screen setting, and the settings stay that way, your battery is good and was just reset. If you change the settings and they reset again, you have a bad CMOS battery. If it is the battery and you need instructions to replace it, let me know.
5helpful
Asus eee pc 1005hab will turn on but will not boot up. cannot get into bios vis f2, esc. just a frozen screen that says asus eee pc press f2 for bios. I have disconnected the battery many times, will not...
My ASUS Eee PC 1005HA turned off by itself then when I turn it on again, a screen come up and said "press F2 or tab" but when i press each of them, nothing's happened. How can I fix that?
Hi I have almost the same problem as ame_91_ok with my Asus Eee Pc 1005Ha. It suddenly shut down a few days ago and ever since that time it boots the bios screen where you have to press F1 to enter setup or F2 to load with the default settings. If I press F1 I enter the bios setup and if I press F2 it's boots fine after that and it seems to work normally. Still I'd like to know what the problem is and if I can fix it before it might get worse. I don't know anything about bios settings or anything like that so I could really use some expert advise. Already tried updating my bios, I have the latest bios version now but that didn't fix the booting problem.
Greetz 08Ray
HI I Trying to restore my ASUS EEE PC 900. It has no CD drive. I tried doing the F9 option but it does not seem to work. It keeps bringing me to the black screen where it says safe mode, start windows...
Method 1 :
  Installed Operating system with an external usb CD or DVD Rom drive.Set your laptop to boot from USB CD ROM in your BIOS.
Method 2 :
  Yoou need an PC with windows server 2000/2003 with RIS (Remote Installation server Set up plus DHCP (Dynamic Host configuration protocol) server ).Change your laptop BIOS Boot setting to boot from Network and installed as if you are installing through  normal procedure.
For more information on setting up RIS Server and DHCP.
here is the link
http://support.microsoft.com/kb/298750
http://www.windowsnetworking.com/articles_tutorials/Setting-Up-DHCP-Server-Organization.html
1helpful
Bios version for asus eee pc 10005ha touchpad screen freezes
Its not the Bos,just dont corrupt the boot procedure with unnecessary key presses.
Or reinstall factory settings properly--it has very little to do with the bios
2helpful
I have a asus Eee pc 904hd that will not boot up
Yes press f2 , this will take you to bios page. See if your date and time are correct. If it is NOT set them using the keypad mouse (Read)
then exit say yes for changings, see if windows loads,
After that if does it again, you need to replaced the CMOS battery.
See TechGuy or Contact me.
JMC
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
