Question about InFocus LP 600 Multimedia Projector
Partial picture The picture has a grayed area about 1/10 of the screen on the left side. The rest of the image is clear and bright. It has worked perfectly in the past, but suddenly we have this problem.
  • terryf51856 Aug 22, 2008
    The unit has never been abused... actually it has been used very little.
  • GOBILLS Aug 26, 2008
    BROWN LINE ON SIDE OF VIDEO PROJECTOR
  • 74 Answers
Your light pipe has collapsed
Posted on Aug 15, 2009
I am trying to adjust the brightness on this circa 1980 floor model solid state tv
The contrast setting controls the relation between the light and black areas of the screen. If the light areas are too bright and are losing details, press the CVOL button; if the picture is gray and lacks contrast, press the VOLB button
The brightness setting controls the overall amount of light in the picture. If the picture is too bright, press the CVOL button; if the picture is too dark, press the VOL B button
The color setting controls the intensity of color.
Curtis Mathes CM19102 Owner Manual Returning To The Factory Settings...
Apr 09, 2016 | Curtis-Mathis Televison & Video
White lines on image however when capturing on dark areas and on video mode, it produce a perfect image
Not clear when you have white lines. While looking on the screen or really on a image.
Lots of camera's produce lines on the LCD, when using the LCD to frame the picture. Special when there are small and sharp lights in the image. But the sensor is not capturing that while making the picture. It is a sort of smear on the screen.
Also, when you try to make a picture in bright lights, you can get flares, but those you can see on the screen and in the picture. To fight flares, most camera's and lenses come with sun hoods. Your camera does not have a hood, so try to avoid shining bright lights on the front of the lens.
Nov 05, 2013 | GE 14MP Digital Camera with 5X Optical...
My JVC HD56 has a purple/green tint and isn't very bright.
Not worth attempting to fix and that is the reason it was tossed.
Apr 01, 2012 | JVC HD-56FN97 56" Television
I have an LG 42" LCD tv with blurred image on half the screen
lg 42 in lcd tv power button blinks nine times before staying on and has sound but no picture
Feb 04, 2010 | LG 42LC2D 42 in. LCD HDTV
Acer aspirw 5100 brightness
1.The Function key (Fn), and the F6 key are pressed to turn the Backlight off to conserve power.
2.The Fn key and the right side arrow key, are pressed to increase Brightness.
You have a TFT LCD monitor screen. (Thin Film Transistor)
The LCD screen cannot be seen clearly without a Backlight.
The Backlight is a CCFL. Cold Cathode Fluorescent
tube. Resembles a small fluorescent tube used in residential, and commercial lighting.
The Backlight can go bad after time, and weaken.
If so, it will have to be replaced.
Sounds easy, it isn't.
The TFT LCD monitor screen is made up of layers. It's enclosed in a thin metal frame. Resembles a picture frame.
The frame is removed, after removing the LCD screen from the laptop's top cover.
The LCD screen transparent outside layers, are separated partially from the rest of the LCD screen.
The Backlight is removed out of the side.
This gives you an example of removing, and replacing an average Backlight,
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
Recommended job for a pro.
Dec 28, 2009 | Acer Aspire 5100 Notebook
Our Sony Bravia tv picture keeps going light dark light dark. What is causing this problem? It is very annoying when it goes dark because you can't see the picture. Please help.
I have Sony KDL-32XBR9 and I have noticed a similar problem. When the picture is showing mostly black, for example during the ending credits of a movie, the TV will further darken the display. Once the picture lightens back up, the TV will adjust the brightness of the display back to normal. I just called Sony customer support and they indicated it was a firmware problem and they will be sending a USB device in the mail to update the firmware. Hope this helps.
Oct 16, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Gray screen with horizontal lines accross it
sounds like you may have a bad ic it probley is a surface mount on the bottom of the board it could couse this problem would need to take to a shop to repair. The ic probley is numbered ic101 on board.
Mar 01, 2009 | Sanyo DS32224 TV
Cracked screen and down screen
If the double images are located at the bottom on one side, you might have cracked the mirror inside the set and it has been displaced making the picture in that area bad (especially if the rest of the picture is OK)
Dec 28, 2007 | Philips 60PP9202 60" Rear Projection...
LCD doesn't show image when I try to take a picture in dark area with flash. The picture are not bright and clear.
my LCD screen on my dxg-506v DV doesn't want to display anything all i see is nothing but a bright screen and absoultly no picture on the LCD screen the only way i can see a picture is through my tv screen. i tried and tried and tried using the pc disc that came with the camera and still nothing works the china people just don.t build solid enough technology. like may be get those people out of those sweat shops and start paying them some real money so that much better technology can be made in china
Dec 26, 2007 | DXG Technology DXG-506V DV Digital...
InFocus LP 600 Multimedia Projector Logo
208 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
