Question about Garmin GPS
The system stopped working while plugged into the car and wouldn't re-start.
  • rlewis1234 Aug 24, 2008
    The model number of my garvin navigation system which isn't working is:
    StreetPilot c340 -- 116505887
    Rita
    Also please email when you respond.
    How do you re-set the unit?
    Genius:
  • 1,011 Answers
Dear,
have u checked with except car.
try it to use seperately.
check its adapter giving output
whats the condition. does it seem dead
regards,
dont rate it until it help to solve
Posted on Aug 24, 2008
  • 4,472 Answers
What is the exact model of the unit. Have you tried resetting the unit?
Thanks,
lee
Posted on Aug 22, 2008
  • Garmin Master
  • 6,487 Answers
Can you please give us the model number of this unit so we can help you further..You can try to unplug and replug it back in..
Thank you........
  • Mark Gil
    Mark Gil Aug 24, 2008
    Try this:
    Unplug the power and USB cables to remove external power
    Place your thumbnail in the groove located under the Garmin logo on the faceplate and gently pull off the faceplate
    Press the Reset button for 3-5 seconds
    Connect the C340 to a power source using the power cable
    If after this still nothing the unit needs replacemnet already..
    Hope that helps
2000 Pontiac Grand Am SE security system wont let car start
first most GM OEM systems will need to recognize the key first and foremost ,to do that you will need to roll window down on driver door,turn the key to the run position and with engine NOT running leave the key on for 10 minutes exactly ..then turn ignition off then try to start engine. if original system is working engine should start normally
Mar 26, 2017 | Cars & Trucks
The auto. door locks, radio, and dome lights not working
You have burned out the vehicle's controls modules, call your insurance company, they should cover this type of unfortunate mistake.
Jun 15, 2017 | 2000 Mazda MPV
Saturn starting promblem.
Had same problem with 6cyl. merc.
Started fine cold but wouldn't start when turned off hot.
Replaced spark plugs & worn dist. cap .Problem solved.
Feb 23, 2012 | Cars & Trucks
Fuel pump and injectors stopped working at the same time
You stated it is a Cummins so it must be a diesel. Somewhere there is a solenoid that controls fuel flow. When you switch the key off power is dropped going to the fuel cut-off solenoid. Loose wire, bad solenoid, no power to the solenoid in run position would never allow fuel to flow. I wouldn't image glow plugs are the problem. All of them I've seen will still start with multiple glow plugs defective.
Jan 01, 2012 | Cars & Trucks
We have a 2003 dodge caravan and have been having problems with keeping a charge. the alternator has been replaced, so has the battery. several weeks ago I had driven up to 7-11 came out and it would not...
Testing the electrical circuits an componets is the way to find the problem , not guessing . Testing power an grounds . Voltage Drop Testing the Charging System Plus this charging system is computer controlled .Free wiring diagrams here http://www.bbbind.com/free_tsb.html Enter vehicle info. year , make , model , engine size . Under system click on engine , subsystem click charging system .
Mar 30, 2017 | 2003 Dodge Caravan
GPS Logo
19 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
