Enet wireless yes the unicorn inn 2 network is showing up but when i go to enter the network security key it wont accept it becuase its not EXACTLY 5 or 13 characters. and i had the same problem last week at a motel where the password was guest000 and it didnt work there either cause thts also not the exact number.
    Problem Solver:
  • 50 Answers
Try the link . . . www.laptop-problem-solution.com
For find your best solution.
46
Posted on Jul 25, 2009
I want to secure my belkin 54 router, its not secure now
Access point configuration
1. Open a Web Browser
2. In the address bar type the IP address of your access point.
Note: By default the IP address is 192.168.2.254
3. Click on Security in the left hand column under Wireless
4. Enter your password if any and click Submit
5. Select WPA-PSK (no server) from the Security Mode section
6. Enter your Pre-shared Key
Note: You can mask your Pre-shared Key by selecting Obscure PSK
7. Click on Apply Changes
Network adapter configuration
1. Go to Start and click on Control Panel.
2. Control Panel window will appear. Double click on Network Connections.
3. Network Connections window will appear. Right click correct Wireless Network Connection by identifying correct wireless network adapter and click View Available Wireless Networks.
4. Wireless Network Connection window will appear. Select the network you wish to connect and click Connect.
5. The should now be security-enabled.
6. Enter the WPA-PSK network key you set up in the router as above.
7. If all goes well, you will connect to wireless network at last.
May 03, 2011 | Belkin (54G F5D7230UK4) Wireless Router
Error code 051099
It appears that the settings entered into the Nintendo DS are not compatible, or the router's broadcast settings should be changed.
What we need to do is try creating a new connection with your system.
1. Turn on your Nintendo DSi and access the System Settings by clicking on the wrench icon
2. Scroll over to the third page, and select "Internet."
3. Now choose "Connection Settings."
4. Click on "None" for "Connection 1." (Don't see "None" for Connection 1? To ensure any existing settings don't interfere with getting connected, tap the button, then choose "Clear Settings.")
5. Click on "Search for an Access Point."
6. The Nintendo DSi will search for any wireless networks within range. Once it is finished searching, it will display the names of all the wireless networks it finds.
Look for your wireless network.
7.What to do next will depend on the "lock" icon you see next to your network on the Nintendo DSi.
You will now have 3 options
A. GOLD UNLOCKED LOCK (No security - Tap on your network name to save the settings and begin a connection test.)
B. GOLD LOCKED LOCK
WEP security - Your wireless network is secured with WEP and requires a security key.
Follow the steps now depending on your option
A.
Select "OK," "Save Settings," and then "Yes." The connection test was successful - Your Nintendo DSi is now connected online.
The connection test was not successful - If the test was not successful, you will receive an error code. LET ME KNOW WHAT IT IS
B. WEP security - Your wireless network is secured with WEP and requires a security key.
Enter your WEP key
On the upper screen you will be informed that "A security key is needed to connect to this access point." Enter your security key by tapping the empty field, and select "OK" when finished.
  • The connection test was not successful - If the test was not successful, you will receive an error code.
    • Error Code 51300 or 51099: This means the security code entered into the Nintendo DSi is not the same one the router is set to. Scroll back up to step #3 of this page for the step-by-step directions. To reach your connection settings, click "back" on the error code screen. Make sure to pay extra attention to the security key you find in your router's settings and enter it exactly as it appears (the key is case sensitive).
    • All other error codes: Let me know what it is.
  • Jan 15, 2011 | Nintendo DSi (0.25 GB) Blue Console
    Router wrt54g2 wont connect to my ho laptop asks for key or passphrase and when in put in key starts doesnt match my laptop security network
    You have set up the security on the router itself so that nobody can steal your signal. When you did this you made up your own key/pass phrase. If you go back into the setup screen for the router you can look under the wireless tab then click on wireless security. Depending on what security you set up be it WPA Personal, WPA Enterprise, WPA2 Personal, WPA2 Enterprise or WEP it will show the shared key that you made up. You must enter this key in on your laptop EXACTLY how it is typed in the box in the routers information page.
    Dec 23, 2010 | Linksys Wireless-G WRT54G Router
    Setting secured wireless connection
    You can enable WEP on your router.
    In the address bar of your browser, type 192.168.0.1 to access the setup page of the Dlink router.
    By default the username is admin and leave the password blank.
    On the Setup page, go to Wireless.
    Security Mode should be WEP then click Next.
    You can change the WEP KEY 1. Make sure you remember this because you will need to enter this on your wireless computer.
    Save the settings.
    I hope this helps!
    Jul 19, 2010 | D-Link DIR-625 (790069292637) Wireless...
    My wireless network is currently unsecure. how do
    If you have a PC connected to your router through an Ethernet cable (i.e. wired), make the changes through it, because, if you do it through a wireless device, you would loose access as soon as you set your wireless secturity parameters. Anyway, start a browser (e.g. Internet Explorer) and go to 'http://192.168.0.1' (this is the default IP address for this router. If you have changed it, replace it with yours). An authentication screen will come up, Enter 'admin' as 'User name', leave the 'Password' field empty, and click on 'OK'. The web interface will come up. Click on the 'Wireless' icon (on the left side of the screen) and the 'Home' tab. On 'WEP', click the 'Enabled' checkbox. On 'WEP Encryption', if you choose '64bit' you must enter exactly 5 characters as your wireless passphrase. Otherwise, if you choose '128bit' (more secure, of course), your wireless password must be exactly 13 characters long. To make it easier for your, select 'ASCII' under 'Key Type', and enter either your 5-char long or 13-char long passphrase under 'Key1' (make sure its checkbox is ticked). Then, click 'Apply' (the green icon with a check mark). Your router is now secured. Now, make these same changes (i.e. WEP encryption method and the passphrase you've chosen) on all devices (computers and/or smartphones), in order to allow them to connect to your router through Wi-Fi.
    Hope it works for you.
    Cheers! Carlos
    May 21, 2010 | D-Link AirPlus DI-524 Wireless Router
    I got a Netbook, I have been using wireless internet in my home for years but cannot connect to internet with new computer.
    In order to connect with the wireless router u need to scan for the available wireless networks in the range .
    So if u r using Win XP ,
    1. Rightclick on the wireless network connection.
    2. U will see view available wireless networks..
    3. u will see ur network name
    4. enter ur security key
    5. Connect
    Or if u r using win vista :
    1. click on start
    2. Connect to wireless network.
    5. Connect
    In case u need further help , feel free to get in touch .
    Nov 24, 2009 | Computers & Internet
    Will not accept password
    Please follow the steps on a computer connected to the router so as to check the network key:
    1. Open the browser(Internet Explorer or Mozilla Firefox).
    2. Access the router usually http://192.168.1.1 else try http://www.routerlogin.com
    3. Login to the router with the Username as admin and password as password (unless you have changed it).
    4. Click on Wireless Settings'(under Setup) from the left menu.
    5. Check if 'WEP (Wired Equivalent Privacy)' or 'WPA-PSK (Wi-Fi Protected Access Pre-Shared Key)' is selected under 'Security Options'.
    6. If WPA-PSK is selected, copy the code entered in the passphrase.
    7. If WEP is selected, copy the code entered in the key that has been checked.
    This is the code required for connecting the wireless computer to the routers' wireless network.
    In some cases, for security reasons the passphrase might show as asterisks. In this case type a new password and click apply. You will then have to use the same password for all the wireless devices connecting to the network.
    IF the computer has windows Vista then perform the steps below:
    1. Click START, Click Control Panel then click classic view in left hand side menu.
    2. In the main screen, open up NETWORK AND SHARING CENTER.
    3. In the left hand side menu open up MANAGE WIRELESS NETWORKS.
    4. If you see any name in the list, please select the name and click remove.
    5. Once the list is empty, click on ADD, select the first option, ADD A NETWORK THAT IS IN RANGE OF THE COMPUTER.
    6. Click on your network name SSID and click on connect. If you have a password setup on the router enter the security key.
    7. This should setup the wireless network.
    For XP perform the steps below:
    1. Right click on My Computer icon and go to Manage.
    2. Go to Services then go to Service and Applications.
    3. Double click on Wireless Zero Configuration.
    4. Change the Start Up Type to Automatic and click on Apply
    5. Click on Start and press OK to close the window.
    6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
    7. Right-click on the wireless Network Connection icon and select 'Properties'.
    8. Go to the 'Wireless Networks' tab .
    9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
    Now please perform the following instructions to connect to the wireless network:
    1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
    2. Right-click on the wireless Network Connection icon and select 'Properties'.
    3. Click on the 'wireless network' tab.
    4. Under Preferred networks if you see any name in the list then highlight the name and click remove. Click OK.
    5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
    6. Look for the SSID (aka Network Name) of the Wireless router or access point.
    4. Highlight thee SSID from the list that you want to connect to.
    5. Type the security Key here and click on the 'Connect' button.
    6. You should have successfully established a wireless network connection.
    I hope this information allows you to resolve this issue.
    If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
    Regards
    Anand
    Sep 24, 2009 | NetGear WGT624 Wireless Router
    Wireless doesn't work
    Hi Friend,
    Kindly check the below given instructions,
    To access the WIRELESS (WLAN) settings window, click on the Wireless Setup button in the SETUP directory.
    WIRELESS NETWORK SETTINGS
    1.Click on the Enable Wireless box to allow the router to operate in the
    wireless environment.
    2.The SSID identifies members of the Service Set. Accept the default
    name or change it to something else. If the default SSID is changed, all
    other devices on the wireless network must also use the same SSID.
    3.Enable Auto Channel Scan so that the router can select the best
    possible channel for your wireless network to operate on.
    4.The Wireless Channel can let you select the channel of your access
    point. Channel availability is different for different countries due to their
    regulation.
    5.Select 802.11 Mode to operate in b/g/n mode. Or select specified mode
    to use.
    6.Channel Width, Maximum rate for 20 MHz is 130 Mbps. Maximum rate
    for 40 MHz is 270 Mbps.
    7.Transmission Rate, suggest keeping the Best (automatic) selection.
    8.Click on the Hide Wireless Network box to allow the router to stop broadcasting its SSID.
    WIRELESS SECURITY WIZARD
    1.Click on the Security My Wireless Network button to enter the
    2.SECURE MY WIRELESS NETWORK window.
    1.Input the SSID.
    2.Select the Wireless Channel.
    3.Select the Encryption type. WPA-PSK is more secure than WEP 64 bit.
    4.Click on the Apply Settings button to apply the settings
    WIRELESS SECURITY MODE - WEP
    1.WEP (Wireless Encryption Protocol) encryption can be enabled for
    security and privacy. WEP encrypts the data portion of each frame
    transmitted from the wireless adapter using one of the predefined keys.
    2.The router offers 64 or 128 bit encryption with four keys available.
    Select WEP Key Length from the drop-down menu. (128 bit is stronger
    than 64 bit)
    3.Specify the encryption key from the Current Network Key drop-down
    menu.
    4.Enter the key into the WEP Key field 1~4. (Key length is outlined at the
    bottom of the window.)
    5.Select Authentication type from the drop-down menu. (Shared is
    better than Open)
    6.Click on the Apply Settings button to apply settings.
    Check and revert back
    Regards,
    Ayyasam
    May 30, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
    Wireless not working
    remove wireless security as Linksys won't accept certain WEP keys
    ping the device to determine that it is there. This often works and shows it is a Linksys setup problem. If can't even ping the device then you have another bigger problem.
    Finally, move the camera to under 5 feet of the wireless access point and then Setup will work. After setup then you can move camera out further.
    Apr 11, 2009 | Linksys Wireless-G WVC54GC Network Camera
    Cannot get online
    The hotels I have stayed in are open access wireless. Basically anyone has access whether they are guests or not. The hotels generally have some sort of internet mgmt that throws out some sort of advertisement before allowing you to get on the internet. Right click the wireless icon and view available networks, you might not even be on the motel's network.
    Aug 22, 2008 | Computers & Internet
    Computers & Internet Logo
    67 people viewed this question
    David Payne
    David Payne
