Question about Motorola Mobility RAZR V3i Cellular Phone
V3i my motorola v3i lifespan is ony 7 hours even if i charge it for a long time...i trid to buy a new battery but its the same...what will i do now??? :)
  • Anonymous Aug 22, 2008
    سسس
    Master:
  • 497 Answers
Hi..ur motorola v3i is defaulted with 7 to 10 hrs of battery life only...o save more power...
  • Keep the brightness on the screen to a minimum. You can also adjust how long the backlight stays on without input from the user.
  • Turn off the Bluetooth when not in use. Bluetooth is a big battery draw.
  • Disable incoming beams so that the phone isn't constantly "searching" for infrared partners.
  • Completely close non-essential programs. When you run an application, it does not shut down completely when you "close" it. It is simply minimized. Go into the Settings to completely shut down any programs you are no longer using
  • also u cud get a car charger so that u cud be sure not to run out of juice..
    Thanks for using Fixya
    Posted on Aug 23, 2008
    SOURCE:
    When I plug in the adapter to the charge the consol the orange light lit. The light does not turn off even after 13 hours of charge. After 13 hours when I want to use it, the red light comes on not the...
    Hello there. You may need to replace your battery pack, as leaving it charged for over 4 hours can lead to "overcharging" a condition which can dramatically shorten your battery packs lifespan and charge retention.
    Also, be sure to charge your console while the device is turned off. Although you may charge it while it is powered on, it will take longer.
    As stated, be sure not to leave the system on charge for more than 5-6 hours, as this can damage the battery and is liable to cause battery leakage, burning, or overheating.
    Battery life is largely dependent on the game being played - some games can give you up to 10 hours of battery life, though the real-world estimate is really more like 5-7 hours of constant use before you'll need to recharge.
    I hope this helps you. -
    Frankie.
    May 11, 2011 | Nintendo DS Lite Console
    My battery once fully charged only seems to hold for sometimes a few hours and other times as normal for a week +. Will buying a new battery solve the problem or is it possibly something more sinister? I...
    well the weather might have very little to do with this unless you expose your phone to the harsh atmosphere.
    it is most likely that your battery has exceeded it's estimated lifespan or is probably damaged. this causes it to loose charge quickly and as such it cannot power the phone properly for a very long time.
    the best advice is for you too get a new original battery as there are fakes flooding the markets right now and buying a fake may only worsen the situation.
    when you buy a new one, it is advised you charge it fully for about 3 hours before turning on the phone.
    hope this helped you? please contact me for more information
    Dec 23, 2010 | Nokia 6300 Cell Phone
    Invalid batery for v3i
    your battery came of a non verizon phone verizon does this alot even with the charger they want you to buy from them only next time make shure its a verizon model battery good luck!
    Sep 01, 2009 | Motorola Mobility New OEM RAZR V3 V3i...
    Moto razer software problem
    You should check the battery, if the phone says the battery is fully charged and it still shuts off,you will need to send the phone to motorola and have them repair it
    Below is the service page for motorola, you can check to see if the phone is under warranty and then send the phone in. If it is not under warranty, check to see what is the cost to ship, and what they would charge to repair it, then look on ebay for new phone and see which is the best way to go,repair or buy new.
    http://direct.motorola.com/hellomoto/nss/service_cell_phone.asp
    Mar 27, 2009 | Motorola Mobility RAZR V3i Cellular Phone
    Invalid battery
    Pull out the battery *while the phone is on*. Wait 15 secs then put battery back in and turn phone on. That should fix it.
    Nov 13, 2008 | Motorola Mobility RAZR V3i Cellular Phone
    Drains battery in 24 hours
    THE BATTERS ARE DESIGNED TO WORK ON STAND BY FOR ABOUT 3 DAYS BUT THE MORE YOU USE IT THE FASTER IT DRAINS TALK TIME ABOUT 18 HOURES CHARGE EVEY NITE SHOULD SOLVE THE PROBLEM
    Sep 18, 2008 | Motorola Mobility RAZR V3
    Motorola v3i
    most lifetime of motorola batteries
    Aug 07, 2008 | Motorola Mobility RAZR V3i Cellular Phone
    Battery doesn't charge
    change battery first and if it stay not charging download the new software
    Feb 27, 2008 | Motorola Mobility RAZR V3i Cellular Phone
    Battery problem
    it is not a problem with the phone the battery just needs to be changed.
    Feb 11, 2008 | Motorola Mobility RAZR V3i Cellular Phone
    Battery
    well...sir they do die quickly no matter the age of the battery......but you should buy a new one
    Jan 26, 2008 | Motorola Mobility RAZR V3
    Motorola Mobility RAZR V3i Cellular Phone Logo
    87 people viewed this question
    Top Motorola Mobility Cell Phones Experts
    D. E. Hev
    vince
    Lawrence Oravetz
    Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
