Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Kitchenaid Fridge not working
Model KSCS25INSS00, bought July, 2004
Fridge is 4 years old-
Neither side will get cold at all, heated door frames are cool, power and light seem ok, digital display appears normal.
A technician came out and said the main electronic control was bad and sent a new one (P/N 2307028) and I installed it (Since he forgot to schedule a return visit, and I didn't want to wait another week.)
Still no change in operation.
I ran the service diagnostic mode from the fridge control panel- but step 5, compressor check, showed code 02; compressor off. I waited 7 minutes as suggested by the service and wiring sheet, but still no compressor ops (should read code 01).
Checking the schematic on the reverse side of the sheet, I don't see a compressor relay, but rather an inverter (gray box, sits next to the compressor in the back).
I actually don't see any relays in the schematic at all- is it all solid state?
Completely unrelated, but I did notice that there is an optional door heater for stainless steel models, as I noticed in other posts, people complained about the seal area being warm- Mine's been warm from the get-go, I believe it is to keep condensation from freezing the seal to the frame. I'm not sure if the heater is electric or (as I believe in my case) part of the evaporator loop.
  • badfridge Aug 27, 2008
    how did u run the diag. code
aborcass
  • 2651 Answers
SOURCE: Compressor not running
you can try to repalce the "overload relay", with the model numberlook up the correct part. i would also check with oyour manual perhaps you have an extended warr. on your compressor assembly( comes with a new overload relay)..
Posted on Mar 01, 2009
  • 1073 Answers
SOURCE: rubber door gaskets very warm to touch, ice cream soft, ice ok
the icemaker will work until the frezer gets to 17 then it will quit sound like a defrost issue defrost heater defrost thermastat or defrost timer need to get it fixed sooooooon you dont want to loose food at the price we have to pay
Posted on May 08, 2008
SOURCE: Kitchenaid fridge #KSCS25INSS hot door frame
how to change the waterhose my Kitchenaid fridge #KSCS25INSS
Posted on Sep 12, 2009
SOURCE: 4yr old kitchenaid refrigerator compressor failure
FRIG STOP GETTING COLD AND MAKING A LOUD NOISE
Posted on Dec 26, 2009
  • 161 Answers
SOURCE: Fridge and freezer not getting cold
the large black component being the compressor itself,i assume...the relay/overload device plugs directly onto the compressor sometimes hidden by a protective cover that you have to pry/or break off sometimes...follw the wires leading to the compressor they attach to the device itself...wires are usually red and white sometimes include yellow or blue also- for a capacitor
Posted on Apr 16, 2010
Underneath the freezer side, way in the back there is a constant drip coming from the tubing there, it then fills the catch pan underneath which then leaks onto the floor why it this tube suddenly...
Assuming you have the KitchenAid fridge depicted, it has cold water and ice-cube making facilities installed, have you had these plumbed in to the water supply?
Obvious thought is a leak on the pipeline or control valve-gear, which I think is located to the rear lower left of the unit (looking from the front.
Otherwise all ‘frost-free’ fridges have a drain pipe from the refrigerator compartment drain trough inside, to a plastic container clipped to the top of the compressor. Here the condensate from the fridge is evaporated off due to the running heat of the motor. Check that this pipe is plugged in where it should be and that it is clear of any debris, old food-stuff etc. Some fridges had a fold of foam ‘cloth’ somewhat like a ‘dishwashing wipe’ stood upright in the plastic container to better evaporate the fridge run-off.
If the fridge is only now making excess condensate look at the door seals and run your hand all around when closed to see if you can feel any cold air loss from a particular area. It is sometimes worth running a little silicone grease down the seal on the hinge side of the door, to ensure it slides easily and doesn’t get creased.
Sep 13, 2010 | KitchenAid (KSRD22FKST) Side by Side...
How do I know what filter to buy for my Kitchenaide Superba Model# KSCS25INSS00??
Part number 4396841
The filter is located underneath the fridge, and accessed from the front of the fridge.
Mar 04, 2010 | KitchenAid Superba Architect KSCS25INSS...
There are heaters located inside the door frame, to prevent your doors from freezing shut, and also to prevent condensation on the outside of the appliance. It sounds to me as though that is where your problem is... Hope this helps
Sep 09, 2009 | KitchenAid Superba Architect KSCS25INSS...
KitenAid KSRX25F -- HOT FRONT FRAME
The fan which cools the compressor is not working , OR , the coils under the front of fridge are very dirty .
Aug 01, 2009 | KitchenAid KSCS25IN Side by Side...
Front metal , top heating element very hot
This should be OK. There are heat strips placed behind the door frame to prevent sweating around the door frame due to the metal being cold normally without the strips. Thanks, Sea Breeze
Jul 21, 2009 | Refrigerators
8 year old Kitchenaid not cooling
the floor has no control over the fridgr or the way it works.you said its 8 years old youve already replaced the compressor once so maybe it time for e new fridge.
Sep 01, 2008 | KitchenAid KSRG22FK Side by Side...
GE side by side Refrigerator approx. 8 years old. Fridge side barely cold.
With your fridge, does the light go out when you shut the refrigerator door?
That could be your issue, that light running inside will create Alot of heat.
Also check to see if there is air circulating from the freezer to the fridge side through the damper. The damper is on the Fridge side left wall up towards the top. That is where the cold air gets to the fridge side. If that damper doesn't open that will also cause your problem, Let me know how you make out.
Bill
May 14, 2008 | Refrigerators
Controle panel flashes 88 like it is trying to start the motor is trying....
LooseChad Were did you store the fridge? Has it been in the upright position all the time? If not, it has to be kept in the upright position for at least 24 hrs before you plug it. If this is not the issue, then most likely the problem is a bad starting device for the compressor or the compressor itself. If it is just a starting device then you can fix it yourself and the part is not expensive. If the problem is the compressor and your fridge is less then five years old - it is still under warranty and Kitchen Aid has to fix it free of charge. If the fridge is more then five years old, it is going to cost you over $500 and you have to compare it with the price of the new one.
Jul 07, 2007 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
398 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
