Question about Sony Grand WEGA KDF-55XS955 55" Rear Projection HDTV
Rear projection LCD Image Burn
I've got a Sony rear projection HD LCD TV that's been performing well until today. I have Dish Network satellite service which has a tendency to go out when heavy rain is present. When the signal goes out the image goes to a screen showing a heavy blue box showing the dish searching for a good signal. Well once the dish resumed a proper reception there it was: A faint blue shadow remained regardless the image. I thought this was not supposed to happen with LCD TVs. Is there a fix for this? I saw a DVD that's supposed to fix the problem, but was wondering is this just another scam to get my $40 bucks.
  • s2seal Aug 22, 2008
    This is a continuation from the original message. The next day the blue clouded image has improved, practically gone. The bottom of the screen has a little blue cloud still showing.
  • dh2supa Feb 25, 2009
    Running letterbox setup creates black/dark strip across the top and bottom of the screen - the bottom is OK but the top has clouded. Looks like the sun visor strip on a car windscreen - have reverted back to center cut but discolouration has remained
  • 320 Answers
Copy and paste the following link in your browser:
http://ciscdb.sel.sony.com/perl/news-item.pl?news_id=206&mdl=KDF50WE655
You have a problem with your optical block and Sony is covering the repairs. You MUST HURRY as the warranty extension only runs through the end of December. Be sure to rate this answer. Thanks!
Posted on Nov 29, 2008
Is this tv hd ready?
Yes, it should be HD ready. There should be a small label on the front of the TV if so (provided it has not been removed). You will need a HD cable box, convertor or HD satellite box (Direct TV or Dish Network) to view HD broadcasts (even from free over-the-air HD broadcasts if you live within range of a local broadcasting station). I had the same, or very similar TV but upgraded to flat screen plasma set.
Aug 14, 2012 | Hitachi 53SBX01B 53" Rear Projection...
How do I install my dish network satellite to my new 47" panasonic?
We would be happy to help you with that. We would recommendvisiting our "Set up receiver to TV"page here:http://www.dishnetwork.com/SupportSection/setup-receiver-totv. We hope thisinformation helps you. Thank you for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Jan 18, 2011 | Panasonic PT-47XD64 47" Rear Projection...
I have a 50" hitachi rear projection tv, do i need
rozmyers,
You do not need a high def receiver, your unit has an ATSC tuner which is the same thing. You do need to hook it up to a high definition signal. You mentioned that you have satellite. Call your supplier and order the high definition channels if you do not already have them on the downlink. They should be able to tell you if you have them or not. They should also be able to tell you which channels they are (normally the higher ones). Once you have a high definition feed you will have the best picture you are going to get with todays technology.
Thanks for using FixYa and for the great rating. Please consider a testimonial.
hardrocko
Jan 09, 2011 | Hitachi 57S715 57" Rear Projection HDTV
Will I be able to receive HDTV programming on my TV?
Your HDMI Cable or Component Cables will plug right into their receiver box. You won't need anything else and they should supply the cables too.
Jan 06, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
It wont display satellite(dish) or
If the satellite picture displays on other tvs in the house, and you have the satellite hooked up to the rear projection tv you may have to do the following:
1. Using the remote, select the input button. You will now see a menu of several choices.
2.Methodically go from one to the next until your satellite pix appears.
Nov 14, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Receiving HD from Dishnetwork
Hi. You will love the dish. I have enjoyed it in my home for a number of years. I like the HDMI cable because it is the best quality and simple to install, one cable does it all. If you don't have one yet get it at walmart where it is about half the cost of other retailers. All satellite TV is HD without you doing anything special. So yes, it will do HD from whatever input you choose.
Jun 27, 2009 | JVC AV-65WP55 65" Rear Projection...
HD Hookup on Dish Network 2nd Location
In order for you to receive HD broadcasting you must have a HD-TV, otherwise you wont get the picture in HD. Also I should point out that you need to make sure that the signal itself is being broadcast in HD.
Apr 28, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Lost my picture when went to pip
Check your PIP source. I couldnt figure out my LCD pip, and why it wasnt working either until I was able to switch the source. It was automatically using a source that didnt have anything hooked up to, I had to switch mine in order for it to work. Try that and see if that might be the case. let me know. thanks!
Sep 24, 2007 | Mitsubishi VS-55705 55" Rear Projection...
Sony KDF-42WE655 (LCD 42 inch)
I have the exact same problem with my 42" LCD HDTV. When I called Sony "customer support" they told me NOTHING. However, I began researching this issue and found out that Sony knows all about this problem. It's a part called the "Optical Block" and THEY are supposed to reimburse you for the repair! The claim form is on the Sony Website. Here's the link: http://esupport.sony.com/US/perl/model-home.pl?mdl=KF42WE610&LOC=3 Look inside the yellow box on the right and click on: Additional service coverage information for your TV (scribble / line pattern on screen) Hope this helps you!!
Apr 28, 2007 | Sony Grand WEGA KF42WE610 42" Rear...
Sony Grand WEGA KDF-55XS955 55" Rear Projection HDTV Logo
144 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
