Question about Dell 3010cn Laser Printer
Streak in color printing only
My Dell 3010cn color printer worked fine for about a year. Then I noticed on the right side of the page there were splotches, and streaks, including on the edge if the printed image (at the right border) the ink steaks off the end of the image.
After some troubleshooting I was convinced I needed a new Bias Transfer Roller. It has take me 6 months to get one. In the mean time printing in black and white is perfect.
When I replace the Bias Transfer Roller, the same results occurred. I can't be sure if the splotches are in the exact same place as with the previous BTR, but it looks close.
I have tried the cleaner of to the side of the printer and that did nothing. It's almost like there's an static charge somewhere on the drum (I assume there is one).
Can you offer any advise as to what the problem is please?
Try this page from the Dell Community Support Forum. <a rel='nofollow' href="http://www.dellcommunity.com/supportforums/board/message?board.id=A940&message.id=26221&query.id=335768#M2622" target="_blank">Click Here</a>
Posted on Sep 01, 2008
Dell 3010cn printer, Printing on right side ends of the page is faded.
There could be dust/ Toner Dust accumulated on the mirrors and lenses inside the printer, which partially blocks laser beams and requires cleaning/ servicing by a professional.
Hope this helps! Dont forget to appreciate the solution!!
CreativeTECH
Dec 13, 2010 | Dell 3010cn Laser Printer
Dell 3010cn white stripe
on the 3010cn open from cover, follow instruction for pulling up the lever and sliding the bar out of the side repeat the slide motion 15 to 20 time. this action cleans the printing plate and will elimiate the strip. the strip is caused be toner leaking on to the plate it the strip returns repeat the steps.
Nov 17, 2009 | Dell 3010cn Laser Printer
Dell 3100cn Smudges on all color except black
Sounds like the fuser. Try heavier paper settings (you have to change them in all 3: driver, printer itself and program you are printing from). If that doesn't work replace the fuser.
Feb 24, 2009 | Dell 3100cn Laser Printer
Dell 3010cn Color Laser Printing Quality
yes..it's almost certainly the drum..did you get a new one or was it simply refurbished?
Aug 20, 2008 | Dell 3100cn Laser Printer
Color streak from center to right straight down the paper
Open the front door and about half way down on the right you'll see a light blue tab. Pull it up and a sliding door will open on the right hand side of the printer. Inside is a slide handle with a swab on it. slide the handle in and out 6-10 times and this shoul help with the problem. Try printing again and if it is still not 100% just retry the cleaning process. I had the same problem and thought it was the fuser, but this worked well for me. You can remove the swab for cleaning as well.
Aug 03, 2008 | Dell 3010cn Laser Printer
Dell Printer Problem
Open the front door. On the right side of the printer a small door will open. Inside is the cleaning rod. Pull it all the way out and push it all the way back a good 20-30 times. Try again. See if that helps.
Jul 26, 2008 | Dell 3010cn Laser Printer
Not printing extreme right side of page
It is either your drum or open front cover see blue handle @ right hand side pull it out look at rignt hand side of printer and a door has opened (only small) pull the blue lever out and move the pad back andforwards a few times this cleans the glass.
It worked for me but I have to do it fairly often but it samve buying a new drum etc
Jan 08, 2008 | Dell 3010cn Laser Printer
Dell 3010cn Laser Printer Logo
288 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
