Question about Canon Pixma iP6600D InkJet Photo Printer
Canon IP6600D Error Message U150
When i turn on my printer there is a error message U150 "The following ink tank cannot be recognized (Photo Magenta Full Tank). A few months ago this problem popped up and i simply opened the top took Photo Magenta out and put it back in. It worked. I did this for about a few months then that quick fix does not work anymore. Now it just stays at the Error U150 and i cant print.
  • 1 more comment
  • Anonymous Oct 05, 2008
    I have the exact same problem. When I examine the ink tank, it clearly contains ink and the contacts are clean.
    What is going on here?
  • mickeyddd Oct 07, 2008
    U150 problem, ink tank cannot be recognised
  • ttarget98 Dec 07, 2008
    I have EXACTLY same problem.
    Can someone suggest a solution?
    Someone mentioned this may need to to "re-sst" the chip...how would you do that?
    Thanks a lot....
You need to reset the chip on the ink cartridge.......................
Posted on Oct 31, 2008
Canon PIXMA MP530 printer repeatedly getting LCD Error Message: "CHECK INK U071 5Bk". I have removed, reinstalled, reseated the 5Bk and all other ink tanks multiple times. Usually when this...
I have Canon M560 printer installed 8 months ago. I replaced the CLI 221 Magenta and CLI221 Cyan ink cartridges, won't work and got this message Error 1411. Tried repeatedly to reinstall the ink cartridges and still have this message coming back. Any solution you could offer? I would appreciate it. Thank you.
ben
Nov 06, 2008 | Office Equipment & Supplies
I keep getting a U150 ink tank cannot be recognized message. I check the ink tank, it is full. It lghts when I put it in, but when I put the cover down, the light goes out and is not recoginzed.
YES- the solution is I had been sold a cartridge for the printer that was same series 8 it needs but it was PM Magenta not a stand M for magenta so I found out form Canon - this is not a photo printer and it cannot use photo printer ink attached Canon's reply to confirm. Went back 3rd time got the M in the 8 series and all is good alarm light out and no error saying it cannot recognize the ink cartridge. YEAH!!!
Thank you for your reply.
Yes, the PIXMA MP530 only uses the regular ink tanks and not the photo
ones. This is the reason that it did not work correctly. Glad to hear
that everything is working now. If we can be of further assistance with
your PIXMA MP530, please let us know.
Thank you for choosing Canon.
Sincerely,
Devin
Technical Support Representative
Aug 24, 2008 | Office Equipment & Supplies
MP500 ink tank cannot be recognized error U043
I had the same problem. My mp630 is also only 4 months old. I replaced all colour ink cartrdiges(inc black), but was only able to release the function for detecting the ink levels for magenta and cyan. Yellow and black then started giving error message U043, with them alternating between working, but never working at the same time. Getting them all clicked in with the lights glowing red does not solve the problem, as once the printer cover is closed, the same error message turns up. The only thing that worked for me is moving the chip slightly out of alignment, by pushing the sliding chip holder, and I only had to do this twice before they all started working and the printer was unlocked.
Jul 30, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Error: U150 the following ink tank cannot be recognized
Only thing you can do with the U150 error is replace the tank.
Jun 27, 2008 | Canon MP970 Photo All-In-One InkJet...
It appears U150 the following tank cannot recognized.. All ink are full
has anybody a solution for these crappy ip6600d canon printers constantly getting the u150 error, i've got a brand new canon catridge but to no avail, it still complains.
Jun 24, 2008 | Office Equipment & Supplies
Same problem - two solutions I found helped me work out mine. One said contacts needed to be cleaned and it worked to use a Q-tip and alcohol or just click it in position several times until it recognizes the cartridge - this may work. Another said that they got it to work by installing a brand new cartridge - cool, but I have one full of ink it won't recognize. So I pulled the little circuit board off a used cartridge (like you need to do with some refills) and put it on the cartridge that it wouldn't recogrnize - works great. Still haven't figured out how to get it to acknowledge ink levels though. Canon really should be more consumer friendly since these problems seem to be intended to compel the use of proprietary cartridges.
Dec 27, 2007 | Canon PIXMA MP600 all-In-One InkJet...
Error code: U150 The following ink tank cannon be recognized (Cyan)
U150 ink error fixed!
I too was getting the error for unrecognized ink cartridge. Then the little green circ board fell out of the end of the ink cartridge and it hit me that maybe if I put in the little green circ board from the old ink cartridge of the same color, then maybe the ink cartridge would be recognized. It worked! So don't throw out an ink cartridge that still has ink just because of that error and hold onto your empty cartridges in case you need the little green/gold circ boards.
This works!
Dec 26, 2007 | Canon PIXMA MP600 all-In-One InkJet...
I have a canon mp510 pixma same message U043 and a u150 fault.
I cant see any chip to replace and have replaced my original cartridges with a non branded cheaper type, this might be why. Does this make a difference or is this the same problem occurring with replacement canon cartridges as well.
Dont want to buy genuine ones if its not going to make any difference.
Anyone who can help me would be appreciated
Nov 14, 2007 | Office Equipment & Supplies
Canon ink tank problems
I think I figured this B!tch out.
When you get the error:
"More than one ink tank of the following color is installed" or
"Ink cartridge not recognized"
Open up the lid where the cartridges are and hold done the "SEARCH" button. This has been working for me, and I bought my ip6600d in 2005, so my machine is old, and ready for this..........ORIGINAL INK!!! Never really used it beyond printing very few pics. So I was really pissed when I found these messages to almost 5 years after buying this printer. So to recap, open the lid where the ink cartridges are while holding the "SEARCH" button, hold it up for like 5 to 10 seconds, place lid down still holding the search button, then let go of the search button. I did notice the alarm was lit, but went away after I released the search button. Good Luck!!!
Until I held the search button down I had turned of the printer, reseeded the cartridges and open and closed the lid but it never worked.
Sep 19, 2007 | Canon Pixma iP6600D InkJet Photo Printer
Canon Pixma iP6600D InkJet Photo Printer Logo
1,396 people viewed this question
old marine
old marine
