Question about Canon Office Equipment & Supplies
I need to know what windows program the Canon S750 will work with. Example will it work with 1998 Windows and older.
  • 94 Answers
Operating systems that it works with is Windows 95/98/2000/Me/XP, Windows NT 4.0, Mac OS(8.5 to 9.x) and Mac OS X v10.1 to 10.2.x
may work with vista if drivers are available in canon website... for this model...
Posted on Aug 22, 2008
Can a Canon S750 work on Windows 8? And i don't have the Set-Up CD-Rom...i brought it from a garage sale and the lady said she had lost it.
Cannon has pretty good driver solution and has the Win 8 version for this model. Just search Canon S750 driver, and choose OS version.
Jan 03, 2013 | Canon S750
CANNOT INSTAL CANON n1240U SCANNER ON WINDOWS 7
Your scanner model is not supported on windows 7.
Jun 07, 2011 | Canon CanoScan N1240U Flatbed Scanner
Canoscan n640 not work in windows 7
Canon stopped supporting this scanner after XP. The available software and drivers are here: http://www.canon-europe.com/Support/Consumer_Products/products/scanners/Others/N640P_ex.aspx?type=download&page=1 .
Depending on the version of Win7 on your computer, you can try one of the following workarounds. To check your version, click Start > Control Panel > System and Security > System. If it says x64, you have a 64-bit version of Windows 7. Otherwise, it is the 32-bit version.
1) If you have the 32-bit Win7, you can try the compatibility mode. Download the driver or full software from the Canon site and right click on the installer. Then choose Properties and then the Compatibility tab. Turn on Run program as Compatible with the appropriate OS. Then right click again on the installer and choose Run as Administrator. Then check if the program itself is running in the compatibility mode by right clicking again and choosing Properties. This may not work.
2) The option that will work for all versions of Win7 is to use a computer (virtual, dual-boot, or true second machine) with an older version of Windows installed. If you have Win7 Pro or Ultimate (or upgrade to them), you can create a virtual XP computer for free. Download and install Virtual PC and XP mode from Microsoft. Install them in order. Then install the XP software from the Canon site in the virtual computer and it will work. (Other virtual computer programs are Parallels and VMWare.) All of the other options will require a licensed version of the older Windows OS. Please note that the virtual computer can't share files directly with the main computer. You'll need to save files to external or removable media (optical media or flash drive, for example) to share them. Also a printer cannot be installed on both the real and virtual computers at the same time. You will be prompted to uninstall one set of drivers if you try.
I hope this helps.
(the above suggestions assume you do not want to replace the scanner which would be faster.)
Jun 07, 2011 | Audio Players & Recorders
I want to install the CanoScan Lide30/N1240U but there is no driver for Windows7. So it looks like I cannot use the scanner anymore. Is there anyone who knows a solution?
Go to site
http://software.canon-europe.com/products/0000466.asp
and select OS as Vista and language as English and press submit
and download windows vista drivers.
you can use Vista driver in Windows 7 using Compatability Mode.
Step required..
1. Right click on driver installation file.
2. choose properties
3. choose compatability tab
4. select Vista
5. press ok
6. Install the driver
I hope it will help you.
Thanks for using FixYa.
May 23, 2011 | Canon CanoScan LiDE 30/N1240U
CS4 is not detecting WIA device or the Twain driver. I have down loaded the latest canon driver and installed it several times and the system will not connect the two programs. I am using Windows 7...
The Canon software that you downloaded is for Win7 32-bit. Canon does not support this scanner on 64-bit OS versions. With Canon, I've found that the compatibility mode does not work.
A method that will work is to use a computer (virtual, dual-boot, or true second machine) with an older version of Windows installed. If you have Win7 Pro or Ultimate (or upgrade to them), you can create a virtual XP computer for free. Download and install Virtual PC and XP mode from Microsoft. Install them in order. Then install the XP software from the above site in the virtual computer and it will work. (Other virtual computer programs are Parallels and VMWare.) All of the other options will require a licensed version of the older Windows OS. Please note that the virtual computer can't share files directly with the main computer. You'll need to save files to external or removable media (optical media or flash drive, for example) to share them.
I hope this helps.
Apr 14, 2011 | Canon CanoScan 8000F Flatbed Scanner
C;\Documents and Settings\admin\My Documents\downloads\Silverlight.exe is not a valid win32 appplication
HI,
causes for these problems are:
1. File is corrupt, bad, or missing.
2. File is not designed for your version of Windows.
3. File is a virus, worm, or other malware file.
4. Hardware incompatibility.
Step 1: Verify that the program installation CD is clean. If the CD is dirty or bad, you could get this error during the install and/or get this error after the program has been installed because it was not copied properly onto the computer.
Step 2: Make sure the program or file you're attempting to run does not contain the same name as the long file name directory it is contained in. For example, executing a file named "program" in the "program files" directory can cause errors.
Step 3: If you're trying to run a program that is not designed for your version of Windows you may get this error. Although many older programs designed to work in older versions of Windows will work with new versions of Windows, unfortunately, not all programs will work.
· If the program is an older MS-DOS program or early Windows program you may get this error.
· If the program is designed for a 64-bit version of Windows and you're running it in a 32-bit version of Windows, it will not work and generate this error.
Step 4: Run an online scan for any threat and try to fix them
http://onecare.live.com/site/en-Us/center/cleanup.htm
Thanks and regards
Nandy
Oct 26, 2010 | Microsoft Computers & Internet
Canon MF5550 printer driver for Windows Vista
I just found this solution TODAY! After trying for a whole year to fix this thing... It was right at my face the whole time!!!!
1) Uninstall your old Canon MF5550 driver.
2) Reboot your computer
3) Download the Canon MF5550 driver Windows XP version.
4) Open your Vista Control Panel, then click on PROGRAMS (not on Uninstall or something else...)
5) bellow "Programs & Features", click on "use an older program with this version of Windows". Follow the wizard.
6) Locate the program manually. (If you need to search the folder where you downloaded your Canon driver, just go to search file on C. It will probably download on your desktop or Downloads)
7) Open the MF5550 Folder where you downloaded the driver, and click on the setup.exe file.
8) Choose on the next screen Windows XP
9) If you need to change the display settings, go ahead. But I didn't change anything. I just clicked NEXT.
10) Fill in the box: RUN THIS PROGRAM AS AN ADMINISTRATOR and click NEXT.
11) Click Next again and let Windows Vista do its job.
12) If it worked... just click yes and finish. If it didn't, click NO and run it again.
I AM SO HAPPY THIS THING WORKED!!!
Let me know if this worked for you!!!! I know I've looked everywhere for this solution...
email me at music2harvest@msn.com
GOOD LUCK! GOD BLESS!
Apr 07, 2008 | Canon imageCLASS MF5550 All-In-One Laser...
Canon
Here is the driver page for windows xp from canon
http://www.usa.canon.com/consumer/controller?act=OSCompatibilitySupportAct&keycode=windr&fcategoryid=231&modelid=6612
here is a different website providing the same drivers for xp200
http://printers.free-driver-download.com/Canon/22877/Canon-S750-BJ-Printer-Driver-v1.62-WHQL-Windows-2000-XP.html
I couldn't find drivers for Vista . I think they are included in Vista installation. Let me know if you need drivers for a different operative system.
Feb 19, 2008 | Canon S 750 InkJet Printer
Mp 500 printer driver software
Try the Canon website for updated drivers.
If they don't have one, try using the compatibility wizard.
Download the latest driver available from the canon web site
To open the program compatibility wizard
1. click the Start button
2. click Control Panel
3. click Programs
4. click Use an older program with this version of Windows
5. browse to the program's setup file, usually called Setup.exe, Install.exe, or something similar. The wizard is not designed to work on programs that have an .msi file name extension.
Dec 15, 2007 | Canon Pixma MP500 All-In-One InkJet...
old marine
old marine
