Question about Liquid Video Computers & Internet
Model # E17LCD2 Monitor
All of a sudden my monitor has no sound. Also, the color is way off when I print digital enlargements. How can I adjust the colors on my screen? Can I get a manual for this monitor?
SOURCE: Colors not distinguishable
Try changing or replacing the display cable ....Simple as that... might work!
Posted on Nov 23, 2006
SOURCE: Analog Monitor problem
But i have same problem.but i cannot run in 1024x726 pixel..how to fix it
Posted on Jul 18, 2008
frcs68
  • 1605 Answers
SOURCE: my monitors colors are all DARK
no! there is nothing inside that you can adjust.
if the screen i sgetting darker by the days, it is time to buy a new one.
Posted on Oct 23, 2008
SOURCE: LG Flatron Monitor-adjust height and color
https://support.dell.com/support/edocs/monitors/1908FP/en/ug/stand.htm#Using%20the%20Tilt,%20Swivel,%20and%20Vertical%20Extension
4:29:29 If locked in the down position, 1. Push the monitor down, 2. Press the Lock down / release button on the bottom rear of stand to unlock the monitor. 3. Lift the monitor up and extend the stand to the desired height.
Posted on Apr 12, 2009
bob_computer
  • 3153 Answers
SOURCE: switched monitor to a different computer and color
are you sure you cant alter the settings via OSD ?
If not then http://www.normankoren.com/makingfineprints1A.html
Posted on Aug 10, 2009
How fix computer monitor stuck in low resolution
If your resolution is too low, you can change that by clicking on the Start button and then clicking on Control Panel. From the Control Panel window, click on Adjust screen resolution from beneath the Appearance and Personalization section. From the Resolution drop-down, select the highest resolution by moving the slider to the top. Your resolution should be just fine now.
To change your font size, go back to Control Panel, search for "window color" in the search box, and then click on Change window colors and metrics". You can adjust font sizes from here.
Jun 08, 2014 | Microsoft Windows 7 Ultimate for PC
Tip
Using a color enlarger to print both color and black and white photos
Some enlargers have dials on the front that are labeled yellow, cyan and magenta. These enlargers are made to print both black and white and color photos. To print in colors you use the dials to perfect the colors of your print. Let say that you took a picture and the colors look to be a bit off. In the light you would hold up a color filter to the image and decide which filter makes the color look closest to what you want the final image to look like. Then taking the information on the card you go back into the dark room and adjust the dials on the enlarger according to the card that was used. If you were looking through a green filter then you would lower the number on the magenta dial.
Printing in black and white on an enlarger with these dials is a little different. Since there are no colors in the black and white paper these dials have a different function. They are used to adjust the contrast of an image. If you turn the light on in the enlarger without paper under it and turn the dials you will notice that the magenta will make the light darker. When you print with the yellow and cyan dials at 0 and magenta at around 10-20 this will add contrast the image. You can always develop all your negatives without touching any of these dials, but if you can master them then your images will have a little less flat than those with little to no contrast.
on Oct 01, 2013 | Photography
Monitor displays no green
I would have said bad VGA cable, but since you said you already tried a new one, have you tried replacing the VGA adapter?
Aug 29, 2017 | Dell Model 2208WFP - 22 Inch Widescreen...
HOW TO SET BRIGHTNESS OF THE SCREEN?
Dear User...
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.) For more information about calibrating your display color in Windows, see Calibrate your display.
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor. Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Thanks....
Feb 07, 2013 | Computers & Internet
Enlarge screen showing.there is screen not being
You need to expand your screen size with the buttons on the monitor, or increase your screen resolution, to a larger size, I think you need to adjust your monitor with the menu, +, -, buttons on monitor.
Feb 21, 2010 | Computers & Internet
My monitor suddenly altered the colors on the screen; white background now appears slightly pink, green appears black. How can I make adjustment to correct the color?
your monitor is either going bad or your display setting are messed up.use the buttons on the front and mess with color option if that don't work then you need a new monitor
Aug 05, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
My display has a red tint to it
Try adjusting the color properties of the monitor using the controls located on the front of the monitor.
If you can't correct the color, then it's a problem in the color circuit. As an ex tv repair guy I can tell you it may cost more than the monitor is worth to fix it unless it's still under warranty.
Jul 13, 2009 | Dell Computers & Internet
LCM-22w3 monitor suddenly changed colors. All
Try adjusting the monitor cable that goes from your monitor to the back of your computer.
Jul 10, 2009 | Westinghouse Electric LCM-22W2 Monitor
Color is heavy on the green. Can't adjust it to look normal.
Ty reattaching the monitor cable to the monitor and PC.
If that does't work, try another cable.
One of these should solve your problem.
May 19, 2009 | Toshiba 42HL196 42 in. LCD HDTV
Calibration of monitor
Here's the tip I used years ago on CRT's suffering this same fate.
Take one of your printed photo's and hold it next to the screen (with the same photo on it running in whatever software you want to print from)
Now using the monitors controls, make the monitor look like your photo that you have printed.
Nice and dark now like the photo, good =)
Now adjust the software to what you want it to look like when printed.
Looking good so far..ok
Save those settings in the program. then re adjust the monitor back to how you want it to look normally (as it was before basically)
Not the ideal soloution, but it works and it's free.
Apr 15, 2008 | HP f1905 19" Flat Panel LCD Monitor
Computers & Internet Logo
151 people viewed this question
Top Liquid Video Computers & Internet Experts
Rommel Balcita
Mark Gough
Are you a Liquid Video Computer and Internet Expert? Answer questions, earn points and help others
