The keyboard and mouse only work on the BIOS and not on the desktop
  • 6 more comments
  • Anonymous Aug 22, 2008
    it is a toshiba satalite pro 6100
    it only works on the BIOS but when xp runs it doesnt work and i cant re-install xp because of important data
    i was doing a sysyem restore when i forgot to plug the main power in and it turned of during it
    (if i reinstall XP will it erase all my current data)
    it happend when i was doing a system restore the power turned of during it
    (if i reinstall XP will it erase my data)
  • Anonymous Aug 24, 2008
    um, i just put the xp disk in when @ BIOS and re-instal it
  • Anonymous Aug 25, 2008
    i dont have XP home edition which is its running
    but i have a office edition will that 1 work just the same or not
  • Anonymous Sep 03, 2008
    thanks its all fixed now
  • Anonymous May 11, 2010
    What kind of mouse and keyboard are they?Usb or PS/2?
    A little more detail is needed. What kind of pc do you have? What operating system are you using? I'm not clear on what you mean that they keyboard and mouse work in the BIOS but not on the desktop. Thanks
  • 44 Answers
Try doing a windows repair.Follow this link on repairing windows.It doesn't wipe out your files.
Posted on Aug 24, 2008
    Scholar:
  • 152 Answers
You can reinstall XP if you back up your important data. It just might be the solution to your problem. Granted, backing up and then reinstalling everything is time-consuming, but it is the easiest and cheapest way to resolve most issues. There may be a virus or a recently added program that is causing the problem. Have you scanned for viruses?
Posted on Aug 22, 2008
  • Anonymous Aug 23, 2008
    You can reinstall and not lose important data. It's when you reformat that you lose data. You would just be overwriting Windows, not erasing anything.
SOURCE:
Factory mouse and keyboard won't work on emachines desktop
I assume this is a wired keyboard and mouse, not USB. It is possible that the BIOS (controls the hardware) memory has gotten scrambled. On the motherboard is a 3-pin connector with a 2-pin block jumper, usually near the battery, that will reset the BIOS memory to the factory defaults. It should be marked "BIOS", "CLEAR", or "RESET".
Turn the COMPUTER OFF. Move the jumper on the 3 pin connector from the first 2 pins to the last 2 pins. After 5 seconds, move the jumper back to the original position. The BIOS should now be reset.
If you can't find the jumper, you can also remove the nickel-sized battery that powers the BIOS memory.
Jan 23, 2013 | Computers & Internet
I reset my cmos on my dimension c521 and keyboard and mouse dont work. how can i get to bios?
You might want to try a Microsoft common keyboard that hooks to the USB on your Computer same with the Mouse
Jun 01, 2012 | Dell Dimension C521 PC Desktop
Hello, i currently use a IBM desktop with IBM keyboard and mouse but i just bought a microsoft wireless keyboard and mouse which i just installed into my desktop using the installation CD. They are both...
Hi Tony,
It appears that you have an IBM desktop whose BIOS isn't capable of booting off of a USB keyboard and mouse device. Older computers used to require that a PS2 mouse and keyboard be attached before booting, to prevent you from booting a machine without any way of controlling it. You have 3 options:
1. leave the corded mouse and keyboard attached and never use them
2. update the BIOS for your desktop to the newest one in hopes that the updated BIOS will allow for USB mouse and keyboard operation
3. go to a computer store and get a PS2 to USB converter/adapter. They're small and relatively inexpensive. It plugs into the PS2 port, and makes your computer think that there's a PS2 device connected, when it's actually a USB device.
Mar 03, 2010 | Microsoft Wireless Laser Mouse 6000 v2.0
Keyboard and mouse won't work when pc is switched on.
Maybe the problem is in your bios the keyboard and mouse port maybe disabled, try to check your bios for you to enabled in case if it is disabled.
Jan 04, 2010 | Dell Dimension 9150 (DIM915MIN) PC Desktop
I can't get the keyboard NOR mouse to work, plugged it in and my computer doesn't recognize them at all. What do I do??
you will most likely need to go into the bios and enable usb keyboard and mouse, this should correct the issue.
You will most likely need to press the Del key when booting up to get into the bios.
Nov 04, 2009 | Logitech Cordless Desktop MX3200 Laser...
Keyboard loads in Bios...
reload the driver once in windows. unload key board drivers. and let it seek the key board and mouse again.
I’m happy to help further over the phone at https://www.6ya.com/expert/howard_079189dd4959a511
Oct 08, 2009 | Acer Aspire 5100 Notebook
The ps2 ports for both keyboard and mouse do not work. i got around that by hooking both up with a usb connector. BUT when the computer is on with no mouse activity for a while, the mouse ''dies.'' Then...
HI,
Go into the BIOS utility and set the BIOS to defaults, hit F10, save the changes and exit the BIOS, the computer will restart, see if that helps.
To get into the BIOS hit the Esc or Del key when the computers just starting up.
Good luck.
Sep 14, 2009 | E-Machines eMachines Desktop PC
My keyboard works fine in BIOS but at login screen keyboard and mouse don't work. I tried SAFE MODE, same thing. Default BIOS same thing. PS2 or USB don't work but both work in BIOS. HELP
You may need to update/reinstall the drivers for your keyboard/mouse. If you able to get online, that would be faster. If not, use a) your restore disk, b) Press update drives in the Control Panel>Keyboard/Mouse.
Good Luck
C2Solutions
Aug 28, 2009 | E-Machines eMachines Desktop PC
No boot no keyboard or mouse
First disconnect all external connections except video, see if system will boot normally (press the power button once on tower to shutdown)
If that works, then connect the keyboard only to the back USB port nearest the NIC. See if the keyboard works. If it does, shutdown and connect the mouse and try again. If it doesn't, try the mouse only. If you localize the problem to either the mouse or keyboard, replace that item.
If neither works, then reset the motherboard junper to reset BIOS defaults. the again, try them one at a time. If they still do not work, then you will need a mothebroard.
Apr 18, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Open Questions:
VIPRE Technical SuPporT pHONe {@}+18OO8O\=\31O69^%%= NUmbEr ddkkjj This VIPRE USA phone number is ranked #2 out of 2 because 7,728 VIPRE USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O31069 is to reach the VIPRE USA Technical Support department for problems like Where to buy, Complaint, Technical support, Repairs, Returns. As far as we can tell, VIPRE USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. VIPRE USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact VIPRE USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling VIPRE USA Calling VIPRE USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from VIPRE USA Technical Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with VIPRE USA's Technical Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare VIPRE USA's phone numbers against each other. Contacting VIPRE USA in General While I8OO8O31O69 is VIPRE USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach VIPRE USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact VIPRE USA.
Oct 17, 2019 | Best Computers & Internet
AVAST Technical SuPporT pHONe {@}+18OO8O\=\31O69^%%= NUmbEr ddkkjj This AVAST USA phone number is ranked #2 out of 2 because 7,728 AVAST USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O31069 is to reach the AVAST USA Technical Support department for problems like Where to buy, Complaint, Technical support, Repairs, Returns. As far as we can tell, AVAST USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. AVAST USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact AVAST USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling AVAST USA Calling AVAST USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from AVAST USA Technical Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with AVAST USA's Technical Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare AVAST USA's phone numbers against each other. Contacting AVAST USA in General While I8OO8O31O69 is AVAST USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach AVAST USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact AVAST USA.
Computers & Internet Logo
46 people viewed this question
Ekse
Alun Cox
